Danlindberg Posted August 14, 2006 Report Share Posted August 14, 2006 Jeg overvejer at køre Christian Thibaudeaus Superhero Program. Men er det noget værd? Nogen som evt. har prøvet det?http://www.t-nation.com/findArticle.do?art...06-021-trainingSuperhero Program by Christian ThibaudeauWEEKS 1-4 Monday (Shoulders conjugate/Traps heavy)A. Seated dumbbell press4 x 6-8 repsB1. Upright rowing3 x 10-12 repsB2. Seated incline lateral raise3 x 10-12 repsC. Arnold press3 x 8-10 repsD. Lateral raise1 x 100 reps (take pauses if needed)E. Barbell power shrugs5 x 5 repsTuesday (Quads/Hams/Biceps/Triceps)A1. Back squat1 x 15, 1 x 12, 1 x 8, 1 x 20A2. Romanian deadlift1 x 12, 1 x 10, 1 x 8, 1 x 15B1. Barbell curl3 x 6-8 repsB2. Close-grip decline press3 x 6-8 repsC1. Preacher curl3 x 10-12 repsC2. Decline dumbbell triceps extension3 x 10-12 repsD1. Hammer curl3 x 12-15 repsD2. Cable triceps extension3 x 12-15 repsThursday (Traps conjugate/Shoulders heavy)A. Barbell shrugs4 x 6-8 repsB1. Haney shrugs (behind the back shrugs in the Smith machine)3 x 10-12 repsB2. Upright rowing3 x 10-12 repsC. Standing calf machine shrugs3 x 8-10 repsD. Rear delt machine1 x 100 repsE. Military press5 x 5Saturday (Chest/Back)A1. Incline bench press3 x 6-8 repsA2. Bent over barbell rowing3 x 6-8 repsB1. Flat dumbbell bench press3 x 10-12 repsB2. Lat pulldown3 x 10-12 repsC1. Decline bench press3 x 12-15 repsC2. Seated rowing3 x 12-15 reps* NOTE: Abdominal work is performed after every workout. Alternate between these two:ABS WORKOUT 1A1. Kneeling cable crunch3 x 12-15 repsA2. Machine crunch (use a 505 tempo)3 x 6-8 repsA3. Swiss ball crunch3 x maxABS WORKOUT 2A1. Eagle sit-up3 x maxA2. Roman chair Russian twist3 x 12-15 repsA3. High pulley woodchop3 x 12-15 reps per sideWEEKS 5-8Monday (Upper chest conjugate/Biceps heavy)A. Incline bench press4 x 6-8 repsB1. Low-incline dumbbell press (stop short of lockout)3 x 10-12 repsB2. Incline cable flies3 x 10-12 repsC. Low-pulley crossover3 x 8-10 repsD. Bench press1 x 100 reps (take pauses if needed)E. Barbell curl5 x 5 repsTuesday (Quads/Hams)A1. Back squat1 x 15, 1 x 12, 1 x 8, 1 x 20A2. Romanian deadlift1 x 12, 1 x 10, 1 x 8, 1 x 15B1. Leg press3 x 10-12 repsB2. Gironda leg curl (leg curl with an elevated torso, as in a push-up position)3 x 10-12 repsC. Leg curl1 x 100 repsThursday (Biceps conjugate/Upper chest heavy)A. Barbell curl4 x 6-8 repsB1. Reverse preacher curl3 x 10-12 repsB2. Hammer curl3 x 10-12 repsC. Machine curl 2/1 technique (lift with 2 arms, lower in 5 seconds with 1 arm)3 x 5-6 reps per sideD. Preacher curl1 x 100 repsE. High incline dumbbell press5 x 5Saturday (Back/Triceps)A1. Barbell rowing3 x 6-8 repsA2. Fat-man pull-ups3 x max repsB1. Weighted chins3 x 6-8 repsB2. Lat pulldown3 x 10-12 repsC1. Decline EZ-bar triceps extension5 x 6-8 repsC2. Rope triceps extension5 x 12-15 reps* NOTE: Abs work is still performed after every workout in an alternate fashion.WEEKS 9-12Monday (quadriceps/hamstrings) A. Back squat1 x 10, 1 x 8, 1 x 6, 1 x 8, 1 x 10B1. Leg press3 x 10-12 repsB2. Leg extension3 x 10-12 repsC. Romanian deadlift1 x 10, 1 x 8, 1 x 6, 1 x 8, 1 x 10Tuesday (Shoulders/Back)A1. Upright rowing1 x 10, 1 x 8, 1 x 6, 1 x 8, 1 x 10A2. Seated incline dumbbell lateral raise4 x 12-15 repsB. Cable lateral raise (one arm at a time)3 x 15-20 reps per armC1. Barbell rowing1 x 10, 1 x 8, 1 x 6, 1 x 8, 1 x 10C2. Lat pulldown1 x 10, 1 x 8, 1 x 6, 1 x 8, 1 x 10E. Haney shrugs3 x 12-15 repsThursday (Biceps/Triceps)A1. Preacher curl4 x 8-10 repsA2. Alternate dumbbell curl4 x 10-12 reps per armA3. Reverse barbell curl4 x 12-15 repsB1. Close-grip bench press4 x 8-10 repsB2. Lying barbell triceps extension4 x 10-12 repsB3. Rope triceps extension4 x 12-15 repsSaturday (Chest/Shoulders)A1. Decline dumbbell press3 x 8-10 reps A2. Dips3 x max repsA3. Cable crossover3 x 12-15 repsB1. Seated dumbbell press4 x 8-10 repsB2. Standing lateral raise4 x 10-12 repsB3. Front dumbbell raise4 x 12-15 reps* NOTE: Abs should be worked after every workout (same as two other phases) plus additional resistance free abs work everyday. Quote Link to comment Share on other sites More sharing options...
Danlindberg Posted August 14, 2006 Author Report Share Posted August 14, 2006 (edited) Ved I forresten hvad decline press betyder? Det står ved f.eks. Close-grip decline press.Decline Barbell Bench Press og Close-grip decline press er det den samme øvelse? Edited August 14, 2006 by Danlindberg Quote Link to comment Share on other sites More sharing options...
Onkel Troels Posted August 14, 2006 Report Share Posted August 14, 2006 Ved I forresten hvad decline press betyder? Det står ved f.eks. Close-grip decline press.Decline Barbell Bench Press og Close-grip decline press er det den samme øvelse?Decline er det omvendte at Incline. Altså skrå bænk bare med hovdet nedad. Closegrip betyder....Supriiisse....Smalt greb. Så det er ikke de samme øvelser. Forskellen er grebsbredden på stangen. Quote Link to comment Share on other sites More sharing options...
Danlindberg Posted August 14, 2006 Author Report Share Posted August 14, 2006 (edited) Mange tak!Kan ikke lave den her øvelse "Standing calf machine shrugs" i mit træningscenter da de ikke har den maskine, har I evt. nogen ideer til alternativer eller kan den udføres uden maskine? Edited August 14, 2006 by Danlindberg Quote Link to comment Share on other sites More sharing options...
Eruption Posted August 18, 2006 Report Share Posted August 18, 2006 Mange tak!Kan ikke lave den her øvelse "Standing calf machine shrugs" i mit træningscenter da de ikke har den maskine, har I evt. nogen ideer til alternativer eller kan den udføres uden maskine?Svidt jg kan regne mig frem til, er øvelsen vel en trapz øvelse i en calf raise maskine. Erstat evt. med en anden version af shrugs. Quote Link to comment Share on other sites More sharing options...
Danlindberg Posted August 22, 2006 Author Report Share Posted August 22, 2006 (edited) Tak!Er løbet ind i problemer igen:( Hvordan udfører man denne øvelse?B2. Gironda leg curl (leg curl with an elevated torso, as in a push-up position)3 x 10-12 repsOg evt. en øvelse jeg kan erstate den med?Har også problemer med denne her øvelse.C. Machine curl 2/1 technique (lift with 2 arms, lower in 5 seconds with 1 arm)3 x 5-6 reps per sidePå forhånd tak! Edited August 23, 2006 by Danlindberg Quote Link to comment Share on other sites More sharing options...
Danlindberg Posted August 24, 2006 Author Report Share Posted August 24, 2006 Ingen der ved det?Den her kan jeg hellere ikke finde: (Weighted chins) Har virkelig brug for hjælp!!!:) Quote Link to comment Share on other sites More sharing options...
Lorte_muskel Posted August 24, 2006 Report Share Posted August 24, 2006 weigted chins, er bare almindelige chin-ups med vægt. De andre kan jeg ikke svare dig på. Quote Link to comment Share on other sites More sharing options...
schnipper Posted August 24, 2006 Report Share Posted August 24, 2006 (edited) Tak!Er løbet ind i problemer igen:( Hvordan udfører man denne øvelse?B2. Gironda leg curl (leg curl with an elevated torso, as in a push-up position)3 x 10-12 repsOg evt. en øvelse jeg kan erstate den med?Har også problemer med denne her øvelse.C. Machine curl 2/1 technique (lift with 2 arms, lower in 5 seconds with 1 arm)3 x 5-6 reps per sidePå forhånd tak!Kender ik lige umiddelbart Gironda Leg Curls, men går stærkt ud fra, at det er den her: Lying Leg curl, hvor du hæver overkroppen ved at strække armene ud!!Machine curl 2/1, er præcis hvad der står... curls i biceps maskinen (fx. den her: lever curl, eller den her: Lever Preacher curl), hvor du hæver den med 2 hænder, og sænker med 1 hånd.. så du altså får 10-12 hævinger, med 2 hænder, og 5-6 sænkninger med 1 hånd! Edited August 24, 2006 by schnipper Quote Link to comment Share on other sites More sharing options...
Achilles Posted August 28, 2006 Report Share Posted August 28, 2006 efter min erfaring ved Christian Thibaudeaus hvad han snakker om så du kan roligt følge programmet!Når du alligevel er inde på testosterone siden kan du tjekke hss-100 ud.Hss-1oo et rigtig rigtig godt program!!!alternativt kan du også tjekke waterburys programmer ud, han er gud på jord. Quote Link to comment Share on other sites More sharing options...
ratava Posted August 30, 2006 Report Share Posted August 30, 2006 Men hvad med dine ben - skal de ikke trænes? Quote Link to comment Share on other sites More sharing options...
Viggo Posted August 30, 2006 Report Share Posted August 30, 2006 efter min erfaring ved Christian Thibaudeaus hvad han snakker om så du kan roligt følge programmet!Når du alligevel er inde på testosterone siden kan du tjekke hss-100 ud.Hss-1oo et rigtig rigtig godt program!!!alternativt kan du også tjekke waterburys programmer ud, han er gud på jord.Jeg er selv lige startet på hss-100. Hvad er præcist dine erfaringer med det?Det virker rigtig lækkert indtil videre, jeg har fået en kæmpe appetit og har konstant DOMS :) Quote Link to comment Share on other sites More sharing options...
Achilles Posted August 31, 2006 Report Share Posted August 31, 2006 Trænede noget lig. for 4-5 år siden og voksede voldsomt.Sammensætningen er smart da de langsomme muskel fibre først bliver kørt i sænk til allersidst.Godt program! Quote Link to comment Share on other sites More sharing options...
Danlindberg Posted September 6, 2006 Author Report Share Posted September 6, 2006 Tak for det, prøver at kigge på de andre programmer.Har kørt programmet i et par uger nu og synes rigtigt godt om det.Men der er ikke rigtigt nogle læn øvelser? Det er vel ikke så positivt? Har hørt man kan blive krumrygget hvis man træner maven meget og ikke så meget læn. Quote Link to comment Share on other sites More sharing options...
Danlindberg Posted September 6, 2006 Author Report Share Posted September 6, 2006 Men hvad med dine ben - skal de ikke trænes?Der er da benøvelser? Quote Link to comment Share on other sites More sharing options...
Danlindberg Posted September 11, 2006 Author Report Share Posted September 11, 2006 Hvordan ser den her øvelse ud? Når jeg søger på google får jeg en masse forskellige øvelser.Den øvelse jeg ikke kan finde er: Rear Delt Machine Quote Link to comment Share on other sites More sharing options...
Bash Posted September 12, 2006 Report Share Posted September 12, 2006 Hvad er hans argument for at køre 100 reps? Quote Link to comment Share on other sites More sharing options...
Danlindberg Posted September 12, 2006 Author Report Share Posted September 12, 2006 Ved jeg faktisk ikke, men det er pænt hårdt:) Quote Link to comment Share on other sites More sharing options...
Viggo Posted September 13, 2006 Report Share Posted September 13, 2006 Hvad er hans argument for at køre 100 reps?Hans argument er, at man får "flushed" så at sige, de/den givne muskelgruppe®. Han fremhæver i den sammenhæng vigtigheden af et solidt pre-WO meal. Quote Link to comment Share on other sites More sharing options...
Bash Posted September 13, 2006 Report Share Posted September 13, 2006 Hans argument er, at man får "flushed" så at sige, de/den givne muskelgruppe®. Han fremhæver i den sammenhæng vigtigheden af et solidt pre-WO meal.Flushed... Lyder videnskabeligt.. Quote Link to comment Share on other sites More sharing options...
Achilles Posted September 15, 2006 Report Share Posted September 15, 2006 (edited) Flushing.. der kommer en masse blod til området som så tager en masse næringstoffer med sig.Ved ikke om der er vidskabelig baggrund for det, men når det kommer fra Thibaudeaus så er der en god chance for at der er! Edited September 16, 2006 by Achilles Quote Link to comment Share on other sites More sharing options...
Bash Posted September 16, 2006 Report Share Posted September 16, 2006 Flushing.. der kommer en masse blod til området som så tager en masse næringstoffer med sig.Ved ikke om der er vidskabelig baggrund for det, men når det kommer fra Thibaudeaus så er der en god chance for at der er!Nu er det jo ikke første gang at guru'erne fra t-nation udtaler sig pseudo-videnskabeligt Quote Link to comment Share on other sites More sharing options...
Danlindberg Posted September 19, 2006 Author Report Share Posted September 19, 2006 Ved I om der er for lidt Lower Back i det program?Er det nok bare at træne Dead-lift og dem der nu er? Quote Link to comment Share on other sites More sharing options...
Viggo Posted September 20, 2006 Report Share Posted September 20, 2006 Flushing.. der kommer en masse blod til området som så tager en masse næringstoffer med sig.Ved ikke om der er vidskabelig baggrund for det, men når det kommer fra Thibaudeaus så er der en god chance for at der er!Jeg vil nu ikke stemple alt hvad der kommer ud af CT's mund(fingre), som videnskabeligt og at det fungerer, blot fordi det er CT.Se feks i kommentarerne til hans Chest Specialization program, hvor incognito punker ham lidt for bl.a. at fremlægge egne erfaringer som videnskab.(Dermed ikke sagt at CT's programmer er lort,- de virker sikkert for nogen og han får jo som regel god feedback på dem. Jeg har dog stoppet min hss-100 karriere, da jeg ikke bryder mig om at træne så lav-frekvent.) Quote Link to comment Share on other sites More sharing options...
