Fie C Posted November 27, 2008 Author Report Share Posted November 27, 2008 endnu en dag m cardio.15 min interval på crostraineren.attack. var rigtig hårdt idag der var kommet nye og hårdere sange ind så var super fedt. Quote Link to comment Share on other sites More sharing options...
Fie C Posted November 30, 2008 Author Report Share Posted November 30, 2008 fredag d 27rack pullsopvarmning: 12x20kg+20kg (stangen vejer 20kg912x30+2012x40+20 x28x45+20bent over rows10x20 +20 x29x20+208x20+20benchpress12x12,511x12,5 x29x12,5rear delt12x22,5kg12x27,511x27,59x27,5pull downs15x22,515x32,512x36,5 x25x40,5chin-upsassisted, 36kgx9,8,5,8statiske lounges1) 10kg i hver hånd 20 reps med hver ben2) 10kg i den ene hånd 20 reps med hver ben x3 sæt. uden pauserskulderpress12x10kg x310x11 Quote Link to comment Share on other sites More sharing options...
Jbork Posted November 30, 2008 Report Share Posted November 30, 2008 De rackpulls er da bare for seje! Er stolt! :4thumbup: Har du overvejet at prøve med noget dødløft? Du har så stærke ben, så jeg tror hurtigt det ville blive nogen gode kg du ville kunne bruge! Quote Link to comment Share on other sites More sharing options...
Fie C Posted December 4, 2008 Author Report Share Posted December 4, 2008 mandag d. 1. 1 times body attack Quote Link to comment Share on other sites More sharing options...
Fie C Posted December 4, 2008 Author Report Share Posted December 4, 2008 tirsdag d. 2.rack pullsopvarming; 12x20+20kg12x40+20 x312x40+20 bent over rows11x20+20kg10x20+20kg x29x20+20benpres12x100 x4bænkpres12x12,5kg x310x12,5bænkpres incline12x10kg x4skulderpres12x10kg x4lounges10kg i den ene hånd.25 reps m hver ben x4 sæt med hver bencardio15 min interval på crostrainer, level 7.2000 m roning, 9:30 Quote Link to comment Share on other sites More sharing options...
Fie C Posted December 8, 2008 Author Report Share Posted December 8, 2008 mandag d. 8.var lige nede til en omgang pump idag. er lidt over to måneder siden jeg stoppede m det pjat, så tænkte jeg ville prøve at se.- var helt overrasket over hvor nemt det var, selv om jeg øgede vægten i forhold hvad jeg tog tidligere, var det kun i bryst-tracket jeg for alvor var presset, til gengæld var min puls helt oppe på omk 160 så fik i hvert fald noget konditiontræning ud af det. men var i hvert fald meget sjovt, men kan godt forstå jeg stoppede m det.1. track; Opvarmning: 10kg2. track; Squat: 25kg3. Bænkpres: 12,54. Ryg (kombinere dødløft, bent over row, upright row): 17,5kg5. Triceps (frenchpres, tricepspres, dips): 12,5kg6. Biceps curl: 10kg7. Lounges: 20kg8. skulder (mc raise, skulderpres, militairy press, front raises) 5kg9. mavetræning: 5kg hvor det var muligt10. cooldownvar til attack bagefter, var lige så fedt som det plejer at være. dog var der nogen problemer med udluftningen så der var fucker varmt! øderlægger lidt træningen når man ikke kan gi sig 100% fordi gulvet er glat:nonono: så idag har været en rigtig cardio dag, var rigtig fedt og havde rigtig meget energi efter at have siddet herhjemme de sidste dage m mit projekt, så var rigtig dejligt at komme af m noget energi. :4thumbup: glæder mig helt til at komme ned og træne igen imorgen.. Quote Link to comment Share on other sites More sharing options...
Fie C Posted December 11, 2008 Author Report Share Posted December 11, 2008 (edited) onsdag d. 10.blev lige til en lille omgang hygge-træning. sys lissom jeg havde brug for at bevæge mig lidt, efter at havde siddet en hel dag og skrevet projekt.deadliftopv. 12x20kg+20kg(stang)12x35+20kg x311x35+20kgbent over row - underhåndsgreb16x10+20kg13x10+20kg12x10+20kg x2bænkpress, håndvægte12x12,59x12,58x12,56x12,5benpres12x110kg x4rear delt12x23,5kg x210x23,5 7x23,5pull downs12x30,5kg x4cardio blev ikk til det helt vilde, 40 min powerwalk mens jeg så resten af Danmark/Spanien-kampen.blev til 4,25 km, 40 min, 3% stigning. og i følge maskinen 360kcal, så mon ikk det blev lidt mindre :Drigtig rart lige at få trænet lidt, selvom det ikk var så vildt Edited December 11, 2008 by Fie C Quote Link to comment Share on other sites More sharing options...
Fie C Posted December 11, 2008 Author Report Share Posted December 11, 2008 torsdagvar til attack, var lige så fedt som det plejer. måske lidt hårdere, men det var nok fordi jeg er blevet lidt forkølet Quote Link to comment Share on other sites More sharing options...
Fie C Posted December 15, 2008 Author Report Share Posted December 15, 2008 (edited) mandag d. 15har haft en smule ondt i mine ene ankel de sidste dage, hvilket er noget rigtig lort da jeg har haft en ret alvorlig håndboldskade i den fod. troede egentlig det var forsvundet helt, menhar gjort lidt nade efter attack i torsdag. er heldigvis blevet meget bedre, og ku næsten ikke mærke det da jeg var til attack idag. :4thumbup: men selvom det er blevet bedre, ville jeg alligevel helst passe lidt på m den idag, så har kun trænet overkrop idag for ikk at lægge for meget belastning på foden.bench press løsvægt12x12,5kg x38x12,5incline8x12,5kg x4skulderpress11x10kg9x10kg8x10kg10x10kgbagskulder - cabel tårn4. blok x12 reps (ved ikke hvor mange kg hver blok vejer desværre )5. blok x 12 reps x2sætclose grib benchpress5x10kg +20 kg (stang)7x10kg +20 kg 4x10kg +20 kg sys selv jeg var ret sej der hehe push downs3 drops1) 5.blok x 12, 4.bl.x 12, 3.bl x122) 5.bl x10, 4.bl x8, 3.bl x8fik ikk lavet så meget andet end det og så en omgang mavetræning...var til attack et par timer senere. der blev mixet super meget i dag, var rigtig hårdt og fedt... især fordi man ikk ved helt hvor hårde tracks'ne er, så gir den bare max i dem alle sammen. var simpelthen fantastisk.... glæder mig super meget til release på det nye program på lørdag. blir så fantastisk m noget mere udfordring. imorgen regner jeg med at prøve at lave noget ben ryg og biceps træning, men vil prøve at vælge nogen beøvelser der ikk er alt for hårde for mine ankler, så regner ikk med at der kommer noget squat og lounges. men prøver måske og se hvordan foden tar det... nu må vi se... Edited December 17, 2008 by Fie C Quote Link to comment Share on other sites More sharing options...
Jbork Posted December 16, 2008 Report Share Posted December 16, 2008 mandag d. 15har haft en smule ondt i mine ene ankel de sidste dage, hvilket er noget rigtig lort da jeg har haft en ret alvorlig håndboldskade i den fod. troede egentlig det var forsvundet helt, menhar gjort lidt nade efter attack i torsdag. er heldigvis blevet meget bedre, og ku næsten ikke mærke det da jeg var til attack idag. :4thumbup: men selvom det er blevet bedre, ville jeg alligevel helst passe lidt på m den idag, så har kun trænet overkrop idag for ikk at lægge for meget belastning på foden.bench press løsvægt12x12,5kg x38x12,5incline8x12,5kg x4skulderpress11x10kg9x10kg8x10kg10x10kgbagskulder - cabel tårn4. blok x12 reps (ved ikke hvor mange kg hver blok vejer desværre )5. blok x 12 reps x2sætclose grib benchpress5x10kg +20 kg (stang)7x10kg +20 kg 4x10kg +20 kg sys selv jeg var ret sej der hehe pull downs3 drops1) 5.blok x 12, 4.bl.x 12, 3.bl x122) 5.bl x10, 4.bl x8, 3.bl x8fik ikk lavet så meget andet end det og så en omgang mavetræning...var til attack et par timer senere. der blev mixet super meget i dag, var rigtig hårdt og fedt... især fordi man ikk ved helt hvor hårde tracks'ne er, så gir den bare max i dem alle sammen. var simpelthen fantastisk.... glæder mig super meget til release på det nye program på lørdag. blir så fantastisk m noget mere udfordring. imorgen regner jeg med at prøve at lave noget ben ryg og biceps træning, men vil prøve at vælge nogen beøvelser der ikk er alt for hårde for mine ankler, så regner ikk med at der kommer noget squat og lounges. men prøver måske og se hvordan foden tar det... nu må vi se...Sej close-grip bp igår! Du er stærk! Det var forresten ikke pull-downs vi lavede igår, men push-downs Vi ses om en halv time søde. Quote Link to comment Share on other sites More sharing options...
Fie C Posted December 17, 2008 Author Report Share Posted December 17, 2008 (edited) tirsdagblev til en omgang ryg, ben og biceps træning.. passede dog meget på anklen så blev ikk til det helt vilde ben-halløj..supersæt leg curl; 12x22,5kg x3sæt leg ex; 12x50,5kg x3sætchin-ups excentrisk6reps, 4 reps, 3 reps-var sejt... er så meget federe end ass. chin-ups, føler mig meget stærk når jeg hænger der... hehe dumble rowshøjre; 8x 15kg x3 sætvenstre; 9x15kg x1sæt 8x15kg x2Push downs12x36,5kg x3sætstraight bar curls5x7,5kg +10kg (stangen). sidste rep assisted.8x 5kg +10kg 7x 5kg +10kg det var så det..meget fed træning, og er mega øm idag så må ha virket... var ret imponeret over hvor fede de der excentriske chin-ups var, skal jeg helt sikkert prøve igen her en af dagene. Edited January 7, 2009 by Fie C Quote Link to comment Share on other sites More sharing options...
Fie C Posted December 17, 2008 Author Report Share Posted December 17, 2008 Sej close-grip bp igår! Du er stærk! Det var forresten ikke pull-downs vi lavede igår, men push-downs Vi ses om en halv time søde.true..har rettet det..tak :inlove: Quote Link to comment Share on other sites More sharing options...
Fie C Posted December 20, 2008 Author Report Share Posted December 20, 2008 torsdag d. 18.var lige til attack og det var så det... Quote Link to comment Share on other sites More sharing options...
Fie C Posted December 20, 2008 Author Report Share Posted December 20, 2008 lørdag d. 21der var release på pump og attack idag. så det var jeg til.. var super fedt lige at få lavet lidt.. var godt lige at få lavet lidt, ska lave konfekt og havregrynskugler idag, så mon ikk man kommer til at smage lidt på noget al alt det snask det nye pump program er 1000 gange federe end det sidste, men slår på ingen måde "ordenlig" træning. attack var os super fedt, ligsom det plejer - fik dog ikke helt så meget ud af det endnu da jeg ikk kendte programmet, men tror det blir rigtig godt når man kender det lidt bedre og bare kan fyre den af. Quote Link to comment Share on other sites More sharing options...
Fie C Posted December 28, 2008 Author Report Share Posted December 28, 2008 onsdag d 24event. pump up attackkombination af attack og pump startede med tre attack tracks som opvarmning. bagefter fire pump tracks; squat, ryg, lounges, skulder. til sidst fire attack tracks så pulsen kom helt op.super fedt, især pga min puls var virkelig høj under pump-trackene så tror jeg fik rigtig meget ud af det konditionsmæssigt.dog fik jeglavet et mindre vrid i mit knæ under den sidste del af attack, så besluttede mig for at passe lidt på det, og ikk ta ned at træne imorgen. Quote Link to comment Share on other sites More sharing options...
Fie C Posted December 28, 2008 Author Report Share Posted December 28, 2008 fredag d 26rent cardio30min løb. 5,25 km (ink opvarmning).2000m roning (9.30 min)15 min interval med crosstrainer - level 7mavetræningudstrækning/cooldownvar rigtig dejligt lige at få lave noget, godt for ens dårlige samvittighed havde heldigvis ingen problemer med knæet idag, så er klar til at træne som jeg plejer igen. Quote Link to comment Share on other sites More sharing options...
Fie C Posted December 29, 2008 Author Report Share Posted December 29, 2008 mandag d 29DB Benchpress 10x 12,5kg10x 12,510x 12,510x 12,5Incline DB Benchpress 10x 10kg 10x 10kg 10x 10kg 10x 10kg Cable Crossover 10x2" 10x2"10x2"10x2"- en hel ny øvelse jeg ikk har prøvet før. var overraskende fed faktisk. fik ikk så mange kg/blokke, tror jeg skal have nogen flere kg på når jeg har fået lidt bedre styr på min teknik Seated DB Shoulderpress 10x 10kg 8x 10kg5x 10kg7x 10kgLateral Raises 10x6kg10x6kg10x6kg10x6kgFace Pulls 10x4" 10x5"10x5"10x5"nåede ikk andet da jeg skulle op til attack.. var rigtig neder har spist noget jeg ik kan tåle så havde simpelthen så megeet kvalme og ondt i maven, så gik efter første halvdel.idag var os første gang jeg trænede m pulsur.. fuck det for fedt. er virkelig bare motiverende. især ved attack. min puls var oppe på 90% af max og jeg forbrændte 400 kcal på 30 min til attack, sys det vsr ret imponerende, og 180 kcal under styrketræningen. var super fedt. er ligesom om det bliver meget sjovere at træne når man kan sidde og tjekke sin puls og sin forbrændingen Quote Link to comment Share on other sites More sharing options...
Fie C Posted January 4, 2009 Author Report Share Posted January 4, 2009 (edited) fredag d. 2.rack pulls12x35kg12x40kg12x45kg10x47,5kg - det højeste jeg nogensinde har taget. lånte os nogen straps, hjalp virkelig meget. har ret svært ved at holde grebet, så mister tit et par reps pga det. ska helt sikkert ha nogen strabschin ups - negative4,3,5DB rows10x15kg9x15kg10x15kg10x15kgpull downs10x36,5kg9x40kg12x36,5kg10x36,5kgfront pulls10x4"12x4"12x4"11x4"straight bar curls5x10kg5x7,5kg8x5kgcablecurls10x1"5x1" +ekstra blok10x1"10x1"kalorieforbrænding; 382 kcal. Edited January 4, 2009 by Fie C Quote Link to comment Share on other sites More sharing options...
Fie C Posted January 4, 2009 Author Report Share Posted January 4, 2009 lørdag d. 3.var til combat i dag. var super fedt og super hårdt idag, og forbrændte overraskende meget.forbrændte 693kcal - hvilket jo er pænt meget på 1 times træning.min puls var også overraskende høj - gennemsnitpulsen var 162 (ca 80% af max), mens den som det højeste var oppe på 188 - altså 93% af max. er for vildt at min puls kom så højt op! Quote Link to comment Share on other sites More sharing options...
Fie C Posted January 12, 2009 Author Report Share Posted January 12, 2009 tordag d. 8leg extentions12x22,5 kg12x22,5 kg12x22,5 kg12x22,5 kgleg curl12x45,5kg12x45,5kg12x45,5kg12x45,5kgbænkpres11x12,5kg10x12,5kg10x12,5kg6x12,5kgpull downs12x36,5kg12x36,5kg12x36,5kg12x36,5kgskulderpres12x10kg8x10kg8x10kg7x10kglateral raises12x5kg12x5kg12x5kg12x5kgface pulls12x4"12x5"12x5"12x5"hyperextensions+5kg x 20 reps x 3 sætkalorieforbrænding under styrketræning; 612kcalkan mærke at jeg er begyndt af falde i styrke, hænger nok sammen med kcal-underskudderefter var jeg til attack. kalorieforbræning under attack: 728kcalmax puls: 94% af max/ 190i alt 1340kcalsuper fed træning. var også ugens eneste træning, pga af donation af blod, teater, galla mm. stilen ændres self i næste uge, hvor der skal trænes 4 gange om ugen igen!! Quote Link to comment Share on other sites More sharing options...
Fie C Posted January 12, 2009 Author Report Share Posted January 12, 2009 mandag d. 12.01styrketræningleg extension12x22,5kg12x22,5kg12x22,5kg12x22,5kgleg curl6x31,5kg6x31,5kg6x31,5kg6x31,5kgpull downs12x36,5kg12x36,5kg12x36,5kg12x36,5kgbænkpres12x10kg10x12,5kg8x12,5kg8x12,5bænkpres close grib12x7,5kg+10kg(stang) 12x7,5kg+10kg(stang) 12x7,5kg+10kg(stang) 12x7,5kg+10kg(stang) face pulls12x4"12x5"12x5"12x5"nåede desværre ikke mere da jeg skulle til attack. men fik dog forbrændt 254kcal på den time jeg nåede at træneattack.endnu engang superfedt. især fordi jeg virkelig havde meget energi her til aften, kunne seriøst alting og fik også forbrændt en hel masse. fik forbrændt 711 kcal, men glemte at tænde for det, så missede lige kalorieoptællingen på det første track så der skal nok lægges lidt til...men var i hvert fald super fedt, og fik presset mig selv rigtig godt - var SÅ fedtsamlet kalorieforbræning; 965kcal Quote Link to comment Share on other sites More sharing options...
Fie C Posted January 18, 2009 Author Report Share Posted January 18, 2009 torsdag d. 15det blev ikke til så meget andet end attack. men var helt fint- meget som det plejer. føltes dog ikk helt så hårdt, var ligesom om jeg kunne lidt mere end jeg plejer.fik forbrændt 695 kcal, så var lidt mindre end normalt, men helt ok alligevel.max puls; 192/95% gennemsnit;164/81% -så det var ganske fint. og pulsen kom lidt højere op end den plejer, så trods af at det slet ikke føles så hårdt som det plejer.super træning alt i alt Quote Link to comment Share on other sites More sharing options...
Fie C Posted January 18, 2009 Author Report Share Posted January 18, 2009 fredag d. 16.idag blev det bare til en lille løbetur. blev til 3,1 km på 15.30 minutter. med andre ord en hastighed på ca. 12km/t så det helt fint.den tur vil jeg forsøge at løbe en gang om ugen den næste tid, bare for lige at se om jeg kan komme til at løbe den hurtigere. på de 15 minutter fik jeg forbrændt 198 kcal, så det var helt fint. Quote Link to comment Share on other sites More sharing options...
Athlete X Posted January 18, 2009 Report Share Posted January 18, 2009 Er du interesseret i en date med mig Fie? Quote Link to comment Share on other sites More sharing options...
Fie C Posted January 18, 2009 Author Report Share Posted January 18, 2009 lørdag d. 17.combat: 664kcalmax puls; 185/92%gennemsnit; 167/83% Quote Link to comment Share on other sites More sharing options...
