Followers 0
l.sefland
Trek 6000 (2012) vs Trek 6300 (2011)
8 posts in this topic
Hej folkens :)
Hvilken cykel bør jeg købe af de to? Prisen er den samme..
Som jeg ser det, har 6300 (2011) bedre forgaffel - er der andre forskelle af betydning?
Takker!
Trek 6300 2011 Specifications
  • Frame: Alpha Black Aluminium with semi-integrated head tube, formed down tube with integrated gusset, formed top tube, monostay seatstay, forged dropouts with rack and fender mounts. Replaceable derailleur hanger
  • Front Fork: Rock Shox Recon Silver with coil spring, rebound, remote lockout alloy steerer and 100mm of travel
  • Rear Shock:
  • Front Derailleur: Shimano Deore
  • Rear Derailleur: Shimano Deore XT
  • Number of Gears:
  • Shifters: Shimano M590 9 Speed
  • Chainset: Shimano M542
  • Chainrings: 44-32-22 Teeth
  • Bottom Bracket:
  • Cassette: SRAM PG-950 11-43 9 Speed
  • Chain:
  • Pedals: Wellgo alloy platform
  • Front Brake: Avid Juicy 3 hydraulic disc brake
  • Rear Brake: Avid Juicy 3 hydraulic disc brake
  • Brake Levers: Avid Juicy 3 levers
  • Handlebars: Bontrager Low Riser 31.8mm with 25mm rise and 9 degree sweep
  • Stem: Bontrager SSR 31.8mm with 10 degree rise
  • Headset: 1-1/8″ threadless semi-integrated with semi-cartridge bearings
  • Grips: Bontrager Race Lite
  • Rims: Bontrager Ranger 32 hole rims
  • Front Hub: Shimano alloy M475 hub
  • Rear Hub: Shimano alloy M475 hub
  • Front Spokes:
  • Rear Spokes:
  • Front Tyre: Bontrager XR3 wire bead 26×2.2″
  • Rear Tyre: Bontrager XR3 wire bead 26×2.2″
  • Tubes:
  • Saddle: Bontrager Evoke 1
  • Seatpost: Bontrager 31.6mm with 20mm offset
  • Seat Binder:
  • Weight:
  • Colour:
  • Extra Features:
Trek 6000 2012 Specifications
Gear: 30
Stel: Alpha Gold aluminium med semi-integreret kronrør, formet skrårør m. integrerede forstærkninger, formet overrør, monostay-baggaffel, smedede gaffelender m. beslag til bagagebærer og skærme, udskifteligt geardropout
Forgaffel: SR Suntour XCR-RL m. fjeder, preload, lockout på styret, 100 mm vandring
Hjul
Nav/Fælge: Shimano M435 alunav; Bontrager AT-850 Disc 32-huller fælge
Dæk: Bontrager XR1, kanttråd, 26x2.2"
Gearsystem
Gearvælgere: Shimano Deore M591, 10-gear
Forgear: Shimano Deore
Baggear: Shimano Deore XT M780 Shadow
Krank: Shimano M552, 42/32/24
Kassette Shimano HG62-10 11-36, 10-gear
Pedaler: Wellgo alu platform
Komponenter
Sadel: Bontrager Evoke 1
Sadelpind: Bontrager SSR, 31.6 mm, 20 mm offset
Styr: Bontrager Low Riser overstørrelse, 31,8 mm, 15 mm højde, 9 grader bukning
Frempind: Bontrager Race Lite, 31.8 mm
Styrfittings: 1-1/8" uden gevind, semi-integrerede semi-lukkede lejer
Bremser: Shimano M446 hydrauliske skivebremser
Signal: Klokke
Reflekser: Ifølge Dansk lov
6000 har 30 gear mod 27 på 6300. Det betyder ikke meget i praksis, men 30 gear er det nyeste shit, så hvis lir-værdi betyder meget for dig, skal du have 30 gear.
6300 har bedre nav på både for- og baghjul. Den kører med Shimano Deore mod Shimano Alivio på 6000.
Når prisen er den samme, ville jeg vælge 6300, først og fremmest på grund af forgaflen og navene.
Personligt kan jeg bedre lide Avids hydrauliske bremser end Shimanos. Men det er en smagssag og andre vil foretrække Shimanos bremser.
Hejsa
Jeg kan ikke svare på baggrund, af de tekniske detaljer. MEN jeg har selv TREK 6300 fra 2011, og der har intet bøvl været med den, på trods af de tæsk jeg har givet den... :bigsmile:
Cool, mange tak :)
En anden ting, er at 6300 er med indvendig lejere (Shimano M542) - hvorimod 6000 har udvendige, som skulle være stivere=bedere? (Shimano M552)
Det havde jeg overset!
Men jeg ville fortsat vælge 6300'eren.
Cool, mange tak :)
Er du helt sikker på at det er indvendig lejer?
http://www.alibabike.com/en/10pedaliers/1847-shimano-m542-mtb-crankset-hollowtech-ii-170-mm-22x32x44-silver.html
Vil iøvrigt lige nævne min kæphest!!!
For en MTB betyder handling "ALT" så tag og få prøvet cyklerne! Stellet er såvidt jeg kan se ens men forskellen på de 2 forgafler kan vise sig at være som nat og dag i forhold til hvordan cyklen opfører sig i terræn, og det er altså en ret dyr del at skifte hvis ikke den passer til dig og din kørestil.
9 eller 10 gear ... tja .. ingen tvivl om at 10 er det nye sort evt kombineret med kun 2 klinger foran, men 9 speed er alt andet lige mere robust og knapt så hysterisk omkring justering. Derudover er det osse billigere at holde kørende hvad angår sliddele.
Hmm.. der ser det ud til at det er udvendige? Anyways - jeg tror jeg har en beslutning om at det bliver 6300 (2011), hvis der passer mig godt når jeg prøver den vel og mærke.
En anden ting (som forhandleren sikkert også kan hjælpe med), er hvilken størrelse jeg bør vælge.
Er lige ca. 186 cm, og 78 kg ? Hvad tænker i, 17.5 eller 18.5 eller 19.5?
Enig med MTBforever - prøv dem af!
Det er umuligt at sige hvilken størrelse cykel du skal have alene ud fra din højde og vægt. Din "fordeling" af højden mellem ben og overkrop har mere at sige end din totale højde.
Min erfaring er, at står man og vakler mellem to størrelser, så skal man tage den mindste.
Followers 0
