Followers 0
Paideia
Dedication => Shredded => SHREDICATION
673 posts in this topic
WORKOUT 25. APRIL 2012 FitnessDK AdelStraße
Question: How do you make a hormone?
Answer: Don't pay her
post-53163-0-21844400-1335371165_thumb.j
Benpres (helt i bund)
15x100.0kg
5x220.0kg
5x220.0kg
5x230.0kg
5x230.0kg
5x240.0kg
Komplementære øvelser:
Pull-ups
4 @ BW w/ wide-grip
4 @ BW w/ wide-grip
4 @ BW w/ wide-grip
4 @ BW w/ std-grip
4 @ BW w/ std-grip
4 @ BW w/ std-grip
3 @ BW w/ narrow-grip
3 chin-ups @ BW w/ narrow-grip - fuck det var virkelig skidt!
Leg-Curls
5x90kg
5x90kg
5x90kg
5x90kg
DB Lunges
5 @ 2x30kg
5 @ 2x30kg
5 @ 2x30kg
5 @ 2x32kg
rimelige wobbly knees på dette tidspunkt
Leg-Extensions
5x80kg
5x85kg
5x90kg
6x90kg
Pinch-Grip Walks
2x20kg plates ca. 20m
Farmer Walks
2x36kg DBs ca. 20m
2x36kg DBs ca. 20m
2x36kg DBs ca. 20m
2x36kg DBs ca. 20m
Calf-extensions
12x230kg
12x230kg
12x230kg
12x230kg
12x230kg
Kommentarer: mødte SibronHP og JesperBro på vej ud af døren. De stod og snakkede om hende receptionisten var en velegnet kandidat til en omgang grillspyd... post-53163-0-92198800-1335372506.jpg
Squatless day, knæene var rimelige wobbly allerede efter benpres så lunges var virkelige bare straf. Var hellere ikke Jack3d eller specielt carbed up, men det spillede. 5 træningspas igen.
Nu vil jeg melde mig til Paleo Challenge. Adios gorditos!
Edited by Paideia
WORKOUT 26. APRIL 2012 FitnessDK AdelStraße
20 push-ups @ BW
Bænkpres:
5x100.0kg
5x117.5kg
5x117.5kg
5x120.0kg
5x120.0kg
6x122.5kg - ok ok, der var en spotter
Ab Side-Twists
2x10 @ BW +10kg
2x10 @ BW +10kg
2x10 @ BW +10kg
2x10 @ BW +10kg
Wide-grip Chest Dips
12 @ BW +10kg
8 @ BW + 20kg
6 @ BW + 30kg
7 @ BW + 30kg
Pull-ups (45 seks pause)
4 @ BW
4 @ BW
4 @ BW
4 @ BW
4 @ BW
4 @ BW
4 @ BW
3 @ BW
Ab Crunch Machine
10x55kg
10x60kg
7x65kg
10x60kg
Cable Flys
15 @ 2x12.5kg
8 @ 2x17.5kg
4 @ 2x20.0kg
Partner Leg Raise/Throw
3x25 reps
Diamond Push-Ups
8 @ BW + 20kg
8 @ BW + 20kg
8 @ BW + 20kg
7 @ BW + 20kg fail!
Kommentarer: Fik en spanier til at spotte mig på bænk, så det var sjovt at fået talt spansk igen. Har jeg ikke få
talt siden min roomie i efteråret og nogle fulde aftener, og det gik sgu godt. Hasta la victoria siempre! 4 træningspas igen.
Kom også i sommeruniform i dag. Quads of thunder!!!
Edited by Paideia
Workout 27. april 2012 @ FitnessDK AdelStraße
Hyper-extensions
15 @ BW
10 @ BW +10kg
10 @ BW +10kg
10 @ BW +10kg
Reverse Leg-Raises
10 @ BW
10 @ BW
10 @ BW
Pull-ups
ingen menergy! Var en quitter
DB Rows
18 @ 2x36kg
12 @ 2x36kg
10 @ 2x36kg
12 @ 2x36kg
DB Curls
5 @ 2x24kg
5 @ 2x24kg
5 @ 2x24kg
Standing Military Press
5x75.0kg
4x75.0kg
5x72.5kg
5x70.0kg
5x70.0kg
20 armstrækkere for at få lidt blod til pecs
Kommentarer: LOL for en crappy dag! Var lige ved at spring opdateringen over fordi det er så ynkeligt. Det var som om kroppen simpelthen NÆGTEDE at løfte noget som helst... kan umuligt kun være fordi jeg var en vildbasse aftenen inden (en kombi af Wessels Kro, crazy mexicans, og ingen søvn)
Edited by Paideia
WORKOUT 28. APRIL 2012 FitnessDK Nørrebro PecHouse
Fuck hvor her stinker af skridt midt på en lørdag eftermiddag. Det hjalp ikke at jeg under bruseren fik lov til at observere verdens største udlændinge barbere måske 20kvm pels. Afløbet må være en rigtig skattekiste...
Squats
15x100.0kg
5x140.0kg
5x140.0kg
5x150.0kg
5x150.0kg
2x160.0kg - kunne nok have fået en til, men turde ikke. Knæene var stadig ret ømme fra i onsdags.
Hammerstrength Leg-Curls
5 @ 2x50kg
5 @ 2x50kg
5 @ 2x50kg
5 @ 2x50kg
DB Lunges
5 @ 2x30kg
4 @ 2x32.5kg
5 @ 2x30kg
5 @ 2x30kg
Kommentarer: Dag 2 med en virkelig sørgelig workout. Mødte Gio, så selvom workout var shiite, så hjalp han på humøret med hans uhelbredelige entusiasme. Knæene er bombed fra benpres i onsdags, så squats var en blandede oplevelse. Mødtes med politcrewet senere og jeg fejrede min sidste BB workout ved at drikke mig æske lam i en eller makedonsk nationaldrink/straf. I dag (søndag) har været en OK dag hvor tømmermændene har virkelig været hårde ved mig...
I morgen tidligt vil jeg opdatere loggen med statisk på de sidste 11 måneders indsats, og resultatet af min 1RM tests indenfor bænk, military press, squats og pull-ups. Vil få mig en carb-meal, masser af wasser, og en sidste omgang kreatin inden. Derefter starter paleohelvedet!
Edited by Paideia
Det ser ret fornuftigt ud med styrkeniveauet!
'tis tomorrow that be the hour of reckoning... er spændt!
Jf. første indlæg i denne log (12. juni 2011).
Tallene svarer til topkarakter på USMC Physical Fitness Test. Armstrækkere har jeg med fordi, selvom de ikke indgår i prøven, så kan du bande på at 100 armstrækkere er normalt for en stor del af de mandlige aspiranter.
Som du dog kan få mig til at fundere, Jaanie!
Både og. Vigtigt at opnå, fordi jeg opfatter dem som én blandt mange definitioner på at være stærk og i god form. Min opfattelse af god form indebærer heldigvis en lav fedtprocent, a la 100m sprinter vis-a-vis maratonløber. Den atletiske side er helt klart den vigtigste, og målene første stop på vejen til et liv i evigt god form (læs: awesomeness). Ikke mindst er målene et løfte til mig selv, som at holde er et mål i sig selv.
Jeg starter med at sige, "jeg vil være i den bedste form, jeg overhovedet kan" men jeg ved nu også, at den sætning er vag og udefineret. Jeg ved hvad jeg vil være, men for at gøre målene håndgribelige og overskuelige, definerer jeg at være gennem gøremål.
At være i god form? Bænk, squatte og dødløft x antal kg, for derefter at løbe y km på z minutter, for derefter at spytte en helvedes masse armstrækkere, mavebøjninger og armhævninger ud. Æstetikken er rart, men for mig har den ingen åndelig værdi. Det er ren forfængelighed, en flygtig fornøjelse. Der er ingen dybere tilfredsstillelse.
Det som jeg får tilfredsstillelse af er, at udvikle mig dagligt i en positiv retning; fysisk, men også psykisk, følelsesmæssigt og, tør jeg sige det? Åndeligt. Ofte går delene hånd i hånd. Når jeg rykker grænser, eller kommer ud af min bekvemthedszone, ikke mindst når jeg bliver slået tilbage og må se mine svagheder og dér, hvor jeg kommer til kort, i øjnene. Netop dér udvikler jeg mig mest, når jeg tager ansvaret for såvel mod- som medgang.
Så ved jeg, at jeg har ingen at takke min egen udvikling for, end mig selv. Såvel ansvaret som valgmuligheden ligger i mine egne hænder.
Fra 1. maj frem til 1. september vil fokus være på at udvikle en dræberkondition, a core of granite, og, næsten endnu vigtigere, mental udholdenhed jfr. ovenstående mål. Jeg regner ikke med, at det bliver en let sag at flytte mine snart 95kg fordelt på 178cm i 16km/t i næsten 19 minutter.
Fra 1. september vil jeg sætte mig nye styrkemål, hvor jeg vil give mig selv 6 mdr. at udrette dem (to har jeg allerede sat: bænke 102,5kg 25 gange, og så komme igen med dødløft). Jeg forventer, at det vil blive min sidste "bulk" sæson. Jeg har ikke ambitioner om at blive stærkere, end en god wide-receiver på min størrelse.
Og, nu hvor vi snakker forfængelighed: Mit første prolbillede (by special request)!
post-53163-0-22830300-1335354803_thumb.j
Fedt svar med meget awsomeness, beklager jeg først får kommenteret på det nu.
Grunden til jeg først får kommenteret på det nu, er fordi jeg egentlig kan genkende det meste af det du skriver, som nogle af de overvejelser jeg selv har gjort mig og ting som jeg arbejder ud fra.
Jeg har stadig ikke fundet på noget klogt at tilføje, men tænkte jeg nok hellere måtte få kommenteret nu du havde udfærdiget mig sådan et fint og langt svar.
Flot dagsform btw. åndelig værdi eller ej :rolleyes:
LIVE UPDATE FROM ADELGADE:
Sidder og går efter 1RM i bænk...
8x50kg
5x80kg
3x100kg
1x110kg
Prøver med 90pct om lidt...
Så var det 1x125kg, går efter 140kg om nogle min...
1x140kg!!!
1x142.5kg!!!!
1x145kg!!!!!!!
147.5kg - fail...
Squats:
8x70kg
5x100kg
3x120kg
1x140kg
1x150kg...
1x170kg....
1x175kg......
1x180kg!!!!!!!!
Pauserne ligger på ca 5 min mellem de tunge reps
5x60kg
1x70kg
1x90kg!!!!!!
95kg... Fail
92.5kg... Fail
11 oh pull-ups @ bw!
DONE!!!
Edited by Paideia
Jaaanie likes this
Rookie-fejl :tongue:
Lav større spring! Ellers udmatter du dig på vejen op til dit max.
LOL
Lyder som en super fed challange du skal i gang med! Glæder mig til at følge med fra sidelinien :-)
Thanks friends! :smile:
Ved ikke om jeg kunne have gjort det bedre med større spring, Spøer... jeg er noob!
Efter sejren tog jeg ned på Hipsterlouises Bro med BioBrosFeldt og kværnede brewskis, mine sidste carbs, mens vi oglede teenage hipster booty.
Statistik lyver ikke, så her kommer nogle facts om indsatsen siden 27. maj 2011, hvor jeg meldte mig ind i FitnessDK efter mere end 1½ års dovenskab.
Træningspas:
I alt 135 træningspas på 48 uger. 42 af disse de sidste 7 uger. Hmmm...
Logbogen:
Mere end 110 ud af 183 indlæg er kommet siden 6. marts.
Startvægt:
84.4kg, fedtprocent: N/A (skyder på ca. 15%)
Slutvægt:
94.4kg, fedtprocent: 21,1 LOLLOLOLOLOLOL!
Startstyrke:
Bænkpres (5x85kg), squats (5x115kg), military press (5x50kg), dødløft (5x130kg), pull-ups (5 @ BW)
Slutstyrke:
Bænkpres (1x145kg), Squats (1x180kg), Dødløft (N/A), Military Press (1x90kg), pull-ups (11 @ BW)
Startmål:
Bænke 140kg, squatte 170kg og dødløfte 200kg. 2 ud af 3... not bad.
Nye mål:
100 armstrækkere og crunches på under 2 minutter. 20 pull-ups. 5KM på 18.45 hurtigst muligt, senest 1. september. Bevar nuværende styrke, bedre dødløft. Mere smidighed. Fedtprocent under 10.
Tilfredshed:
Blandet. God styrke, lidt skæv bulk, og for useriøs i starten.
Konklusion:
Loller over min chubiness. Har taget 10kg på... some of it muscle. Most of it beer.
Goodbye bodybuilding! Heeello crossfit
PS.
Fandt et billede af dagsformen anno 2004. Sådan har jeg set ud da jeg var 17 (BP 1RM var 100kg dengang). Trippy!
Edited by Paideia
Brug noget mere tid på helt lave kg. som opvarmning og for at få teknikken til at spille og lav større hop op mod dit maks. Det er selvfølgeligt svært hvis man ikke har nogen anelse om sit maks, men i bænken skulle du som minimum have droppet 142,5 og form. også 145 kg. Squatten tegner det samme billede.
I dag blev jeg lidt mindre wuss, og lidt mere awesome.
Rugby Træning: Masser af kontakt. Det kom der en masse hudafskrabninger, blodnæse, og ømme muskler ud af. Det var mere eller mindre bare ubehageligt, eftersom det er det første rigtig cardio jeg har lavet i 2 år. Tog dog mig selv i at shirke lidt, og det blev jeg irriteret over. Så straffede mig selv med en omgang Tabata-sprints, som for det meste var ynk. Det synes de andre backs var en god ide, så vi gjorde det en gang til sammen for god ordens skyld.
Kommentar: Første dag af min nye livsstil, hvori carbs kun indgår i det omfang jeg får dem sammen med det pulver jeg købte. Det er lidt crap, da der er 15g carbs/22g prots. Så håber nogen kan anbefale noget prot powder der smager godt og er sukkerfattig. Ellers er jeg pænt kvæstet. Mañana cross-jizz'er jeg.
Det er da rimeligt let at få pulver kun med prots?
Ja da... men måske kender du en der er EKSTRA nice... når lortet skal drikkes med vand. Det jeg har smager herligt, det er bare crap.
Edited by Paideia
Nårh ja ok. Så er jeg out. Men har altid bare dunket pulveret ned, så smagen har været mindre vigtig.
Satser på jeg skal bøffe 6-7 shakes dagligt... det er ok at straffe sig selv lidt, men det behøver ikke være nederen det hele...
Edited by Paideia
Lol det er fan'me meget.
Myproteins prot pulver smager fortræffeligt, men 6-7 gange om dagen bliver nok lidt voldsomt uanset hvad fanden du bruger :laugh:
Paideia likes this
Hvad købte du? Kan slet ikke overskue så mange valgmuligheder. Er ret færdig over de har after-eight smag...
Followers 0
