kaoshjerte Posted August 3, 2009 Report Share Posted August 3, 2009 (edited) Jeg har fundet det her, fra West-side acedemy. Jeg har sakset lidt i det, og tilpasset det til det jeg ville have.Med uvurderlig hjælp fra Don Landau!Jeg er startet på det, men mente at det måske var på tide at komme tilbage hertil, og give det et skud :DAnd here after follows the account of the great battle, of Hole-in-the-Wall:Week 1Day 1 (max effort squat day)Dead lift variation: warm up doing sets of three reps until you feel that you can no longer perform three reps. At this point drop the reps to one and continuing working up to a one rep max.Glute Ham Raises: 3 sets of 10 reps. Stress the eccentric, try to get a four count on they way down.Pull throughs: 3 sets of 8 reps using the small strapPull Down Abs: 5 sets of 10 to 15 repsStraight Leg Raises: 5 sets of 15 repsDay 2 (max effort bench day)Board Press: warm up doing sets of three reps until you feel that you can no longer perform three reps. At this point drop the reps to one and continuing working up to a one rep max.Lying Barbell tricep extensions: 6 sets of 10 repsPush Downs: 3 sets of 10One Arm Press: 3 sets of 15Day 3 (dynamic effort squat day)Box Squats: 10 sets of 2 reps with 50% of 1RM (45 to 60 sec rest between sets)Reverse Hypers: 3 sets of 8 reps using the small strapOne Leg Squats: 4 sets of 10 with each legUnderhand Yates rows: 4 sets of 6 repsBarbell Shrugs: 3 sets of 15 repsDay 4 (dynamic effort bench day)Bench Press: 10 sets of 3 reps with 60% of 1RM; use three different grips; (45 to 60 sec rest between sets)Lying Dumbbell Tricep Extensions: 4 sets of 8 repsDumbbell Side Raises: 3 sets of 10 repsBent Over Dumbbell Side Raises: 3 sets of 10 repWeek 2Day 1 (max effort squat day)Dead lift variation: warm up doing sets of three reps until you feel that you can no longer perform three reps. At this point drop the reps to one and continuing working up to a one rep maxGlute Ham Raises: 3 sets of 8 reps. Stress the eccentric, try to get a four count on they way down.pull throughs : 3 sets of 8 reps using the small strapPull Down Abs: 5 sets of 10 to 15 repsStraight Leg Raises: 3 sets of 20 repsDay 2 (max effort bench day)Board Press: warm up doing sets of three reps until you feel that you can no longer perform three reps. At this point drop the reps to one and continuing working up to a one rep maxLying Barbell Tricep Extensions: 6 sets of 10 repsPush Downs: 3 sets of 10One Arm Press: 3 sets of 15Day 3 (dynamic effort squat day)Box Squats: 10 sets of 2 reps with 54 % of 1RM; (45 to 60 sec rest between sets)pull throughs: 3 sets of 8 reps using the small strapOne Leg Squats: 4 sets of 10 with each legUnderhand Yates row: 4 sets of 6 repsBarbell Shrugs: 3 sets of 15 repsDay 4 (dynamic effort bench day)Bench Press: 10 sets of 3 reps with 60% of 1RM; use three different grips ; (45 to 60 sec rest between sets) Lying Dumbbell Tricep Extensions: 4 sets of 8 repsDumbbell Side Raises: 3 sets of 10 repsBent Over Dumbbell Side Raises: 3 sets of 10 repsWeek 3Day 1 (max effort squat day)Dead lift variation: warm up doing sets of three reps until you feel that you can no longer perform three reps. At this point drop the reps to one and continuing working up to a one rep maxGlute Ham Raises: 3 sets of 8 reps using the small strapPull throughs : 3 sets of 8 reps using the small strapPull Down Abs: 5 sets of 10 to 15 repsStraight Leg Raises: 3 sets of 20 repsDay 2 (max effort bench day)Board Press: warm up doing sets of three reps until you feel that you can no longer perform three reps. At this point drop the reps to one and continuing working up to a one rep maxLying Barbell Tricep Extensions: 6 sets of 10 repsPush Downs: 3 sets of 10One Arm Press: 3 sets of 15Day 3 (dynamic effort squat day)Box Squats: 10 sets of 2 reps with 56 % of 1RM ; (45 to 60 sec rest between sets) Pull throughs: 3 sets of 8 reps using the small strapOne Leg Squats: 4 sets of 10 with each legDumbbell Rows: 4 sets of 6 repsBarbell Shrugs: 3 sets of 15 repsDay 4 (dynamic effort bench day)Bench Press: 10 sets of 3 reps with 60% of 1RM; use three different grips ; (45 to 60 sec rest between sets) Lying Dumbbell Tricep Extensions: 4 sets of 8 repsDumbbell Side Raises: 3 sets of 10 repsBent Over Dumbbell Side Raises: 3 sets of 10 repsWeek 4Day 1 (max effort squat day)Low Box Squat: warm up doing sets of three reps until you feel that you can no longer perform three reps. At this point drop the reps to one and continuing working up to a one rep maxGlute Ham Raise: 5 sets of 5 repsPartial Deadlifts: 3 sets of 20 repsPull throughs 3 sets of 8 reps using the small strapPull Down Abs: 5 sets of 10 to 15 repsDay 2 (max effort bench day)Floor Press: warm up doing sets of three reps until you feel that you can no longer perform three reps. At this point drop the reps to one and continuing working up to a one rep maxClose grip incline press: work up to 2 sets of 3 repsIncline Dumbbell Press: 2 sets of 10Seated dumbbell Cleans: 4 sets of 8Straight Leg Raises: 5 sets of 15Day3 (dynamic effort squat day)Box Squats: 10 sets of 2 reps with 60 % of 1RM ; (45 to 60 sec rest between sets) * after your sets of box squats work up to a heavy double. This is not a maximum attempt so do not miss the attempts.Pull throughs: 5 sets of 8 repsChest supported Rows: 4 sets of 8 repsGlute Ham Raise: 3 sets of 6 repsPull Down Abs: 5 sets of 10 repsDay 4 (dynamic effort bench day)Bench Press: 10 sets of 3 reps with 60% of 1RM; use three different grips ; (45 to 60 sec rest between sets) Close Grip Bench Press: work up to 2 sets of 3One Arm Dumbbell Extensions: 3 sets of 10Front Plate Raises: 3 sets of 10 repsWeek 5Day 1 (max effort squat day)Low Box Squat: warm up doing sets of three reps until you feel that you can no longer perform three reps. At this point drop the reps to one and continuing working up to a one rep maxGlute Ham Raise: 5 sets of 5 repsPartial Deadlifts: 3 sets of 20 repsPull throughs: 3 sets of 8 reps using the small strapPull Down Abs: 5 sets of 10 to 15 repsDay 2 (max effort bench day)Floor Press: warm up doing sets of three reps until you feel that you can no longer perform three reps. At this point drop the reps to one and continuing working up to a one rep maxClose grip incline Triceps press: work up to 2 sets of 3 repsIncline Dumbbell Press: 2 sets of 10Seated Dumbbell Cleans: 4 sets of 8Straight Leg Raises: 5 sets of 15Day 3 (dynamic effort squat day)Box Squats: 10 sets of 2 reps with 50% of 1RM ; (45 to 60 sec rest between sets) Pull throughs: 5 sets of 8 repsChest supported Rows: 4 sets of 8 repsGlute Ham Raise: 3 sets of 6 repsPull Down Abs: 5 sets of 10 repsDay 4 (dynamic effort bench day)Bench Press: 10 sets of 3 reps with 60% of 1RM; use three different grips ; (45 to 60 sec rest between sets) * after your sets of box squats work up to a heavy single. This is not a maximum attempt so do not miss the attempts.Close Grip Bench Press: work up to 2 sets of 3One Arm Dumbbell Extensions: 3 sets of 10Front Plate Raises: 3 sets of 10 repsWeek 6Day 1 (max effort squat day)Low Box Squat: warm up doing sets of three reps until you feel that you can no longer perform three reps. At this point drop the reps to one and continuing working up to a one rep maxGlute Ham Raise: 5 sets of 5 repsPartial Deadlifts: 3 sets of 20 repsPull throughs: 3 sets of 8 reps using the small strapPull Down Abs: 5 sets of 10 to 15 repsDay 2 (max effort bench day)Floor Press: warm up doing sets of three reps until you feel that you can no longer perform three reps. At this point drop the reps to one and continuing working up to a one rep maxClose grip incline triceps press: work up to 2 sets of 3 repsIncline Dumbbell Press: 2 sets of 10Seated dumbbell Cleans: 4 sets of 8Straight Leg Raises: 5 sets of 15Day 3 (dynamic effort squat day)Box Squats: 10 sets of 2 reps with 52 % of 1RM ; (45 to 60 sec rest between sets) Pull throughs: 5 sets of 8 repsChest supported Rows: 4 sets of 8 repsGlute Ham Raise: 3 sets of 6 repsPull Down Abs: 5 sets of 10 repsDay 4 (dynamic effort bench day)Bench Press: 10 sets of 3 reps with 60% of 1RM; use three different grips ; (45 to 60 sec rest between sets) Close Grip Bench Press: work up to 2 sets of 3One Arm Dumbbell Extensions: 3 sets of 10Front Plate Raises: 3 sets of 10 repsWeek 7Day 1 (max effort squat day)Deadlift variation: warm up doing sets of three reps until you feel that you can no longer perform three reps. At this point drop the reps to one and continuing working up to a one rep maxGlute Ham Raise: 5 sets of 5 repsLunges: 4 sets of 10 reps (each leg)Pull throughs: 3 sets of 8 reps using the small strapPull Down Abs: 5 sets of 10 to 15 repsDay 2 (max effort bench day)Ball Press: 3 sets of 20 reps (avg. rest period = 5 min)Seated dumbbell Shoulder Press: 5 sets 10 repsIncline Barbell Tricep Extensions: 5 sets 6 repsface Pulls: 5 sets 15 repsDay 3 (dynamic effort squat day)Box Squats: 10 sets of 2 reps with 54 % of 1RM ; (45 to 60 sec rest between sets) * after your sets of box squats work up to a heavy double. This is not a maximum attempt so do not miss the attempts.Pull through: 4 sets 8 repsPull Downs: 3 sets 8 repsGlute Ham Raise: 4 sets 15 repsDay 4 (dynamic effort bench day)Bench Press: 10 sets of 3 reps with 60% of 1RM; use three different grips ; (45 to 60 sec rest between sets) * after your sets of box squats work up to a heavy single. This is not a maximum attempt so do not miss the attempts.Dumbbell Tricep Extensions: 4 sets of 6 repsReverse Grip Push Downs: 3 sets of 15 repsFront - Side - Rear Delt Combo Raise: 2 sets of 60 reps (20 each raise)Pull Down Abs: 5 sets 10 repsWeek 8Day 1 (max effort squat day)Deadlift variation: warm up doing sets of three reps until you feel that you can no longer perform three reps. At this point drop the reps to one and continuing working up to a one rep maxGlute Ham Raise: 5 sets of 5 repsLunges: 4 sets of 10 reps (each leg)Pull through: 3 sets of 8 reps using the small strapPull Down Abs: 5 sets of 10 to 15 repsDay 2 (max effort bench day)Ball Press: 3 sets of 20 reps (avg. rest period = 5 min)Seated dumbbell Shoulder Press: 5 sets 10 repsIncline Barbell Tricep Extensions: 5 sets 6 repsface Pulls: 5 sets 15 repsDay 3 (dynamic effort squat day)Box Squats: 10 sets of 2 reps with 62 % of 1RM ; (45 to 60 sec rest between sets) Pull throughs: 4 sets 8 repsPull Downs: 3 sets 8 repsGlute Ham Raise: 4 sets 15 repsDay 4 (dynamic effort bench day)Bench Press: 10 sets of 3 reps with 60% of 1RM; use three different grips ; (45 to 60 sec rest between sets) Dumbbell Tricep Extensions: 4 sets of 6 repsReverse Grip Push Downs: 3 sets of 15 repsFront - Side - Rear Delt Combo Raise: 2 sets of 60 reps (20 each raise)Pull Down Abs: 5 sets 10 repsWeek 9Day 1 (max day) near end of weekBox Squat: work up to a 1 rep maxBench Press: work up to a 1 rep maxFeedback ønskes!(Kontruktiv feedback, eller jujigatame!) Edited August 3, 2009 by kaoshjerte Quote Link to comment Share on other sites More sharing options...
kaoshjerte Posted August 5, 2009 Author Report Share Posted August 5, 2009 Der er forbløffende lidt feedback Quote Link to comment Share on other sites More sharing options...
Gudderman Posted August 5, 2009 Report Share Posted August 5, 2009 Der er jo ingen der gider sidde og læse alt det igennem... Quote Link to comment Share on other sites More sharing options...
