sas Posted December 11, 2002 Report Share Posted December 11, 2002 følgende er taget fra: linkSecret Training Tip #463The Most Amazing (and Ridiculously Simple) Trick For Stiff-Legged Deadlifts You Will Ever Read In Your Life!Do you have a hard time feeling your hamstrings working when you do stiff-legged deadlifts? You will never EVER have that problem again after you read this tip.The stiff-legged deadlift is one of the best exercises you can do for your hamstrings. The only problem is, it can also be one the hardest exercises to perform properly.For years, I tried to feel my hamstrings working when I did the stiff-legged deadlift. I knew it was the best exercise to work the hip extension function of the hamstrings but I never succeeded in feeling my hams work until I came up with this simple technique.Let me tell you, the very rep of the very first set I used this technique on, I could feel my hamstrings like never before! It was like a revelation. It was also extraordinarily simple. I guarantee if you've never had success with stiff-legged deadlifts, you will definitely have it after applying this technique.The trick? Elevate your toes on weight plates while you do the exercise. That's it! It's very simple but very elegant in the way it addresses the kinesiology and anatomy of the hamstrings. I will explain exactly how to set it up and the mechanisms of why it works so incredibly well.How To Do It:Set two 25-pound weight plates on the ground butted up against each other (one for each foot). They should be right beneath the barbell you will be using for the exercise and placed side-by-side so you can set your feet on both of them.Stand in front of the barbell with your feet half on the plates and half off. The front parts of your feet will be on the plates and your heels will be on the ground. Use the weight plates to brace your feet up so that your toes are up in the air and your feet are flexed up (known as dorsiflexion). At the end of this article you will find a link to a picture of how to set up this exercise.Bend over and grasp the bar at about shoulder width with an overhand grip. Keep your knees locked but slightly bent while doing this exercise and keep a tight arch in your lower back.Look directly forward while you are coming up and going back down. This will help you to keep an arch in your lower back.Squeeze the bar off the ground slowly and deliberately, coming up only until your upper body is slightly above parallel. Any higher and you'll start to lose tension in the hamstrings and throw it on your lower back. The real value of this exercise lies in the stretch at the bottom anyways.Come down slowly, being absolutely sure to keep the arch in your lower back. As you near the bottom, stick your butt out and try to raise your toes as high up as possible. This dramatically intensifies the stretch you put on your hamstrings. Hold that stretch for a moment or two then reverse the direction without bouncing.Repeat this for 5 to 7 reps. At the end of the set, place the barbell down gently then get ready to grab onto something for support. If you've done this technique correctly and intensely, your hamstrings will probably feel like jelly and you might find yourself prone to falling down suddenly (this is not a joke - I can't tell you how many things I've had grab onto to catch myself on after doing a hard set of these)!Why Is This Technique So Effective?The reason this toe-raising technique is so effective for the stiff-legged deadlift comes straight from biomechanics and anatomy.The stiff-legged deadlift exercise places the most tension on the hamstrings at the bottom, stretched position. Therefore, in order to maximize tension on the hamstrings, we must maximize the stretch on the hamstrings at that point.In the standard stiff-legged deadlift, this is normally accomplished by simply bending at the hips. But this is not the greatest anatomical stretch that can be put on the hamstring muscles.As you may or may not know, the muscles of the calves are tied in with the hamstrings. Therefore, placing a stretch on the calves also places more stretch on the hamstrings. This is what the weight plates accomplish - they raise your toes, putting a stretch on the calves, which then puts a greater stretch on your hamstrings.By stretching the hamstrings at both the hip joint and the knee joint (from stretching the calves), you literally force your hamstrings to activate strongly during the stiff-legged deadlift movement. The difference is quite amazing! Try it for just one set and I promise you'll never go back to doing it the standard way ever again!For a photograph of how to set this exercise up, visit:http://www.fitstep.com/Misc/Newsletter-arc...mstring-tip.htm-------------Er der andre der har erfaring/kommentarer til ovenstående trick?Er der andre trick man kan bruge når man stiff-legged deadlifter, for bedre at ramme haserne? Quote Link to comment Share on other sites More sharing options...
Nexus Posted December 11, 2002 Report Share Posted December 11, 2002 Er der andre der har erfaring/kommentarer til ovenstående trick?Er der andre trick man kan bruge når man stiff-legged deadlifter, for bedre at ramme haserne? Needless to say, så skal det prøves - det lyder som et velargumenteret fif han giver der. jeg kommer til tænke på noget andet i den forbindelse - Goodmornings - udført på samme måde......... gotta try Quote Link to comment Share on other sites More sharing options...
Fast legs Posted December 12, 2002 Report Share Posted December 12, 2002 Jeg forsøgte mig lige med "Secret Training Tip #463" i morges - og det virker sku.Den går langt bedre i haserne - hvilket jeg virkelig kan bruge til noget - MANGE tak for tippet. Quote Link to comment Share on other sites More sharing options...
sas Posted December 12, 2002 Author Report Share Posted December 12, 2002 Squeeze the bar off the ground slowly and deliberately, coming up only until your upper body is slightly above parallel. Any higher and you'll start to lose tension in the hamstrings and throw it on your lower back. The real value of this exercise lies in the stretch at the bottom anyways.Undrer mig også en del over hvorfor mange vælger at gå hele vejen op når der "reppes" i stiff-legged deadlift :confused2: Fast legs: jeg har nu brugt tricket i de sidste 3 træningspas, jeg kan også mærke at tricket virkelig tvinger baglåret til at arbejde...når jeg i skrivende stund sidder her og flekser baglåret, kan jeg mærke hvor chokeret musklen er blevet, selvom jeg ikke har brugt højere vægt end hvad jeg ellers ville.SASthe Hammie buster Quote Link to comment Share on other sites More sharing options...
ATJ Posted December 13, 2002 Report Share Posted December 13, 2002 For a photograph of how to set this exercise up, visit:http://www.fitstep.com/Misc/Newsletter-arc...mstring-tip.htm...keep a tight arch in your lower back.Godt nok en "grim" lænd han har på billedet! Quote Link to comment Share on other sites More sharing options...
Fast legs Posted December 13, 2002 Report Share Posted December 13, 2002 SaS: Jeg har ikke lagt mærke til at den rammer baglåret mere, men jeg er også forholdsvis stærk i lårene (for som bag) i forhold til læg og haser. Så tricket var lige hvad jeg manglede, da jeg har haft lidt svært ved at ramme haserne effektivt. Quote Link to comment Share on other sites More sharing options...
