Guest Slettet bruger Posted November 5, 2001 Report Share Posted November 5, 2001 Jeg har fundet denne artikel på Flex, og syntes lige i skulle se den, bare lige for at høre hvad jeres mening er om det biceps program, og om det er noget i kan anbefale. Hvilket i nok ikke kan, men hva fanden. 10 Commandments for BicepsEverybody talks about shocking biceps into new growth, but I’ll place odds that 99 out of 100 guys have no idea what it really takes. They parrot popular theories about what constitutes a biceps shock but, no matter how many criteria they list, it won’t be enough. Biceps are the most stubborn bodypart of your physique. Overlook just one of the requirements for a potent shock, and your biceps will lie there as if you never touched them. I’ve built my career on my own biceps research: experimenting with every conceivable training technique and charting and comparing results in an effort to determine, conclusively, what best makes biceps grow. Now I know, but I’m sorry to inform you that it’s not as simple as I’d hoped. I can’t boil it down to anything less than 10 commandments of biceps training. To integrate all of them takes concentration, but if you have the fortitude to bear with me on this, you will ascend to the ranks of those blessed with the best biceps they are capable of attaining. I. VOLUME Almost no one trains with enough sets. Every bodypart must be beaten into senseless submission by set after relentless set, until the last synapse sputters and dies. You’ll never reach that point if you’ve been sold that bill of goods called overtraining. There’s no such thing. Overtraining was invented by wimps to camouflage their inability to train hard. They say, “Because it’s a small muscle group, never do more than nine sets.” To me, that’s not training your biceps. Even with 20 sets, you’re not shocking them, only training them. A legitimate advanced shock workout not only constitutes at least 20 sets, but all of them must be working sets, each one to failure. Don’t count any warm-up sets, regardless of the pump you get. II. SUPERSETSNo exercise technique activates more muscle fibers or pumps more blood into the muscle group than do supersets; since no bodypart is more responsive to this type of concentrated attack than are biceps, I incorporate supersets into every biceps workout. Doing so, however, carries with it a great responsibility: Supersets are a powerful weapon and must not be used indiscriminately. They have their time and place, so heed the following caveats. Do not use supersets for every biceps exercise. Use them for the last full working sets in your workout. Barbell curls should not be used for supersets. As a compound movement, they exact too much energy and do not activate enough fibers to produce the proper superset burn, which is more of a searing than an exploding sensation. Do not superset biceps exercises with each other. The purpose of supersets is to beat a bodypart into submission by destroying the most remote muscle fibers, so begin each set with as much energy reserve as you can muster. You need maximum strength to reach maximum fatigue. The ideal bodypart superset companion I’ve found for preserving biceps energy is triceps. The two are almost equal in strength, yet directly antagonistic, allowing each other plenty of time for recovery while waiting their turn. Using supersets for only the last heavy exercise in my biceps workout provides a transition into my triceps workout. To superset a biceps exercise with a triceps exercise, I try to combine movements of equivalent effort, such as dumbbell preacher curls with one-arm dumbbell extensions or seated alternate dumbbell curls with standing French curls. The only biceps exercises that should be superset are dumbbell curls, preacher curls, seated barbell curls and cable curls. Freestanding barbell curls are too heavy, concentration curls are too light and machines are too isolated to produce a comprehensive burn. III. FAILUREPyramid your sets, but take each one to failure, regardless of the amount of weight you’re using or the reps you’re getting. Only by failure can you ensure that the fundamental principle of universal destruction is being satisfied.IV. LOW REPSCount only those sets for which you reach failure in the six- to eight-rep range. If you do more than eight reps, you are depleting the rest of your body aerobically before your biceps are fully fatigued anaerobically; if you cannot reach six reps, it’s a good indication that your biceps muscles are not being fatigued before ancillary muscles take over the movement. V. DISORDERIf we assume that maximum strength should be allocated to the heaviest exercise, it then follows that every workout should begin with barbell curls. Your body, however, has the ability to adapt to any movement with such subtlety that you will be unaware that ancillary muscles have wrested some of the work from your biceps. By starting with a different exercise each time, those ancillary muscles do not have a chance to adapt and your biceps muscles are forced to do all of the work. If you start, for example, with preacher curls or alternate dumbbell curls instead of barbell curls, you won’t be using as much weight, but the exercise will be more effective, because your biceps will have completed the task before the rest of your body figures out how to help. VI. BICEPS WITH TRICEPSDo not train biceps with any other bodypart except triceps. This advice is similar to the caveat in the second commandment against supersetting biceps exercises with each other, except that here it’s in the context of the entire body. If you train chest with biceps, as many bodybuilders do, your chest workout depletes energy from your biceps workout, so even though you think you’re giving your biceps 100%, they’re getting only 80%. You’ll realize a better shock if you train only one bodypart a day; in this case, arms. The first exercise can then be hit with full power, and you’ll still have enough energy to control your movements on the remainder without cheating. VII. DUMBBELL CURLSWhat qualifies dumbbell curls as ideal for a biceps shock is that they are usually alternated, allowing each arm more recuperation time, not only between reps but between supersets as well. Consequently, dumbbells enable you to handle poundages as heavy or nearly as heavy as with straight sets. Concentration curls are an exception — they’re too isolated and light to be effective as a mass builder or as a superset component for a shock. I employ them solely as a warm-up, but add something extra: a slow supination and peak contraction with every rep, which generates such an intense pump that I often keep it going with five pyramided sets of six to eight, the same as for my other biceps exercises. Effectively, it’s a full-blown working exercise, but I still don’t count it. VIII. PREACHER CURLSAlways include preacher curls of some sort in every biceps workout. A preacher bench provides a combination of power and isolation that cannot be equaled by any other position. With the elbow braced, it’s a power exercise but, since the shoulders are also braced, it’s an isolation exercise. I also use it at two different angles. With the pad at an incline, I can pull back with my body to apply more leverage power. With the pad vertical (in the “spider” position), so that my arms are straight downward, my body ballast is neutralized and I’m forced to use more isolation. Preacher curls should be performed with one arm with a dumbbell, as well as with two arms with a barbell or cambered bar. A dumbbell allows you to supinate or hammer the movement, so you can target specific areas of your biceps. A bar fixes your hands in a position that keeps all of the stress in the belly of the biceps, so you cannot rotate away from the burn as it develops. IX. BARBELL CURLSJust because I advised you earlier to never use barbell curls for supersets doesn’t mean you should never use them at all. Quite the contrary, no biceps mass-building program should be without them, or cambered-bar curls, if you prefer. Every muscle-group workout needs at least one free-weight compound exercise to force all of the muscles in the group to exert maximum strength in a combined effort. In no other way can maximum mass be distributed throughout the bodypart and its ancillaries. Hardly a biceps workout passes that I don’t include five straight sets of barbell curls, the first set for eight reps to failure and the last set for six reps to failure, every one as heavy as possible but not wasted. This is the prototypical size builder, but I never cheat with it. My biceps do all the work. In contrast, I often finish a biceps workout with partial-rep barbell curls at about 70% of my maximum barbell curl poundage. This is a highly unorthodox movement, but it enables me to leave the gym with my biceps feeling as though Cujo got hold of them. To restrict my partial reps to a small arc, I sit on a bench and I make sure never to lower the bar so far that it touches my thighs. I close my eyes, start pumping and don’t stop until I hear my own death rattles. Lee Priest's Training SplitsDay 1: LegsDay 2: BackDay 3: ChestDay 4: ShouldersDay 5: ArmsDay 6: Rest Priest's Biceps Shock WorkoutsBEGINNERConcentration curls: 3 sets, 10-12 repsBarbell curls : 3 sets, 10-12 repsAlternate dumbbell curls: 3 sets, 10-12 repsBarbell preacher curls: 3 sets, 10-12 repsDumbbell preacher curls: 3 sets, 10-12 repsINTERMEDIATEConcentration curls: 4 sets, 6-8 repsCambered-bar curls: 4 sets, 6-8 repsDumbbell preacher curls: 4 sets, 6-8 repsSeated alternate dumbbell curls: 4 sets, 6-8 reps superset with Standing French curls: 4 sets, 6-8 repsSeated cambered-bar curls: 4 sets, 6-8 repsADVANCEDConcentration curls : 5 sets, 6-8 repsStanding cambered-bar curls: 5 sets, 6-8 repsCambered-bar preacher curls: 5 sets, 6-8 repsDumbbell preacher curls: 5 sets, 6-8 repsSeated alternate dumbbell curls: 5 sets, 6-8 reps superset with Standing French curls: 5 sets, 6-8 repsSeated cambered-bar curls: 5 sets, 6-8 reps X. CONTROLTo get the most out of any biceps curl, keep the movement tight during the extension, slowing the pace the lower you go. Do not extend all the way: If you straighten your arm under stress, you increase the risk of snapping your biceps or developing tendinitis in your elbow. Put your mind into your biceps during the contraction, then get a good peaking squeeze at the top. By all means, forget about the poundage you’re using. If it feels good, try more, but if it doesn’t feel good, try progressively lighter weights, until you find one that gives you the best pump. Don’t wait for an injury to teach you to grow up and do it right. Too many bodybuilders worry about others watching the weight they’re using. I’m sure many people have said, “Look, there’s Lee. He acts as if he’s in pain, but the weights he’s using are light.” I couldn’t care less. I’m not there to impress anyone; I’m there to train for myself. Quote Link to comment Share on other sites More sharing options...
BLACKICE Posted November 6, 2001 Report Share Posted November 6, 2001 Well Undskyld mig Infestedass. meeeeeeen Rimelig lang artikkel at poste og så på engelsk. der går lige lidt tid før folk har fået tygget sig igennem den tror jeg.Lidt uoverskuelig.hvad er det for en gut du har fået som Ikon? Quote Link to comment Share on other sites More sharing options...
MichaelEbeltoft Posted November 6, 2001 Report Share Posted November 6, 2001 Jeg vil gætte på at det er Lee Priest du har som ikon, det ligner ihvertfald hans arm.>InfestdassLad være med at hænge dig alt for meget i programmet. Det vigtigste er de forskellige principper, og så kendsbak til de forskellige øvelser. Og sammensæt så det program du mener virker bedst for dig. Du laver simpelthen et program af 3-4 øvelser og går ned i bodycenteret giver dig 140%, og så ved du om det var et godt eller skidt program. Du vil ikke være i tvivl. Det bider, brænder og pumper når du har fundet dit eget program. For det er nemlig meget forskelligt fra person til person hvad der virker bedst. Men det skal da være sagt med det samme at Lee Priest har freaky armne i forhold til hans størrelse, men mon ikke han er genetisk disponeret for det. Han er så omvendt ikke genetisk disponeret for en stor Pectoralis, det er synd for hvis han fik pectoralis med så ville manden være meget pænere bygget. Der findes forresten death pools på nettet over bodybuildere, og Lee Priest er en sikker top 3, for den mand er berygtet for hans brug af AS. Jeg har set interviews og klip hvor han imdrømmer at han bruger AS. Det er lidt usædvanligt at en prof BB gør dette, men det giver ham stor credibility. Quote Link to comment Share on other sites More sharing options...
Ninja Posted December 17, 2001 Report Share Posted December 17, 2001 det ikke lee priests arm på billede der er kevin levrones han bliv nr2 til mr.olympia 2000 Quote Link to comment Share on other sites More sharing options...
MichaelEbeltoft Posted December 19, 2001 Report Share Posted December 19, 2001 At The Maryland Muscle Machine blev nummer 2 til Mr O sidste år er jo ikke vedkommende for hvem der er på billedet. Jeg holder fortsat på at det er Lee. Quote Link to comment Share on other sites More sharing options...
Guest Slettet bruger Posted December 27, 2001 Report Share Posted December 27, 2001 Hæ hæ det er lee det ka jo ses på hans biceps, heldige skidderik!!Men kun man ikke lave programmet om til en One day arm cure med 50 - 100 set x 6-8 til failure spredt ud over en dag, bare en ide. Det vil ihvertfald gøre nas dagen efter. Quote Link to comment Share on other sites More sharing options...
Henning Friis Posted December 27, 2001 Report Share Posted December 27, 2001 Hvad med en gang 1000 rep challenge i squat???Det burde da nok gøre ondt bagefter... Quote Link to comment Share on other sites More sharing options...
MR Posted December 28, 2001 Report Share Posted December 28, 2001 Efter at have læst hele indlægget synes jeg der er nogle ting som jeg ikke helt er enig med Lee Priest om. Han siger at "overtræning" ikke findes Quote Link to comment Share on other sites More sharing options...
MR Posted December 29, 2001 Report Share Posted December 29, 2001 Hele mit indlæg kom ikke med sidst jeg postede det så jeg prøver igen.Efter at have læst hele indlægget synes jeg der er nogle ting som jeg ikke helt er enig med Lee Priest om. Han siger at "overtræning" ikke findes og det er et begreb der blev opfundet af nogle vatnisser som ikke turde træne igennem. Som så mange andre før mig har skrevet i dette forum er overtræning et reelt fysiologisk begreb. jeg tror godt man kan køre Lee Priests program en gang imellem til shocke ens muskler som han siger, men at køre dette program så ofte ville jeg aldrig anbefale nogen. 35 sæt for den avancerede BB`er og 28 sæt for en BB`er på et mellem niveau og oven i købet siger han det alle sæt skal være arbejdene sæt. Opvarmningssæt skal ikke tælles med. I afsnittet om preacher curls, siger han at det er fordelagtigt at køre med en dumbell så man kan supinere sit håndled og ramme et specifikt område af biceps. Det er umuligt f.eks. kun at ramme det korte hoved eller kun ramme det lange hoved. Det er måske rigitgt at man kan aktivere en større procentdel af moter enhederne i biceps ene del, ved at supinere håndleddet. men det er umuligt at "isolere" en bestemt del af en muskel. Ligesom det er umuligt at "isolere" det øvre bryst ved at køre øvelserne på en incline bænk. Jeg mener heller ikke det nødvendigt at køre hver eneste øvelse til total udmattelse for at få musklen til at vokse. En muskel skal stimuleres, ikke udmattes i hvert eneste træningspas. Quote Link to comment Share on other sites More sharing options...
