The Big Bear Posted April 29, 2008 Report Share Posted April 29, 2008 Træning Mandag d. 21-4Leg Extension :3 x 10 @ 50 kg Leg Curl :3 x 10 @ 30 kgBænkpres :3 x 10 @ 70 kgSeated Row :3 x 10 @ 30 kgDumbbell Curl :3 x 10 @ 8,5 kgTriceps Pushdown :3 x 10 @ 20 kg Quote Link to comment Share on other sites More sharing options...
The Big Bear Posted April 29, 2008 Author Report Share Posted April 29, 2008 Træning onsdag d. 23-4Leg Extension :3 x 10 @ 50 kg Leg Curl :3 x 10 @ 30 kgBænkpres :3 x 10 @ 70 kgSeated Row :3 x 10 @ 30 kgDumbbell Curl :3 x 10 @ 8,5 kgTriceps Pushdown :3 x 10 @ 20 kg Quote Link to comment Share on other sites More sharing options...
The Big Bear Posted April 29, 2008 Author Report Share Posted April 29, 2008 Træning fredag d. 25-4Leg Extension :3 x 10 @ 50 kg Leg Curl :3 x 10 @ 30 kgBænkpres :3 x 10 @ 70 kgSeated Row :3 x 10 @ 30 kgDumbbell Curl :3 x 10 @ 8,5 kgTriceps Pushdown :3 x 10 @ 20 kg Quote Link to comment Share on other sites More sharing options...
The Big Bear Posted April 29, 2008 Author Report Share Posted April 29, 2008 Træning Mandag d. 28-4Leg Extension :3 x 6 @ 75 kg Leg Curl :3 x 6 @ 40 kgBænkpres :3 x 6 @ 100 kgSeated Row :3 x 6 @ 50 kgDumbbell Curl :3 x 6 @ 11 kgTriceps Pushdown :3 x 6 @ 30 kg Quote Link to comment Share on other sites More sharing options...
The Big Bear Posted April 29, 2008 Author Report Share Posted April 29, 2008 Træning Tirsdag d. 29-4Leg Extension :3 x 6 @ 75 kg Leg Curl :3 x 6 @ 40 kgBænkpres :3 x 6 @ 100 kgSeated Row :3 x 6 @ 50 kgDumbbell Curl :3 x 6 @ 11 kgTriceps Pushdown :3 x 6 @ 30 kg Quote Link to comment Share on other sites More sharing options...
The Big Bear Posted April 30, 2008 Author Report Share Posted April 30, 2008 Træning Onsdag d. 30-4Leg Extension :3 x 6 @ 75 kg Leg Curl :3 x 6 @ 40 kgBænkpres :3 x 6 @ 100 kgSeated Row :3 x 6 @ 50 kgDumbbell Curl :3 x 6 @ 11 kgTriceps Pushdown :3 x 6 @ 30 kg Quote Link to comment Share on other sites More sharing options...
The Big Bear Posted May 3, 2008 Author Report Share Posted May 3, 2008 Træning Fredag d. 2-5Leg Extension :3 x 6 @ 75 kg Leg Curl :3 x 6 @ 40 kgBænkpres :3 x 6 @ 100 kgSeated Row :3 x 6 @ 50 kgDumbbell Curl :3 x 6 @ 11 kgTriceps Pushdown :3 x 6 @ 30 kg Quote Link to comment Share on other sites More sharing options...
The Big Bear Posted May 5, 2008 Author Report Share Posted May 5, 2008 Træning Mandag d. 5-5Bænkpres :1 x 3 @ 60 kg 1 x 3 @ 100 kg 1 x 3 @ 120 kg 1 x 3 @ 130 kg 1 x 3 @ 140 kg 1 x 3 @ 150 kg 1 x 3 @ 160 kg Kunne tag flere kg. men der var ingen til at stå bag...... Dumbbell Lateral Raise (skulder) :3 x 10 @ 8,5 kg Triceps Pushdown :3 x 10 @ 37,5 kgGod Træning .... Men skal nok tænke på at ligge træningen når der er folk i centeret...... Quote Link to comment Share on other sites More sharing options...
BLACKICE Posted May 5, 2008 Report Share Posted May 5, 2008 (edited) HejDin log er lidt unik på flere måder.Den melder ikke så meget om alder og trænings erfaring. Men jeg hæfter mig ved at du først har 3 trænings pas med 3 x 10 x 70kg i bænkpres, og så 4 trænings pas med 3 x 6 x 100kg, og så repper 3 gange med 160 på næstfølgende trænings pas.Kombineret med at der ikke er så voldsomt meget vægt på nogle af dine andre løft, der i blandt, rows, laterals, biceps curls , push downs osv, så er det ret unikt med et bænkpres for reps på over 160.Hvordan kører du bænkpres? Er det konventionel, eller er det i smith stativ? Hvor træner du? Hvor gammel er du? Stiller du op i konkurrence osv?Lidt mere info vil det krydre din log lidt. Edited May 5, 2008 by BLACKICE Quote Link to comment Share on other sites More sharing options...
The Big Bear Posted May 5, 2008 Author Report Share Posted May 5, 2008 ------> hej BLACKICE Jeg vil gerne svare på dine spørgsmål......Hvordan kører du bænkpres? ----> I en "ER Equipment Bænk" og ellers nomalt.....Er det konventionel, eller er det i smith stativ?----> Det er Konventionel......Hvor træner du?-----> Jeg træner på Falkevejens motioncenter i viborg.....Hvor gammel er du?-----> Jeg er 34 år.....Stiller du op i konkurrence osv? -----> Jeg har stillet op i styrkeløft.....Hvis du har flere spørgsmål vil jeg gerne svare....The Big Bear Quote Link to comment Share on other sites More sharing options...
The Big Bear Posted May 6, 2008 Author Report Share Posted May 6, 2008 (edited) tirsdag d. 6-5Dødløft fra knæ :3 x 10 @ 60 kgSeated Row :3 x 6 @ 70 kgDumbbell Curl :3 x 6 @ 14,5 kg Edited May 6, 2008 by The Big Bear Quote Link to comment Share on other sites More sharing options...
The Big Bear Posted May 6, 2008 Author Report Share Posted May 6, 2008 Træning tirsdag d. 6-5Bænkpres :1 x 3 @ 60 kg 1 x 3 @ 100 kg 1 x 3 @ 120 kg 1 x 3 @ 130 kg 1 x 3 @ 140 kg 1 x 3 @ 150 kg 1 x 3 @ 160 kg Mange krafter tilbage ..... Quote Link to comment Share on other sites More sharing options...
The Big Bear Posted May 7, 2008 Author Report Share Posted May 7, 2008 Træning Onsdag d. 7-5Bænkpres :1 x 3 @ 60 kg 1 x 3 @ 100 kg 1 x 3 @ 120 kg 1 x 3 @ 130 kg 1 x 3 @ 140 kg 1 x 1 @ 150 kg 1 x 1 @ 160 kg 1 x 1 @ 170 kg1 x 1 @ 180 kgHavde konen med som spotter..... havde rigtig god fart på de 180.... Quote Link to comment Share on other sites More sharing options...
The Big Bear Posted May 9, 2008 Author Report Share Posted May 9, 2008 Træning Fredag d. 9-5Bænkpres :1 x 3 @ 120 kg 1 x 3 @ 130 kg 1 x 3 @ 140 kg 1 x 3 @ 150 kg 1 x 1 @ 160 kg 1 x 1 @ 170 kg1 x 1 @ 180 kg1 x 1 @ 185 kgFransk pres:1 x 6 @ 27,5 kg1 x 6 @ 47,5 kg3 x 6 @ 57,5 kgsuper træning .... masser af fart på bænken Quote Link to comment Share on other sites More sharing options...
The Big Bear Posted May 13, 2008 Author Report Share Posted May 13, 2008 træning tirsdag d. 13-5Bænkpres :1 x 3 @ 120 kg 1 x 3 @ 130 kg 3 x 3 @ 140 kg Triceps Pushdown :3 x 10 @ 37,5 kglet træning efter meget ømme triceps Quote Link to comment Share on other sites More sharing options...
