jsc Posted January 12, 2004 Report Share Posted January 12, 2004 Those Crazy ExercisesIn my lifting career, I've trained as a powerlifter, an Olympic weightlifter, and a bodybuilder. Training as a strongman, however, provided its own unique set of challenges. I had to prepare for events that were tough to simulate in the gym. These were "real world" tests of strength and I had to build as much functional strength as possible to tackle them. Even though I used these exercises to prepare for strongman contests, I feel anyone can benefit from them, especially if you're an athlete who must perform in an unpredictable environment, e.g. wrestling, football, etc. Even if your only goal is to look good, I challenge you to throw a few of these exercises into your usual routine for the sake of variety and novelty. Here are a few of the more unusual exercises and a couple of tips:Ab RotationsUse a cable attached to a weight stack at chest height. (Note: you can also use tubing secured to a stationary object.) Stand next to the weight stack and line your shoulders up to it. This puts your face at a right angle to the stack. Grasp the cable handle and step arms length away. With legs shoulder-width apart and knees slightly bent, extend your arms in front of you and rotate your torso. Really use your abdominal muscles to work against the resistance. Work from left to right for a given rep count and then do the same number of reps from right to left, meaning you'll need to face the opposite direction.To give you a better idea of the movement pattern, simply stand with your arms out in front of you and rotate all the way to your left. Now rotate back towards your right. Your hands moving through space will form a semi-circle. You can also do these using only one hand.Alternating Dumbbell Bench PressStart by pressing both dumbbells up. Lower the right one and leave the left on "hold" in the air. Press the right dumbbell back up. Now, lower the left with the right still holding and press the left. This will feel awkward at first, so start out lighter than regular dumbbell benches. You can also do inclines and declines using this same protocol. Alternating Dumbbell Upright RowsThis is done similar to the above. Grab two dumbbells and let them hang in front of you. Pull one up to your shoulder and hold. Pull the other up, hold and lower the first. If you are prone to getting shoulder impingement, avoid this until you strengthen your scapular muscles.Barbell Row VariationsI use three styles for barbell rows. The first is a simple, traditional movement where I get the bar into position and then bend at the waist until I'm parallel to the ground. From here I just use my upper back and arms to pull the bar up. I try not to use any lower body. The second type, which occurs later in my training cycle, is just like the above except that I use my legs and lower back to help drive the weight up. Think of it as a slight cheat, but remember, I have to use all my muscles in competition in a coordinated fashion and this helps me prepare for that. The third type of row is what I'd call a power row. I set up like a clean pull and I then explode off the ground and finish in the top position of a barbell row. This is a very explosive movement and great for helping me to lift competition stones.Clean PullsSet up like a deadlift, except use an overhand grip (instead of a mixed grip) and keep your hips lower. Pull the bar past your knees and at the lower third of the thigh move your knees and hips forward. Extend explosively into a top shrug position. Cheat CurlsWork on using your legs, hips, and lower back to help curl a heavy barbell. This mimics many of the movement patterns in a strongman events. I often use a triceps bar (parallel grip) to simulate the logs used in competition.Clean HoldsAs an early preparatory exercise for Farmer's Walks, I used this to increase my grip strength. Holding something in front of your thighs is harder than when your hands are at your sides, so grab a barbell using a regular grip. Deadlift it from a rack or the floor, lock out, and hold for 60 seconds. Do this in front of a mirror and count how many shades of red your face turns! This is also a great forearm exercise and can help you ditch your lifting straps by strengthening your grip. Explosive Good MorningsUnrack a barbell like you're going to do a high bar back squat. Arch your back and bend forward. You can do these with a close stance or a wide stance. Likewise, you can keep your legs straight or bend your knees. These factors will influence how heavy you can go, so use your head and start out light. Bend forward until parallel with the ground or slightly below. Explode to the starting position.I use these to work my weak links as well, so for me a straight legged, wide stance movement helps quite a bit. I can't handle any heavy weights this way, but remember it's to help me strengthen my weak links so when I lift a 330-pound stone, I have the strength where it counts. Farmer's WalkGrasp a heavy object in each hand and walk — that's it. Since the grip width, implement diameter, and weight vary from competition to competition, I practice with a wide variety of equipment. Heavy dumbbells, however, should work well for you if you've never tried these. I like to walk a 100-foot course and then come back. Early in my training I focused on increasing the weight. My next goal is to work up to 400 pounds in each hand. As I get closer to the competition, I focus on speed for the actual distance. Tips: Start with your wrists flexed. As you lift the weights off the ground, they'll straighten your wrists out. Also, make sure you're balanced before trying to walk fast with the weight.One Arm Rear ReachesUse either tubing or a weight stack and cable setup. Face the base, extend your arm overhead, and pull the tubing or handle behind you. Emphasize your shoulder blade pulling and the arm just going along for the ride. It's a short range of motion if you perform it right. This can be done with one or both arms. One-Legged Anterior ReachesThis is an abdominal movement. Face away from some tubing or a weight stack. Grab the tubing/handle and extend your arms overhead, then balance yourself on one leg. With your arms extended overhead, use your abdominal muscles to flex your trunk forward. Keep your arms in the same plane as your torso and don't allow your shoulders and arms to do all the work. This is great for training the abdominals in a very explosive fashion. After you flex forward, return back to the starting position by using your abs to slow you down. Be careful that you don't come back too fast.Rope Pull UpsThese bad boys not only work your arms and back like normal pull ups, they also help you make rapid gains in grip strength. We do these with thick jute rope you can get at a boating supply store. Push PressesSet up like you're going to do standing barbell presses. Let the bar rest on your clavicles. Bend your knees slightly and extend them explosively while pushing the bar overhead. Use the momentum from your legs to drive the bar to lockout.Step UpsSet up like you're going to back squat. Step up to a platform with your right leg. Step down from the platform with the opposite leg (so your left leg will touch the ground first on the way down). Repeat using the opposite leg (left up, right down). I use all kinds of heights and movement speeds. I generally use a height of about 20 inches, but this can change depending on my specific needs.Wall MarchesThis will get some stares from people in the gym. Walk over to a wall and just start pushing on that sucker like you're trying to push your pick-up out of the mud. If you're on a low carb diet, pretend there's a big carrot cake waiting for you on the other side. I do this for 30 seconds, but every five seconds my training partner yells out and I switch my front and back feet. This really helps the start of the truck push in competition. Wood ChopsSet up in between two pulley stacks like you're going to do cable crossovers. Grab a handle from only one side with both hands. With the arms overhead, move diagonally across your body to the opposite foot. You'll be simulating chopping wood, hence the name. Switch and do the other side after each set. You should feel this in muscles all across your midsection.Other ConsiderationsKeep in mind I used a lot of good old-fashioned strength and mass builders like front and back squats, chin-ups, regular bench presses, and military presses as well as the above exercises. I also used several explosive movements like power cleans, clean and jerks, and snatches. (Since these are very technical lifts and require a lot of explanation, they were beyond the scope of this article.) I also trained specifically for many of the events like the tire flip, the keg run and the truck push and pull by simply going out and doing them. (Damned near killed the neighbor's cat with a 700 pound tire once, too.) All of these are great ways to build up your practical strength and absolutely essential if want to stand a chance in a strongman competition. Quote Link to comment Share on other sites More sharing options...
Guest Slettet bruger Posted January 13, 2004 Report Share Posted January 13, 2004 Har du planer om deltagelse i en stærkmands konkurrence engang??? Quote Link to comment Share on other sites More sharing options...
