Dr. Durden Posted November 22, 2009 Author Report Share Posted November 22, 2009 Spændende at se andre arbejde på planchen.. jeg har selv været godt på vej før men er inde i et skadesforløb. Din video vil jeg ikke helt mene er 'adv' tuck planches da du stadig runder lidt i ryggen og jeg ville nok holde mig til stadig at træne tuck planches lidt endnu /Razz fra gymnasticbodiesHvis du ligger mærke til det, så har jeg langt de fleste steder " " rundt om adv ;) For ja, så snart jeg exstender det sidste, så ryger jeg ned... Mener at have tjekket din log en enkelt gang - du var ved straddle, right? Og nu ude efter skulderoperation? Quote Link to comment Share on other sites More sharing options...
Dr. Durden Posted November 22, 2009 Author Report Share Posted November 22, 2009 (edited) Sakset fra Gymnasticbodies:Chris:I think that from zero for a reasonably fit dude it would take 6-12 (coach stated in his article about FL and planche that it should take ~6 as far as I remember, while in another one, by a different author it was said that 9-12) months depending on the body shape, genetics etc. and i mean months of constant, solid training, but I'm no authority here.Cheers,ChrisBraindx: Haha, that would nice if it was that fast.More like 2-3 years on average for planche.Front lever can be done in about a year or so. Depending on height and weight of course. If you're fairly skinny coming in and not over 5'6" it's likely that what I said above is correct. = :4mewantfood: :4mewantfood: Edited November 22, 2009 by Dr. Durden Quote Link to comment Share on other sites More sharing options...
Dr. Durden Posted November 24, 2009 Author Report Share Posted November 24, 2009 (edited) Mandag den 23/11:Fuck! Der trænede en lille buff koreaner i gym'en i dag. Mens jeg knoklede med min lorte planche sprang han lige op og lavede 5 muscle-up på chin-barren. Uden false grip og intet kip! Da han var oppe vendte han sig lige om og lavede 4-5 korean dips (som jeg tidligere i denne blog har knoklet med - de er umulige!) Både MU og dips var easy peacy for ham. Rimelig tuff!Opvarmning:500 meter c2SKulderCirklerFacepulls:1x6 @ 201x6 @ 271x8 @ 342x8 @ 38 (her begyndte min bagskulder/scap at brokke sig lidt til sidst)Biceps, robe curls:1x8 @ 411x8 @ 481x8 @ 551x7 @ 551x4 @ 55Skin the cat:4x3 sekunders hold i back og front lever (tucked)Test af "ab roll out" på en foam rulle:Nogle set med nogle sekunder i en hvis avanceret distance - men der synes lang vej til fuldt abwheel roll out.Tuck PLanche, pb:5x6 sekunder strictPå opfordring af Razz går jeg tilbage til tuck. Jeg går efter så ret ryg som muligt, men skal kunne holde den i seks sekunder. Og så øver jeg mig i at læne mig endnu længere frem.Seated Row:2x6 @ 48 (det kører ikke rigtigt)PPP, wall: (samme taktik som i lørdags)Jeg tager en enkelt med stejl vinkel og så ellers 5 negative med minimumvinkel.HSPU, pb:FAIL, kan stadig ikke selvom jeg ikke har kørt dips inden. Det bliver til et par negative i stedet.Wall runs:1x101x20HSPU: (som jo altså egentligt er HeSPU)1x12x3Tuck planche, pb:5x4-6 sekunder+lidt forskelligt LL og HLL, samt L-sitChins:3x3Cable FLyers:(straight arm!)1x8 @ 17,51x8 @ 22,5 (shit, det rykker i Brachialias (eller hvad fanden den hedder))1x6 @ 22,5+nogle negative med 25Pullups6, 5, 4GHR, situps:2x8GHR, single leg body lever:2x8 (acid!)GHR, reverse hyperextensions:2x5BW triceps extensions:3x6Reverse Pushup:2x81x6Arch:Benløft med 5 kilo på maven: 2x10Alternating hæl skulder: 2x8Dorsal PU:1x10PPP:2x10Wall extensions:2x10Lidt tøsebridge med benløft osv., scap mob og noget stræk. Edited November 24, 2009 by Dr. Durden Quote Link to comment Share on other sites More sharing options...
Dr. Durden Posted November 24, 2009 Author Report Share Posted November 24, 2009 Quote Link to comment Share on other sites More sharing options...
Dr. Durden Posted November 26, 2009 Author Report Share Posted November 26, 2009 (edited) Onsdag den 25/11:Rolig dag, har sovet for lidt de sneste nætter på grund af lorte opgaver så jeg gemmer kræfter til i morgen. Desuden er jeg vist nødt til at forbi min mirakelmager kiropraktor, da min skuldre er begyndt at være noget tunge. Selv i seated row gør ant. delt. ondt.Opvarmning:750 meter c2Dips1x15Tuck planche:5x mixBiceps:3x41Pullups:2x6Softcore: (se sportsfyssen.dk/oevelsesvideoer.htm for at se hvilke video, jeg refererer til)Boldøvelsesvideoer 2 til 6Stabilitetsvideo 14 (med fødderne på en bold)Trillebøre på bold.+nogle ekstra boldøvelser, som i hvert fald ikke er for gravide+One leg full bridgeHer lagde jeg godt mærke til at af de sædvanligt mistænkte fra Yoga lurede lidt fordi jeg bare generelt er fucking sej på en SwissHåndstand:Træning i at holde balancen ...bad, max 7 sekunder Assisted one-arm static pressHLL:(med bagvæg)3x2Tuck PLanche:5x6 sekunderFak, de er tunge i dag!Dynamisk Stjerne:1x8/8Lateral Flexions, GHR:1x8/8 @ 5 (over hovedet)Reverse laterals:(maskine)1x8 @ 271x5 @ 342x8 @ 31Så var der lige plads til onsdagsyoga. Og da jeg herefter sad og strækkede mine stive external hip rotators kommer yogapigen (160+/50 og holdets smidigste!) fra før listende over og fortæller jeg er rigtig sej og om jeg ikke kunne tænke mig at gøre hende sej... Jeg siger ja... to be continued. Edited November 26, 2009 by Dr. Durden Quote Link to comment Share on other sites More sharing options...
Dr. Durden Posted November 27, 2009 Author Report Share Posted November 27, 2009 Torsdag den 26/11:Opvarmning:750 meter c2 (var loaded godt op på kaffe, så før første gang havde jeg den nede under 1:30 i snit)skuldercirklerBent-over Laterals:3x8 @ 6Biceps, robe curls:1x12 @ 341x48 @ 48Supersettet med et par pullupsDragon Flags:4x22x8 (single leg, incline)Tuck Planche:8x6 sekunder+et par chins ind i mellem+et forsøg på HLL Whipers, men der var ikke mere krudt i sækken!!PPP:1x52-3x8Planke med fødderne på Swiss:2x25 sekunder2x10 sekunderBiceps/skulder-balance:(ny øvelse - ved sgu ikke lige hvad jeg skal kalde den!!) Link: http://tinypic.com/usermedia.php?uo=qd8D4Imtpdbcik3I08Ii3g%3D%3DLidt forsøg med den. Den er sgu hård for armene!! Den skal fremover med, så jeg kan få gymnastik kanoner!DB skulderpres:1x8 @ 182x5 @ 201x3 @ 20BOR:1x6 @ 422x8 @ 421x6 @ 42Rack Pulls:Hmm, det kørte ikke sådan fremrangende. Blev til en del ustrukturerede singles.??x1-3 @ 60-92Chins:2x32x5 (assisted)Tucked Dips:2x22x1Cable flyers:(strict straight arm og med forskellige vinkler)1x5 @ 141x? @ 162x? @ 181x? @ 20Tror jeg havde et set mere, men ikke sikker. Det rykkede i hvert fald helt suværent i armene!! Jeg har altid hadet flyes, men nu elsker jeg dem. Straight arm FTW!Wall extensions:2x10 (ohne problemen!)Streeeeetch out! Quote Link to comment Share on other sites More sharing options...
MaxPower Posted November 27, 2009 Report Share Posted November 27, 2009 Torsdag den 26/11:Opvarmning:750 meter c2 (var loaded godt op på kaffe, så før første gang havde jeg den nede under 1:30 i snit)Som i at det blev snittet for de 750m, eller var den bare periodevis under de 1:30 i snit?1:30@500m vil jeg kalde ret hæderligt, så 750m ved samme tempo må være bedre. Quote Link to comment Share on other sites More sharing options...
Dr. Durden Posted November 27, 2009 Author Report Share Posted November 27, 2009 Som i at det blev snittet for de 750m, eller var den bare periodevis under de 1:30 i snit?1:30@500m vil jeg kalde ret hæderligt, så 750m ved samme tempo må være bedre. Ha ha, er du sindsyg. Nej under 1:30 var kun lige et par tag. Jeg plejer aldrig at kunne få den længere ned end 1:32 (det er nogle lidt ældre maskiner og kan let komme til at kure frem og tilbage, hvis man som jeg forsøger ar kompensere for manglende pullstyrke ved at trække endnu hurtigere tilbage med fødderne).Havde de første meter omkring 1:42, kort pause og så de resterende 250 meter nede omkring de 1:32. Quote Link to comment Share on other sites More sharing options...
Gymrazz Posted November 28, 2009 Report Share Posted November 28, 2009 Hvis du ligger mærke til det, så har jeg langt de fleste steder " " rundt om adv ;) For ja, så snart jeg exstender det sidste, så ryger jeg ned... Mener at have tjekket din log en enkelt gang - du var ved straddle, right? Og nu ude efter skulderoperation?ja tænkte nok du havde styr på det, ville bare være sikker ;) og jo var ved straddle og er nu igang med genoptræning efter skulderskade.. Quote Link to comment Share on other sites More sharing options...
Gymrazz Posted November 28, 2009 Report Share Posted November 28, 2009 Biceps/skulder-balance:(ny øvelse - ved sgu ikke lige hvad jeg skal kalde den!!)Link: http://tinypic.com/u...k3I08Ii3g%3D%3DLidt forsøg med den. Den er sgu hård for armene!! Den skal fremover med, så jeg kan få gymnastik kanoner!Planche leans Quote Link to comment Share on other sites More sharing options...
Dr. Durden Posted November 29, 2009 Author Report Share Posted November 29, 2009 (edited) Planche leansTak Lørdag den 28/11:Slapper den lidt, og gainer strength til i morgen!!Pinky-side up lateral shrugs:2x8 @ 51x8 @ 31x8 @ 2TGU:3x3 @ 14Håndstand:BalancetræningScap mob.Foam rollingStreeeetch Edited November 29, 2009 by Dr. Durden Quote Link to comment Share on other sites More sharing options...
Dr. Durden Posted November 30, 2009 Author Report Share Posted November 30, 2009 Søndag den 29/11:Har smukke rene dooms i lower trap - ved ikke om det er fra lateral shrugs eller TGU...Filmede nogle tuck hjemme på kammeret tidligere, men de kørte ikke så godt, face-plant'ede og balancen var der generelt bare ikke... prøver igen tirsdag måske...OPvarmning:600 meter c2SkuldercirklerFacepulls:1x8 @ 201x8 @ 341x8 @ 381x8 @ 34Biceps, robe:1x8 @ 411x2 @ 614x2 @ 681x1 @ 72Chins:3x4 (smal)2x4 (bred)Seated row:1x8 @ 463x8 @ 52Tuck planche:4x6-8 sekunderPPPs:2x101x71x1 (hårdt lårt!)Planche leans:5x5 sekunderStjerne:1/1x10 (dynamisk)1/1x20 sekunder (statisk)Dødløft: (generelt manglende koncentration - og det lider min lænd nu lidt under!)1x6 @ 601x6 @ 703x3 @ 82Weighted Dips:1x6 @ bw1x5 @ 111x3 @ 201x3 @ 252x2 @ 31 Single leg flags, GHR:3x8HSPU:3x3Det var det - træt og kørte dårligt - lav koncentration. Quote Link to comment Share on other sites More sharing options...
Dr. Durden Posted December 2, 2009 Author Report Share Posted December 2, 2009 (edited) Tirsdag den 1/12:Glædelig jul. Og i dag er dagen(i går) egentligt ret stor. Det er nemlig mit et års jubilæum med styrketræning. For et år og 2 dge siden, havde jeg aldrig ligget på en bænk og skubbet til en barbelle. Dengang hed det 40 kilo i bænkpres, 30 cm. overarm. 71 kg. kropsvægt.Mine et års mål, så jeg kan samligne næste år:Overarm: 35Læg: 37Lår: 58Hals: 41Vægt: 77Derudover har jeg kun 21 dage tilbage i Canada - skolen er færdig og jeg mangler blot 4 eksaminer. Men det betyder også, at jeg nok må erkende, jeg ikke når mit mål på 10 sekunders advanced tuck planche - medmindre jeg falder i krudttønden... Men dagens træning:OPvarmning:750 meter c2SKulderCirklerReverse PU:3x8Tuck PLanche, pb:5x8 sekunderBiceps, robe:1x8 @ 415x3 @ 612x1 @ 68Chins:2x3 (smal)5x3 (bred) (spredt lidt ud over træningen)Dragon Flags:3x2 (strict)2x1+nogle single legs+nogle negative med svømmefødderTuck Planche, pb:6x6-8 sekunderSkin the Cat:1x22x1 med 3-4 sekunders hold i henholdsvis tuck lever og adv. back lever.HSPU:1x53x31x42x3Diverse PUsNoget der lignede wall runsCable Flyers: (strict straight arm)3x?? @ 17,5 (skiftende vinkler)Supersettet med...One-arm dead hangs:?/?x 3-4 sekunderTuck planche med indbygget negative tuck dips: (og dips op igen)3x3..supersettet med mere one-arm dead hang.Wall Extensions:2x10Lidt mere mavehalløj og hypers på GHR'en... Edited December 2, 2009 by Dr. Durden Quote Link to comment Share on other sites More sharing options...
Dr. Durden Posted December 3, 2009 Author Report Share Posted December 3, 2009 Onsdag den 2. december: T-minus 20 dage til return!Skuldrene skulle lige åbnes igen fra i går, så dagen stod på:YogaOne-arm dead hangsHåndstandWall runsFoam rollingStrækWall extensions Quote Link to comment Share on other sites More sharing options...
Dr. Durden Posted December 4, 2009 Author Report Share Posted December 4, 2009 (edited) Torsdag den 3/12:Opvarmning:750 meter c2skuldercirklerFacepulls:1x10 @ 202x8 @ 341x8 @ 38Biceps, robe:1x8 @ 413x3 @ 631x4 @ 631x1 @ 70...supersettet med:Chins: (smal)3x4En lille smule tuck lever holdsSeated Row:1x8 @ 482x8 @ 55Dragon Flags:3x2 (somewhat strict)2x8 single legTuck PLanche, pb:3x8 sekunder3x6 sekunderHåndledene er helt døde, men underarmen er glad!PPPs:2x102x51x1Supine Arch leg lift:2/2x10+lidt mere arch workPlanche Leans:8x5 sekunder (hænder bagud)DB skulderpres:3x6 @ 20Hypers, GHR:3x8 @ 111x4 @ 20Weighted dips:1x6 @ 114x4 @ 20+et par tucks merePullups:2x3 @ 10Chins: (wide)5x1 (strict)Reverse laterals:2x10 @ 5lidt mave i maskineAfsluttende var der håndstand, wallruns, Bridge PU, serratus PU, serratus press og scap mob og stræk. Edited December 4, 2009 by Dr. Durden Quote Link to comment Share on other sites More sharing options...
Dr. Durden Posted December 4, 2009 Author Report Share Posted December 4, 2009 Her er forresten lige mine hjemme tucks fra starten af ugen. De gik ad h til!!! Quote Link to comment Share on other sites More sharing options...
Dr. Durden Posted December 10, 2009 Author Report Share Posted December 10, 2009 Onsdag den 9/12:Pyha uha, jeg kom hjem fra hyttetur i går. Tre dage med usund mad, lidt GTG adv. L-sit og alt for meget alkohol! Varmede op til turen i fredags på den lokale: 1 kg deep fried chicken wing og to kander øl. Vægten dikterer 174 pund på tom tarm mod de 169 i fredags... Og jeg har endnu ikke set bare en enkelt canadisk bjørn!!I dag:Opvarmning:En times Hatha500 meter c2skuldercirklerFacepulls:1x8 @ 201x8 @ 341x8 @ 411x8 @ 34Biceps, robe:3x12 @ 41L-chins:(strict fra dead hang med skulderne bag ørene, smal greb OH)5x1Seated Row:1x8 @ 481x8 @ 551x8 @ 55Dragon Flags:3x2 (strict)1x8 single leg2x1 negativ med svømmefødderTuck Planche, pb:6x6 sekunder (virkelig tunge til start, men det blev bedre)Supersettet med lidt MSH (forøvelse til Manna)HS to PPP, wall:3x1 negative - min højre skulder dislocater/popper stadig ret meget i øvelsen, så jeg nøjedes med 3.PPP, wall:3x1HeSPU:(samme som jeg normalt kalder HSPU)1x42-3x3Superset X:3xPLanche leans: 3x5 sekunderPlanke på lille swiss ball: 1x25 sekunderFullBridge PU: 1x8 (droppede pushup delen på det tredje set, da det gjorde avs i den sædvanlige infraspinatus. Kørte i stedet bare fokus på stræk)Tuck Planche:4-5x5-6 sekundersupersettet med flere MSH.Hyperextensions:2x6 med 5 kg i strakte arme over hovedet2x15Reverse Hypers:2x8 med svævende bagdelWeighted dips:1x8 @ 113x6 @ 11Cuban Press:1x6 @ 16Chins, pullups, one-arm dead hang:...i en blandet landhandel Quote Link to comment Share on other sites More sharing options...
Dr. Durden Posted December 10, 2009 Author Report Share Posted December 10, 2009 Tordag den 10/12:Tager til New york om et par timer, så ksulle lige nå en formiddagstræning.Opvarmning:500 meter c2skuldercirklerBiceps, robe:3x12 @ 41Supersettet med:Pullup/chins:1x4 (smal OH)1x3 (parrallel)1x5 (UH)Tucked levers:5x2-3 sekunderSkin the Cat:1x2 plain3x1 med 3 sekunder i front og back leverBOR:4x6 @ 43Reverse PU:2x8Tuck planche:Shiiiiit, de kørte slet ikke - ingen krudt i håndledene :( Havde et par enekelte, men ikke noget vildt. Prøvede nogle flere senere i træningspasset, de kørte lidt bedre.HLL:4x3Hypers:2x10 @ 111x15 Reverse Hypers:2x8Stabruntine 2+med lidt ekstra guf+lidt boldøvelserMen kunne ikke nå hele det sædvanlige softcore programMilitary på maskine:1x8 @ 552x6 @ 55Cable Flyers:2x8 @ 17,52x5 @ 22,5Supersettet medChins:4x3DONE. Nu går turen til new york og GTG PPP+tucks Quote Link to comment Share on other sites More sharing options...
Dr. Durden Posted December 16, 2009 Author Report Share Posted December 16, 2009 Tirsdag den 15/12:Homecomming om 7 dage! Der er sgu også ved at være koldt her i Canada. Kom hjem fra NY i morges efter en nat i bus. Fik ikke rigtigt lavet nogle PU's i NY - og det var måske godt nok - for her til aften lavede jeg mine PT bedste tucks!!! Incredible feel - desværre var der hverken spejle eller kamera, men instruerede en spotter, der sagde jeg var helt straight back. Men han var nu nok ikke så kritisk som mig selv (og Razz )OPvarmning:600 meter c2SkulderCirklerSeated Row:1x8 @ 482x8 @ 55L-chins fra dead hang:5x1Facepulls:1x8 @ 203x8 @ 34Bicep, robe:1x8 @ 413x8 @ 55+et par pullups+micro lidt med HLL og leverTuck PLanches:3x3 sekunder med fokus på straight3x6 sekundersupersettet med lidt MSHDragon Flags:3x2+en masse løstDB SKulderpress:1x6 @ 202x5 @ 20Hypers:1x8 @ 5 i strakte arme1x8 @ 111x12 med curlReverse Hypers:2x10Superset Y:3xPlanche leans: 3x5 sekunder - der kom god "dybde" på i dagPlanke på lille swiss: 30 sekunderPPP: 10 stkLateral Hypers:1/1x10 med strakte arme1/1x6 @ 11 (det er sgu hårdt på en GHR!)Weighted Dips:1x6 @ 114x3 @ 20+lidt l-sits, men lårene var døde efter at have vadet Money-makin' Manhatten tynd.Chins:4x3Pullups:1x4Dorsal PU:1x10Serratus PU:1x10Wall extensions:2x12+scap mob og strækI'm DEAD tired!!! Quote Link to comment Share on other sites More sharing options...
Dr. Durden Posted December 17, 2009 Author Report Share Posted December 17, 2009 Onsdag den 16/12Lidt rekreativt...Opvarmning:1 times Yoga400 meter c2Pullups:3x6Lateral shrugs:2x8 @ 63x8 @ 8TGU:3/3x3 @ 16Wall runs:3x20Lidt ekstra HS og assisted one-arm HSFullBrigde leg lift:2x?Dorsal PU:1x12Wrist PU:(paa knae og med pike )1x10Cuban Press:3x6 @ 15Til slut foam rolling og straek. Og saa staar den paa hjemmelavet deltamassage inden sengetid Quote Link to comment Share on other sites More sharing options...
Dr. Durden Posted December 18, 2009 Author Report Share Posted December 18, 2009 Torsdag den 17/12:3. sidste work out i Canada - kommer til at savne den ret udemærkede gym. Havde en kammerat, som jeg havde lovet at vise nogle ab-øvelser, hvilket lidt gik ud over den sædvanlige rytme/struktur.Opvarmning:800 meter c2SkulderCirklerBor:2x8 @ 431x6 @ 521x8 @ 43+lidt reverse PUBiceps, robe: (fyfan cepsne er trætte - eller også trængte kabeltrækket virkelig til noget olie)1x8 @ 412x6 @ 551x6 @ 48+nogle random pullupsTuck Planche:?x4-6 sekunder +MSH af 4-6 sekunderKørte nogle flere senere i træningspasset, men kom ikke op på ti tror jeg - generelt var jeg lidt tung i dag.En masse mavehalløj:bl.a. flags, side bridge, russian twists og leg liftsHypers:3x10 med 2,5 i hver hånd - Y-positionReverse Hypers:3x6DB skulderpres:3x8 @ 18Dips: (wow, det føltes som om jeg har kørt 20 sæt på bænken!)3x8 +lidt tucks+MSHCable Flyers:(strict straight arm ofc.)3x??+nogle chins Quote Link to comment Share on other sites More sharing options...
Dr. Durden Posted December 19, 2009 Author Report Share Posted December 19, 2009 (edited) Fredag den 18/12:KOrt træning inden hvile weekend, de sidste eksaminer og julegavekøb.OPvarmning:750 meter c2SkuldercirklerarmsvingHåndstand (god til at bløde håndledende op)Dødløft:5x8 @ 60Chins:4x4PPPs:3x12BW Tricep extensions:3x5+lidt reverse PUBiceps, robe:2x10 @ 34+nogle random pullupsTuck planche:3x8 sekunderHeSPU:1x4Reverse laterals:2x6 @ 6scap stab og mobPå mandag sker det - total recall og showdown. Jeg skal filme min adv. tuck planche og fejre sidste træning i Canada!! Edited December 19, 2009 by Dr. Durden Quote Link to comment Share on other sites More sharing options...
Dr. Durden Posted December 22, 2009 Author Report Share Posted December 22, 2009 Mandag 21/12:Sidste dag i Canada. Jeg kommer til at savne gym og alle damernes gode styrketræningskultur. Danske damebagdele og lår kunne virkelig lære noget af Canada.Jeg glemte kameraet, så der blev ikke filmen noget tuck. Men de var okay - ikke helt så gode som i onsdags, men godt nok...Opvarmning:650 meter c2SKuldercirklerEt par HeSPUEt par chin singlesTuck Planche:4x? sekunder (straight back)4x6 sekunderFacepulls:1x8 @ 271x8 @ 341x8 @ 411x8 @ 38Biceps, robe:1x8 @ 413x6 @ 55Seated row: 1x8 @ 482x8 @ 55Dødløft:1x8 @ 604x8 @ 70supersettet med...Chins:4x4Legede med lidt Saxon Bend med vægtstangen.Dips:1x5 @ 112x1 @ 201x1 @ 311x1 @ 361x1 @ 40 - pretty much max!3x4 @ 20Superset Y:3xPlanche Leans: 3x5 sekunderPlanke: 40 sekunderHalf bridge-benløft mm.: 8/8Skin the Cat:3x2 med holds i begge ender. Min advanced back lever er ok ;)HeSPU:?x?blandet sammen med scap stab og mob.GHR:Reverse hypers: 3x6Blandet mavehalløjVi ses i DK. Quote Link to comment Share on other sites More sharing options...
Dr. Durden Posted December 29, 2009 Author Report Share Posted December 29, 2009 Fredag den 25/12:Lidt late opdatering, så desværre lidt dårlig opsætning...Første træning i dk var i FW i horsens (tidligere Equinox) - shit, det er altså noget lort. Fine fine fine lokaler med Gucci skabe og brusere - og en swimmingpool fra Prada og hvad ved jeg - men al udstyret: NOOO. Jeg så i alt 4(!!!) 20 kg-plates! Og "squat racken" var hjemmelavet. De havde nogle fine fine KBs, men dem måtte man selvfølgelig ikke bruge uden personlig træner.Meget lidt tuckMSHHLL på ribbeMini FlagsDødløft4x70FacepullsChest supported rowIncline DB pressL-sit pullupsHeSPUHeSPU, 5 cm. boxBiCeps/robeReverse PUEt par dips+MSHPLanche leansDecline Ab wheel fra knæ på box (ha ha, jeg kunne næsten ikke tage jakke af og på dagen efter)Et par Skin the Cat Quote Link to comment Share on other sites More sharing options...
Dr. Durden Posted December 29, 2009 Author Report Share Posted December 29, 2009 Hjem til ÅrhusMandag den 28/12:En times poweryoga (hårdt for mine små ben) og:HLL på ribbe (er stadig ikke helt oppe at røre med fødderne:()Wide chest supported rowFacepullsWrist flexor "push ups"Seated RowLidt HypersEn smule dragon flags-halløjTuck planche ?x6 sekunderMSHEt par af div. chins/pullupsHeSPU, 5 cm. boxBiceps, robeWall extensionsScap stab+mob med elastikJeg er måske ikke vokset det store de sidste 5 måneder, men jeg har sgu fået opbygget en pæn mobilitet og awareness omkring thorasic-bæltet og low back. Bare sådan en ting som at lave gammeldaws rygbøjninger på gulvet med slappe balder er pludselig blevet piece of cake og jeg kunne i dag lave Namaste(handfladerne samlet som til bøn) på ryggen - never did I do that before og det er ikke engang noget jeg har trænet specielt på.Massage i morgen - det bliver min ryg glad for :) Quote Link to comment Share on other sites More sharing options...
