The big easy
Thierry Sanchez
Tonsilitis
23-02
1min on/1 min off x10: LCx8, Jx11, LCx8, Jx11,LCx8, Jx11,LCx8, Jx11, LCx11, Jx13
Clean with gloves @2x16kg x6 min (SSC,SC,C)
Thick rope Susp. Rows @BW x16
Bar hang x1min
Hindu push up x12
Off to Russia on Thursday, and competition against the locals on the Sunday. Jerk, snatch and Long cycle @24kg for 7 min each discipline.
Edited by Thierry Sanchez
  • 2 weeks later...
Back in Denmark and feeling half human again
11-03
LC @2x24kg x1min/1min: x9,9,9,10,9,8
1 arm swing @28kg x2min e.s
Black cleans @2x16kg x6 min
BG split squat @17kg x12 e.s
Deficit rev lunge @17kg x12 e.s
Dragon lunge @17kg x12 e.s
Crunch x1 min
BG bag @17kg spins x20+20
Side bends @24kg x15 e.s
Thick rope susp. Rows MDS x26
Hindu push ups x21
Bar hang x1min
Hi, what do you mean commenting on the different techniques?
GS snatch is the technique with the most personal variations, but there are some common points.
Unless you have freaky grip strength that is. I have seen some impressive results by people that looked like they had no clue of what they were doing. Impressive is relative of course, because world class results are something else!
I think you should look at a top athlete of same weight as a starting point. the smoother your drop and relaxed you are when you swing, in general, the higher the results.
As for grip there are pros and cons for each, so it all depends on your strength and weaknesses, level of fatigue and so on. Experimentation is required.
I was wondering if there was some common reasoning behind different hand positions (in the bottom), different ways of taking it down, swing-style(relaxed tip-toe or very rigid).
For example why do some use a thumb downwards bottom grip? Why rigid and flat foot swing-style if a more relaxed way is energy preserving?
Edited by Dr. Durden
Absolutely,there are reasons why we do it one way or the other, or change half way through the set. Apart from fatigue, it depends on the athlete BW in relation to the KB weight, strength, feel, if muscle group are starting to wear out and so on.
I am doing a KB sport workshop on Sunday in Valby ;-)
http://performbetter.dk/workshops/116-kettlebell-specialisten-workshop.html
