Johnny Bravo Posted January 19, 2007 Author Report Share Posted January 19, 2007 Så tror jeg vist liiiige vi klapper hesten dødsfjæs Hvorfor skal din mor blandes ind i det? Quote Link to comment Share on other sites More sharing options...
Guest Slettet bruger Posted January 20, 2007 Report Share Posted January 20, 2007 Bruger han homo-pøllen? Jeps. Det gør han. Prøvede at tale ham fra det, men han var så inspireret af pyramidebænkerne, at han ville bænke med pude i minimum 45 minnutter..... Quote Link to comment Share on other sites More sharing options...
Johnny Bravo Posted January 20, 2007 Author Report Share Posted January 20, 2007 (edited) Jeps. Det gør han. Prøvede at tale ham fra det, men han var så inspireret af pyramidebænkerne, at han ville bænke med pude i minimum 45 minnutter.....Så vidt jeg har hørt, så har han end da sin egen tude-pude med sit navn på... li'ssom pro'erne. Edited January 20, 2007 by Johnny Bravo Quote Link to comment Share on other sites More sharing options...
Johnny Bravo Posted January 20, 2007 Author Report Share Posted January 20, 2007 Lidt træning for tændstikkerne.Smith frontsquat:12x40kg12x40kg8x60kg8x60kg8x60kgSquat:12x60kg5x100kg5x100kg5x100kg8x80kgStifflegged deadlift:8x60kg6x100kg6x100kg6x100kgLegextensions:15x90lbs15x110lbs10x150lbs10x150lbslying db. legcurl:10x19.5kg10x19.5kg10x19.5kgStanding calf raise:12x200lbs12x200lbs12x200lbs12x200lbsSluttede af med lidt mave træning. Quote Link to comment Share on other sites More sharing options...
Johnny Bravo Posted January 21, 2007 Author Report Share Posted January 21, 2007 Lidt arm træning..Seated db. curl:10x16kg10x18kg10x18kg10x18kg10x18kg10x20kg10x20kg10x20kg10x20kg10x20kg10x20kgFrench press:10x40kg10x35kg10x35kg10x35kg10x35kg10x35kg10x35kg10x35kg10x35kg10x35kg10x35kgPull-ups:8xbw8xbwStanding calf raise:20x160lbs16x160lbs14x160lbs Quote Link to comment Share on other sites More sharing options...
Tunen Posted January 21, 2007 Report Share Posted January 21, 2007 Du skal starte på en høj vægt og så trappe den ned i løbet af sættene dood. Fx 2x10@25kg > 2x10@22,5kg > 2x10@20kg > 2x10@17,5kg > 2x10@15kg Quote Link to comment Share on other sites More sharing options...
Johnny Bravo Posted January 21, 2007 Author Report Share Posted January 21, 2007 Du skal starte på en høj vægt og så trappe den ned i løbet af sættene dood. Fx 2x10@25kg > 2x10@22,5kg > 2x10@20kg > 2x10@17,5kg > 2x10@15kgDet ved jeg godt, men da det var længe siden jeg sidst har kørt 10x10, vidste jeg ikke hvad jeg sku' starte med. Der ud over har jeg altid haft forståelsen af, at man kun akkurat lige skal kunne tage 10 reps. De sæt jeg tog med 20kg håndvægte, var jeg godt presset og fik dem også kun lige med nød og næppe. Der er da ingen grund til at tage mindre vægt, hvis jeg stadig kan kør emed 20kg. Quote Link to comment Share on other sites More sharing options...
Tunen Posted January 21, 2007 Report Share Posted January 21, 2007 Det ved jeg godt, men da det var længe siden jeg sidst har kørt 10x10, vidste jeg ikke hvad jeg sku' starte med. Der ud over har jeg altid haft forståelsen af, at man kun akkurat lige skal kunne tage 10 reps. De sæt jeg tog med 20kg håndvægte, var jeg godt presset og fik dem også kun lige med nød og næppe. Der er da ingen grund til at tage mindre vægt, hvis jeg stadig kan kør emed 20kg. Quote Link to comment Share on other sites More sharing options...
Johnny Bravo Posted January 21, 2007 Author Report Share Posted January 21, 2007 Quote Link to comment Share on other sites More sharing options...
Tunen Posted January 21, 2007 Report Share Posted January 21, 2007 Quote Link to comment Share on other sites More sharing options...
Johnny Bravo Posted January 27, 2007 Author Report Share Posted January 27, 2007 Dagens første omgang træning... Super Charge Rocks :4thumbup: Seated db. press - Non-lockout:16x17kg12x27kg8xx32kg8x32kg8x32kgDb. Lateral raise:12x14.5kg12x17kg12x17kgChest supported db. incline rear laterals:12x12kg12x12kg12x12kgLow Incline db. press - Non-lockout:15x32kg10x37kg6x42.5kg5x42.5kg10x37kg10x32kgHigh Incline db. press - Non-lockout:7x32kg7x32kg8x32kgBenchpress:5x90kg6x90kg7x80kg7x80kgCable cross over:3 sets til failure Quote Link to comment Share on other sites More sharing options...
Johnny Bravo Posted January 27, 2007 Author Report Share Posted January 27, 2007 Dagens 2. omgang træning.Døjer med min højre albue. Fik ondt i den fordi jeg begyndte at squatte en del Barbell Curl:12x30kg12x30kg12x35kg12x35kgClosegrip Benchpress:12x60kg8x80kg8x80kg8x80kgPreacher EZ barbell curl:10x30kg5x35kg8x30kg8x25kgSeated overhead db extensions:12x29.5kg7x34.5kg8x34.5kg10x34.5kgCable Curl:8xplate 1210xplate 1110xplate 1110xplate 11Reverse grip one arm pushdown:12xplate 612xplate 612xplate 612xplate 6 Quote Link to comment Share on other sites More sharing options...
Johnny Bravo Posted February 2, 2007 Author Report Share Posted February 2, 2007 Fik denne DVD med posten idag. :4thumbup: Og har fået meldt mig ind i Dansk Helsesport.Frontsquat:8x60kg10x60kg10x60kgLegExtensions:15x30kg15x50kg15x50kgStanding calf raise:Failurex90kgFailurex110kgFailurex110kgBarbell curl:20kg25kg13x30kg12x30kg12x30kg12x30kgSeated overhead db. extensions:14x28kg8x34kg8x34kg8x34kgRope Pushdown:12x20kg12x20kg12x20kgLeg Curl:16x30kg9x50kg8x50kg Quote Link to comment Share on other sites More sharing options...
GoingBiG Posted February 2, 2007 Report Share Posted February 2, 2007 Hvordan vidste posten at du ønskede dig den DVD? Quote Link to comment Share on other sites More sharing options...
Johnny Bravo Posted February 2, 2007 Author Report Share Posted February 2, 2007 Hvordan vidste posten at du ønskede dig den DVD?Hvem ville ikke ønske sig den? Quote Link to comment Share on other sites More sharing options...
Lagoon Posted February 3, 2007 Report Share Posted February 3, 2007 Er den fed? Quote Link to comment Share on other sites More sharing options...
Johnny Bravo Posted February 3, 2007 Author Report Share Posted February 3, 2007 Er den fed?Ja den er er ret fed.Description:2 discs plus Bonus Disc, 414 minutes. ( 6 hours 54 minutes)Released : January, 2007The Battle for the Olympia XI / 20062 Discs plus Bonus DiscDisc One :Ronnie Coleman / Chest, AbsJohnnie Jackson / Shoulders, TricepsBranch Warren / ArmsVictor Martinez / BackBill Wilmore / ChestVince Taylor / Back, CalvesDexter Jackson / Chest3 hours 25 minutesDisc Two :Troy Alves / BackJay Cutler / BackDavid Henry / Biceps, BackToney Freeman / Back, ShouldersDennis James / ChestGunter Schlierkamp / Chest, ShouldersRonny Rockel / Chest, BackDennis Wolf / Back, Triceps3 hours 29 nminutes Quote Link to comment Share on other sites More sharing options...
Johnny Bravo Posted February 3, 2007 Author Report Share Posted February 3, 2007 Dagens træning. Yates Rows:12x40kg10x80kg10x80kg10x100kg10x100kgIncline Benchpress:12x60kg6x80kg6x80kg6x80kgCable Rows:15x60kg10x80kg11x80kg10x80kgNautilus Super Pullover: 12x130kg10x150kg10x150kgChest supported db. incline rear laterals:12x10kg12x10kg12x10kgStiff-arm Pulldown:12x25kg12x25kg12x25kg Quote Link to comment Share on other sites More sharing options...
Johnny Bravo Posted February 4, 2007 Author Report Share Posted February 4, 2007 Db. shoulder press:15x18kg10x28kg10x28kg10x28kgDb. Lateral raise:16x10kg15x10kgDb. press - Non-lockout:15x32kg10x38kg10x38kg10x38kgIncline barbell press - Non-lockout:9x65kg6x75kg6x75kg8x75kg8x75kgMachine Chest Press:12x50kg10x50kg9x50kgDb. Flyes:10x22kg10x22kg10x22kg7x22kgStanding Calf raise:20x90kg15x110kg13x130kg13x130kgFik også trænet lidt mavse. Quote Link to comment Share on other sites More sharing options...
Bogs Posted February 5, 2007 Report Share Posted February 5, 2007 En lille gave i loggen - enjoy! Quote Link to comment Share on other sites More sharing options...
angel Posted February 5, 2007 Report Share Posted February 5, 2007 En lille gave i loggen - enjoy! OMFG!!! Quote Link to comment Share on other sites More sharing options...
Tunen Posted February 5, 2007 Report Share Posted February 5, 2007 OMFG!!!Synes godt nok også det er i overkanten af umomdenhed at tvinge billeder af sig selv ned over manden i hans log Det er ikke dating.dk det her for fanden Quote Link to comment Share on other sites More sharing options...
Till Posted February 5, 2007 Report Share Posted February 5, 2007 Hvad laver du Boten?!? Billeder af din dagsform hører hjemme i din egen log. Heldigvis kan skaden udbedres med lidt good ol' Pamela: Quote Link to comment Share on other sites More sharing options...
Johnny Bravo Posted February 5, 2007 Author Report Share Posted February 5, 2007 Bogs --> Kan se at du har det Tjernobyl look alle er så vilde med. French Tuna--> Hvad skal man stille op med den slags?Till--> Mere af den slags tak :4thumbup: Quote Link to comment Share on other sites More sharing options...
Tunen Posted February 5, 2007 Report Share Posted February 5, 2007 French Tuna--> Hvad skal man stille op med den slags?Skriv en PM til MaxPower, så tager han sig af sagen Quote Link to comment Share on other sites More sharing options...
