jsc
Doktorens log
Farmers
2 x 60 kg x 1 tur
Push-ups
Kv x 5
+20 kg x 5
+40 kg x 5
+50 kg x 8
+40 kg x 8
+30 kg x
Inverse rows (3220)
Kv x 6, 6, 6, 6, 6
K. Rows
Hold + dynamisk
Stakken+16 plader x 4 x 30 sek + 5 reps
Skulder + Triceps disco
Suitcase holds
50 kg x 10/10 sek
70 kg x 10/10 sek
90 kg x 20/20 sek, 10/10 sek
Push-ups (3010)
Kv x 7
Kv+20 kg x 5
Kv+40 kg x 5
Dips
Kv x 5
Kv+10 kg x 5
Kv+20 kg x 10, 10
Kv+15 kg x 10
Kv+10 kg x 8
Kv x 15
N. Parallel pull-ups
(3210)
Kv x 5, 5, 5, 4, 4, 4, 3
Yates deadlifts
40 kg x 5
60 kg x 5
80 kg x 6
Den her har potentiale :)))
Band push-downs
Grønt x 5 sæt
Band face-pull-aparts
Lilla x 3 sæt
Band pull-aparts
Rød x 2 sæt
Edited by jsc
Bencurls
70 x 8
90 x 8
110 x 8
130 x 8
150 x 8
130 x 8, 8
Yates deadlift
40 kg x 6
60 kg x 6
80 kg x 6
90 kg x 6
80 kg x 8
Gad ikke i dag.
Farmers
2 x 60 kg x 1 tur
Inverse rows (3320)
Kv x 6, 6, 6, 6
Push-ups
Kv x 5
Kv+20 kg x 5
Kv+40 kg x 5
Kv+50 kg x 11
K. Rows
15 plader x 20 sek + 5 reps
Stakken x 30 sek + 15 plader x 10 reps
Stakken x 30 sek + 16 plader x 5
Stakken x 30 sek + 17 plader x 6
Maskin laterals
80 x 20, 15, 17, 15
Kabel Overhead ext
Stakken x 15, 12, 10
Suitcase isohold
50 kg x 10 sek
70 kg x 10 sek
90 kg x 10/10, 10/10, 10/10 sek
Push-ups
Kv x 5
Kv+20 kg x 4
Kv+40 kg x 3
Kv+50 kg x 2
Kv+60 kg x 2
Kv+50 kg x 8, 7
Ring Dips
Kv x 16, 14
Parallel Pull-ups (3310)
Smalt greb
Kv x 5, 5, 5
Bredt greb
Kv x 5, 5
Føj, de er slemme :D
Havde kun tid til en kort omgang i dag, så skippede alt det sjove. I første omgang. Kom igen senere:
Bencurls
70 x 7
90 x 7
110 x 6
130 x 5
150 x 4
170 x 3
130 x 15
Dødløft
lidt eksperimenteren
Disko
Edited by jsc
Farmers
2 x 60 kg x 1 tur
Inverse rows
Kv x 6, 6, 6, 5, 5, 5, 5
Push-ups
Kv x 5, 5
Kv+20 kg x 4
Kv+40 kg x 3
Kv+50 kg x 2
Kv+60 kg x 2
Kv+70 kg x 2
Kv+50 kg x 12
Kv+40 kg x 8
Rear delts
Suitcase isohold
50 kg x 10 sek
70 kg x 10 sek
90 kg x 10/10, 10/10 sek
Push-ups
Kv x 5, 5
Kv+20 kg x 4
Kv+40 kg x 3
Dips
Kv x 5
Kv+10 kg x 5
Kv+20 kg x 10, 9, 8
Medium Parallel Pull-ups (3310)
Kv x 5, 5, 5, 5, 5
K. Rows
16+16 x 15 sek + 5 reps
25+16 x 30 sek +5
En l.... dag, så ville primært ikke glide baglæns :P
Bencurls
70 x 10
90 x 8
110 x 8
130 x 8
150 x 8
130 x 10
Trap bar high handles m squatsko
46 kg x 10
66 kg x 10
86 kg x 10
96 kg x 10
106 kg x 10
Det var en start
Farmers
2 x 60 kg x 1 tur
Push-ups
Kv x 5, 5
Kv+20 kg x 4
Kv+40 kg x 3
Kv+60 kg x 2
Kv+75 kg x 1
Kv+50 kg x 8(?!)
Kv+40 kg x 8
Kv+30 kg x 8
Inverse rows (3310)
Kv x 6, 6, 6, 6, 5, 5, 5
Face-pull-aparts
3 sæt m tre sek hold i toppen
Maskin laterals
80 x 13, 12
Overhead ext (3010)
Stakken x 10, 10, 8 + 5 push-downs
Edited by jsc
Suitcase holds
50 kg x 10/10 sek
70 kg x 10/10 sek
90 kg x 10/10 sek, 30/30 sek
Push-ups
Kv x 5, 5
Kv+20 kg x 5
Kv+40 kg x 5
Kv+60 kg x 5
Kv+40 kg x 9, 8
Dips
Kv x 15, 12, 10, 10, 10
Kv x 5, 5, 5, 4, 4, 3, 3, 3
M. Laterals
80 x 20, 15
70 x 15
Suitcase farmers
70 kg x 1/2 tur per hånd
Pull-ups, medium parallel
Kv x 6 x 8 reps
Push-ups
Kv x 5, 5
Kv+20 kg x 5
Kv+40 kg x 5, 12, 9, 7
Kv+20 kg x 13
Inverse rows (3320)
Kv x 6, 6, 6, 6
Dips
Kv x 5
Kv+10 kg x 10
Kv+10 kg x 10 -> Kv x 10
Maskin laterals
60 x 7
100 x 15 -> 85 x 4 -> 70 x 4 -> 55 x 4
Smalle Overhead ext + push-downs
Stakken x 10+10
Suitcase BB holds
50 kg x 10/10 sek
70 kg x 10/10 sek
90 kg x 10/10 sek
100 kg x 10/10 sek
90 kg x 20/20 sek
Push-ups
Kv x 5, 5
Kv+20 kg x 5
Kv+40 kg x 4
Kv+50 kg x 3
Kv+65 kg x 5 det skulle have været 60 kg
Kv+50 kg x 10
Kv+30 kg x 15
Kv+20 kg x 14
Smalle Pull-ups (3110)
Kv x 7, 6, 6, 6, 5 jeg er blevet fed
Inverse rows
Kv x 6, 6, 6
Band pull-aparts
Rød x 3 x 20
Band pull-aparts m isohold
Rød x 16, 15, 15, 13, 13
Band push-downs
Grøn x 5 x 10
Farmers
2 x 60 kg x 1 tur
Push-ups
Kv x 5, 5
Kv+25 kg x 5, 20, 14 (fik ekstra manuel modstand i sidste sæt :P)
Kv+20 kg x 16
Kv+10 kg x 15
Inverse rows (3320)
Kv x 6, 6, 6, 6, 6, 5-6
Awesome pump
Overhead ext
Stakken x 10, 8
Stakken-10 x 10
Stakken -20 x 10
Maskin laterals m bøjede arme
70 kg+manuel modstand i den excentrisk fase a la Meadows
70 x 10, 8
Suitcase carries
Push-ups
Kv x 5, 5
Kv+20 kg x 5
Kv+40 kg x 5
Kv+50 kg x 5
Kv+60 kg x 5
Kv+50 kg x 8
Kv+40 kg x 8
Kv+30 kg x 10
Kv+20 kg x 12
Inverse rows (3310)
Kv x 6, 6, 6, 6, 6, 5, 5, 5
De sad godt, alle reps. Jeg er ikke gået op i vægt el gentagelser i denne, men i starten var det kun de første to til tre sæt, der sad lige i skabet.
Har haft ondt i skuldrene i nogen uger pga træningen. Holdt volumen nede i fag og så kan jeg også bedre se, om det er push-ups, der er problemet i sig selv, eller om fx skuldertræningen medvirker.
Suitcase holds
50 kg x 10/10
70 kg x 10/10
90 kg x 10/10
100 kg x ?/?
90 kg x 20/20
Push-ups
Kv x 5, 5
Kv+20 kg x 5
Kv+40 kg x 5
Prowler
Legede lidt med den. Vi må køre indenfor nu, så den skal i spil igen :)
Pull-ups
Kv x 10, 9, 10, 10
Dips
Kv x 20, 18
Øv ha. Knækkede en tand til aften og var (er) i temmeligt dårligt humør herefter. Min stakkels kone viste ikke hvad hun skulle gøre for at hjælpe, andet end at sende mig op og træne. Så jeg ringede til min makker Tykke Toft og tvang ham med op og prowle.
Turen i centret er nok ca 18 meter
Prowler
Slæde x T/R
Slæde+100 kg x T/R
Slæde+125 kg x T/R
Slæde+150 kg x T/R
Slæde+175 kg x T/R
Slæde+200 kg x T/R
Slæde+225 kg x T/R
Slæde+250 kg x T/R
Slæde+275 kg x T/R
Slæde+300 kg x T/R
1-hånds Swings
12 kg x 10/10
16 kg x 10/10
Get-ups
+12 kg x 1/1
+16 kg x 4/4
Suitcase carries
70 kg x 1 tur pr hånd :P
Push-ups (3110)
Kv x 5, 5
Kv+20 kg x 5
Kv+40 kg x 5, 5, 5, 5
Inverse rows (3320)
Kv x 6, 6, 6, 5, 5
Kb. Get-ups
16 kg x 5 x 1/1
Reverse flyers
30 x 20, 20, 20
Maskin laterals
80 x 12
75 x 12
70 x 12
Band push-downs
Grøn x 3 x 8
Suitcase isohold
50 kg x 10/10 sek
70 kg x 10/10 sek
90 kg x 10/10, 30/30 sek
Push-ups
Kv x 5
Kv+20 kg x 5
Kv+40 kg x 5
Dips
Kv x 5
Kv+10 kg x 5
Kv+20 kg x 10
Kv+15 kg x 10
Kv+10 kg x 10
Kv+5 kg x 10
Kv x 10
Pull-ups
Kv+5 kg x 5
Kv+10 kg x 4
Kv+15 kg x 3
Kv+20 kg x 2
Kv+25 kg x 1
Kv x 12, 10
Tyrkiske get-ups, Kb
16 kg x 1/1, 1/1
20 kg x 1/1, 1/1
16 kg x 1/1
Rear maskin laterals
35 x 18, 15, 15, 12
Maskin laterals
80 x 12
75 x 12
70 x 12
65 x 12
Prowler
+100 kg x 18 m
+200 kg x 18 m
+300 kg x 18 m
+200 kg x 2 x 18 m
Suitcase isohold
50 kg x 10/10 sek
70 kg x 10/10 sek
90 kg x 10/10
Push-ups (3010)
Kv x 5
Kv+20 kg x 5
Kv+40 kg x 8, 7, 6, 6, 5 - 32 reps
Inverted rows (3320)
Kv x 5, 5, 5, 5, 5
Maskin rear flyers
40 x 12, 12, 12
Db. Floor flyers
10 kg x 12
12 kg x 10
Hvis jeg kan få dem her partner assisted, med lidt modstand i toppen, er de tæt på at kunne være en ny ynglingsøvelse for pattøjet :D
Maskin laterals
80 x 12, 12, 12
Da' burn >:D
Overhead ext
Stakken x 10, 10, 8 + pull-overs x 6
Hyperextension (3320)
Kv x 5, 5
Ryggen driller konstant for tiden. Prøver at lave disse igen med fuld kontrol.
Suitcase isohold
50 kg x 10/10 sek
70 kg x 10/10 sek
90 kg x 30/30 sek med stropper pga skadet finger (husarbejde).
Push-ups
Kv x 5
Kv+20 kg x 5
Kv+40 kg x 5
Kv+60 kg x 5
Kv+40 kg x 12
Kv+20 kg x 15 pump & burn
Pull-ups
Kv+10 kg x 5
Kv+15 kg x 4
Kv+20 kg x 3
Kv+25 kg x 2
Kv+30 kg x 1
Kv x 12
Dips (3320)
Kv x 5, 6, 5
Rear laterals
40 x 15, 15, 15, 15 sidste sæt var ikke helt så købt som første, men godt pump :)
Maskin laterals
80 x 12, 12, 12, 12
Straight arm pull-downs
Stakken x 10, 10, 10
Edited by jsc
