jsc Posted September 30, 2003 Report Share Posted September 30, 2003 Stairway To Shredded:The Ultimate Kettlebell/Dumbell Ladder Superset For Anaerobic Endurance, Fat Loss, And Personal Challenge by Nick Radonjic, CSTSThis is not a workout for the faint of heart, literally and figuratively. It involves placing a #1-pood or 36-pound kettlebell (if you don't have a kettlebell, use a 35 pound dumbbell instead), a 53-pound kettlebell or 1.5 pood (if you don't have access to one, use a 55-pound dumbbell instead), and 2-pood or 72-pound kettlebell or (70 pound-dumbbell in the alternative) all in a straight line about two feet apart from each another. Then after warming-up, begin as follows: snatch the 35-pound weight three times with the left hand, and then do the same with the opposite hand. Next move to the 55-pound weight and snatch that 3 times with the left hand, and then repeat with the right hand. After that is completed go to the 70-pound weight and do the same. Not done yet! Now go back and repeat everything, but now you'll merely do either kettlebell cleans or dumbbell cleans for sets of three! After everything is said and done, and you're through choking on your lung, you will have rested for 60 seconds and then repeat the superset for 3-5 times, with 60 second rests between sets. What that really translates to is that each "set" will last about 2:00 to 2:15 seconds! Also, with the brief rest interval, you're really pushing. Assuming you do the 5 sets, you will have done 180 reps of volume of kettlebell or dumbbell snatches and cleans in about 15:00, with actual working sets comprising between 10:00 to 11:00 worth of work! This translates into tremendous caloric expenditure, growth hormone release, and metabolic increase. In English, this means LESS BDOY FAT folks! And over time, a lower resting heart rate as well. Also, keep in mind that these are explosive movements which will translate into incorporating the fast twitch muscle fibers that martial artists, police officers, and other anaerobic athletes so rely upon. Do this "gauntlet" three days per week and you'll surely be on the way to losing that unwanted body fat. Good luck and keep training. Nick Radonjic, CSTS, is an experienced martial artist (having studied a wide range of combat disciplines) who has posted a 405 deadlift at a bodyweight of 185. Nick is also a certified coach for Charles Staley's Private Coaching Group. If you'd like to inquire about membership in this select group of training partners, click HERE. Quote Link to comment Share on other sites More sharing options...
MadsSWIM Posted September 30, 2003 Report Share Posted September 30, 2003 Lyder interessant.Ikke ulig den første mand i verden under 1.00 minut i 100 brystsvømning på langbane. Hans styrketræning var baseret på lave vægte og 1. min arbejde.Det lyder dog mere interessant da her kommer nogle flere kg på.Dog vil jeg gerne lige vide hvad en kettelbell er?Og snatch - jeg er med på cleans...Mads :swim: Quote Link to comment Share on other sites More sharing options...
jsc Posted September 30, 2003 Author Report Share Posted September 30, 2003 Kettle-bells er kuglevægte med et håndtag i. Glem dem, du kan alligevel ikke finde nogen. Håndvægte er også nemmere og IMHO bedre at træne med.Snatch er råtræk med en håndvægt. Du står med en håndvægt i den ene hånd med let spredte ben. Så lader du håndvægten køre bagud mellem benene og så trykker du hoften frem og trækker håndvægten op over hovedet. Dine underben skal under hele øvelsen være ca 90 grader til gulvet, og du skal fokusere på at kaste HV op med hoftestødet. Quote Link to comment Share on other sites More sharing options...
Jørgen L Posted October 2, 2003 Report Share Posted October 2, 2003 OK, jeg spørger lige: Hvor langt skal håndvægten op i scatch?Udførslen af cleans? (Kunne ikke finde den med håndvægte på exrx.net) Quote Link to comment Share on other sites More sharing options...
AndersL Posted October 2, 2003 Report Share Posted October 2, 2003 OK, jeg spørger lige: Hvor langt skal håndvægten op i scatch?Udførslen af cleans? (Kunne ikke finde den med håndvægte på exrx.net) I Snatch ( ;) ) skal håndvægten helt op i strakt arm over hovedet.Clean med håndvægt er ligesom med stang, du ender bare med at hvile vægten på skulderen til sidst. Quote Link to comment Share on other sites More sharing options...
Jørgen L Posted October 2, 2003 Report Share Posted October 2, 2003 I Snatch ( ;) ) skal håndvægten helt op i strakt arm over hovedet.Clean med håndvægt er ligesom med stang, du ender bare med at hvile vægten på skulderen til sidst. Ups.. Scat er da vist ikke noget man går og løfter på :lol: Tak for beskrivelsen iøvrigt! Quote Link to comment Share on other sites More sharing options...
jsc Posted October 2, 2003 Author Report Share Posted October 2, 2003 Fandt to artikler takket være Lucas:http://www.bodybuilding.com/fun/mahler8.htmhttp://www.bodybuilding.com/fun/mahler7.htm Quote Link to comment Share on other sites More sharing options...
MadsSWIM Posted October 2, 2003 Report Share Posted October 2, 2003 Hvorfor egentlig ikke bare lave de øvelserne BB og stadig høje rep? Mads :swim: Quote Link to comment Share on other sites More sharing options...
jsc Posted October 2, 2003 Author Report Share Posted October 2, 2003 Hvis du henviser til hvorfor man laver ladders, er det fordi man simpelthen kan lave flere reps på den måde uden at køre til udmattelse. Flere reps=godt, mht udholdenhed og fedtforbrænding og greasing the groove. Det er ikke øvelser jeg personligt forventer at opleve den store massefremgang ved, da de stort sdet ikke har nogen eccentrisk komponent. Quote Link to comment Share on other sites More sharing options...
MadsSWIM Posted October 2, 2003 Report Share Posted October 2, 2003 Mit spørgsmål går egentlig mere på hvorfor lave clean/snatch med dumbells istedet for barbell...Mads :swim: Quote Link to comment Share on other sites More sharing options...
jsc Posted October 2, 2003 Author Report Share Posted October 2, 2003 Når du laver cleans eller snatch med BB skal du generelt ikke gå over tre reps pga kompleksiteten af disse løft. Med håndvægte er der ingen øvre grænse, som her hvor man laver 36 reps per sæt. Quote Link to comment Share on other sites More sharing options...
