Zune Posted August 26, 2007 Author Report Share Posted August 26, 2007 Uge 34, lørdag den 25/8-07, skulder, biceps og triceps, 45 minVar nede i motionsrummet på mit arbejde.Seated db shoulder press:1x10: 20 kg db1x10: 24 kg db1x10: 26 kg db3x10: 30 kg db2x8: 26 kg dbPress behind neck(smith rack):3x10: 30 kg+rackSeated lateral raises:3x10: 10 kg dbSeated bent over raises:3x10: 10 kg dbBB-curls:3x10: 40 kg2x10: 45 kg....mega letteIncline db curls:1x5: 20 kg db3x10: 18 kg dbConcentration curls:2x10: 12 kg dbOver head cable curls:3x12: 25 kgTriceps pushdown:3x10: 85 kgTriceps rope pushdown:3x10: 40 kgOne arm triceps pushdown:3x10: 15 kgDet træningspas sad rent hvor det skulle Der var cement i bi´s og tri´s og delt var ømme på den fede måde Quote Link to comment Share on other sites More sharing options...
Zune Posted August 31, 2007 Author Report Share Posted August 31, 2007 Uge 35, torsdag den 30/8-07, bryst, 45 minVar nede i motionsrummet på mit arbejde - Wanker holdet var mødt op til træf...Benchpress:1x10: 50 kg1x10: 60 kg1x10: 80 kg1x10: 110 kg1x5: 120 kg3x5: 130 kgDe var lamme i ansigtet, da den gamle lagde pres på stangen Incline db press:4x10: 40 kg dbCable cross:4x10: 25 kg ---- BURNINGHygge omgang med team Wanker Quote Link to comment Share on other sites More sharing options...
Zune Posted September 2, 2007 Author Report Share Posted September 2, 2007 Uge 35, søndag den 2/9-07, ryg og nakke, 45 minVar oppe i WFC.Chins:1x12:: BW2x10: BWT-bar:3x8:75 kg1x10: 60 kgLat pulldown(bred/lige):3x10: 90 kgLat pulldown(bredt/parallelt):3x10: 85 kgPulley rows(smalt):4x10: 65 kgPulley rows(bredt/parallelt):3x10: 60 kgVertical machine rows:2x10: 40 kgUpper back machine rows:3x10: 30 kgShrungs/machine:5x10: 60 kgGod og intensiv omgang.. Quote Link to comment Share on other sites More sharing options...
Zune Posted September 3, 2007 Author Report Share Posted September 3, 2007 Uge 36, mandag den 3/9-07, skulder, biceps og triceps, 70 min.Var oppe i WFC sent.Seated db shoulder press:1x10:24 kg db5x10: 30 kg dbSeated front press(smith rack):4x10: 30 kg+stativSeated lateral raises:4x10: 10 kg dbSeated bent over raises:3x10: 10 kg dbBB curls:1x10: 30 kg1x10: 40 kg1x10: 45 kg1x5: 50 kg3x8: 45 kgPreacher EZ-curls:4x10: 37,5 kgConcentration curls:2x10: 12 kg db2x10: 14 kg dbDIPS:1x35: BW2x10: BW BURNING FIBRES Lying db triceps extension:1x10: 14 kg db3x10: 16 kg dbOne arm triceps ext.:2x10: 10 kg dbTriceps kick backs:3x10: 8 kg dbDer var ren syre i delt´s og armene var som cement..igen Quote Link to comment Share on other sites More sharing options...
Zune Posted September 5, 2007 Author Report Share Posted September 5, 2007 Uge 36, onsdag den 5/9-07, ben, lægge, cardio og mave, 60 minVar sent oppe i WFC.Opvarmning:5 min. sofacykelLegpress:1x10: 80 kg5x10: 120 kgLeg ext.:5x10: 25 kgLeg curl:5x10: 15 kgSeated calve raises:5x12: 30 kgCardio/ sofacykel:20 min.Mave: Abs machine:100 reps Quote Link to comment Share on other sites More sharing options...
Zune Posted September 8, 2007 Author Report Share Posted September 8, 2007 Uge 36, fredag den 7/9-07, bryst, ryg, biceps og triceps, 60 min.Var nede i motionsrummet på mit arbejde.Benchpress:1x10: 50 kg1x10: 60 kg1x10: 80 kg1x10: 110 kg1x5: 120 kg3x5: 125 kgIncline db press:3x10: 42 kg dbCable cross:3x10: 30 kgLat pull down(bredt/bøjet greb):3x10: 80 kgLat pull down(bredt/lige greb):3x10: 80 kgLat pull down(bredt/parallelt greb):3x10: 80 kgLat pull down(smalt/parallelt greb):3x10: 80 kgVertical rows(machine):6x10: 50 kgSupersæt: Biceps/TricepsBB curls / Triceps pushdown:4x10: 40 kg / 4x10: 70 kgGod omgang overkrop og arme Quote Link to comment Share on other sites More sharing options...
Zune Posted September 13, 2007 Author Report Share Posted September 13, 2007 Uge 37, onsdag den 12/9-07, bryst og ryg, 65 min.Var sent oppe i WFC.Benchpress:1x10: 50 kg1x10: 80 kg1x10: 110 kg1x10: 120 kg NY REP. PR !!!!!!!!!1x5: 130 kg1x4: 130 kg1x4: 120 kgIncline benchpress:4x10: 80 kgLying hammer press:2x10: 60 kgPec deck:2x10: 40 kgChins(bøjet greb):3x8: BWCG Chins:3x8: BWT-bar:4x10: 60 kgLat pulldown(lige bredt greb):3x10: 80 kgLat pulldown(parallelt bredt greb):3x10: 80 kgPulley rows:3x10: 65 kgLow rows / Technogym machine:3x10: 40 kgGod omgang med historisk let bænk på 120 kg - surt jeg ikke skulle kører 1RM, så havde der været ny PR Quote Link to comment Share on other sites More sharing options...
Zune Posted September 14, 2007 Author Report Share Posted September 14, 2007 Uge 37, fredag den 14/9-2007, skulder, biceps og triceps, 45 min.Var nede i motionsrummet på mit arbejde.Seated db shoulder press:Opvarmning.1x10: 22 kg db1x10: 26 kg db3x10: 30 kg dbSeated frontpress(smith rack):3x10: 40 kg+stativ1x10: 45 kg+ stativSeated press behind neck(smith rack):3x10: 30 kg+ stativLateral raises(delt´s machine/technogym):3x10: 30 kgCompound sæt for rear delts:Bent over cableraises(rear delts) / standing cable pull (rear delts) 3x10: 15 kg / 3x10: 15 kgSupersæt for biceps og triceps:BB curls / French press1x10: 40 kg / 1x10: 35 kg1x10:50 kg / 1x10: 35 kg1x10: 50 kg / 1x10: 35 kg1x8: 50 kgPreacher curls / triceps pushdown:3x10: 35 kg / 3x10: 80 kgConcentration curls / triceps rope pushdown:3x10: 14 kg db / 3x10: 40 kgSkøn omgang supersæt for armene - det virker perfekt p.t. Der var endnu engang cement i de små gunz Quote Link to comment Share on other sites More sharing options...
Zune Posted September 18, 2007 Author Report Share Posted September 18, 2007 Uge 38, mandag den 17/9-2007, bryst og ryg, 60 min.Var sent oppe i WFC.Benchpress:1x10: 50 kg1x10: 80 kg3x10: 110kg2x5: 120 kg1x5: 130 kgIncline benchpress:4x10:80 kgPec deck:3x10: 40 kg....burning fibres Chins(smith rack):1x10: BW1x5: BW2x7: BWT-bar:3x8: 60 kgLat pulldown(lige og bredt greb):3x10: 80 kgLat pulldown(lige og parallelt greb):3x10: 80 kgPulley rows:(semi bredt og parallelt greb):4x8: 60 kg....sad rent i latz Quote Link to comment Share on other sites More sharing options...
Zune Posted September 23, 2007 Author Report Share Posted September 23, 2007 Uge 38, lørdag den 22/9-2007, skulder, biceps, triceps og underarme, 70 min.Seated db shoulder press:--opvarmning--1x10: 26 kg db1x10: 30 kg db3x10: 34 kg db NY PR !!!!Military press:4x10: 50 kg ... lede efter db pressSeated lateral raises:3x10. 10 kg dbSeated front raises:3x10: 10 kg dbBent over raises(rear delts):3x10: 20 kg dbBB curls:--opvarmning-- 2x10: 32,5 kg--Worksæt--4x6: 50 kgPreacher curls:3x10: 37,5 kgIncline db curls:1x10: 16 kg db1x10: 18 kg db1x10: 20 kg dbconcentration curls:3x8: 16 kg dbFrench press:4x10: 40 kgLyimg db triceps extension:3x10: 16 kg dbDb triceps kick back:3x10: 6 kg db...burn Endnu en massiv omgang arme. Trænede dog lidt lang tid Quote Link to comment Share on other sites More sharing options...
Zune Posted September 25, 2007 Author Report Share Posted September 25, 2007 Uge 39, mandag den 24/9-2007, bryst og ryg, 75 min.Var oppe i WFC.Benchpress:2x10: 50 kg2x10: 80 kg1x10: 110 kg1x10: 120 kg3x3: 130 kgIncline benchpress:1x10: 90 kg2x8: 90 kgLyinng hammer press machine:3x10: 70 kgPec deck:3x10: 40 kgChins:3x10: BWT-bar:3x10: 70 kgOne arm db rows:3x10: 45 kg dbLat pulldown(lige og bredt greb):3x10: 80 kgLat pulldown(bredt og parallelt greb):3x10: 80 kgLat pulldown(smalt og parallelt greb):3x10: 80 kgHård omgang. Quote Link to comment Share on other sites More sharing options...
Zune Posted September 29, 2007 Author Report Share Posted September 29, 2007 (edited) Uge 39, lørdag den 29/9-07, skulder, biceps, triceps og underarme, 75 min.Var tidligt oppe i WFC.Seated db shoulder press:1x10: 22 kg db1x10: 26 kg db--opvarmning--slut--1x10: 30 kg db1x6: 34 kg db3x10: 30 kg db1x10: 28 kg dbMilitary press:4x10: 50 kgSeated lateral raises:3x10: 10 kg dbSeated front raises:3x10: 10 kg db----kørt med tre varianter--Seated bent over raises(rear delts):3x10: 10 kg dbBB curls:1x10: 40 kg1x10: 45 kg1x6: 50 kg2x8: 45 kg1x10: 40 kgPreacher curls(EZ-bar):1x8: 37,5 kg4x8: 32,5 kgConcentration curls:4x8-10: 14 kg dbFrench press:1x10: 37,5 kg3x10: 40 kg1x6: 40 kgDips:3x10: BW ---- Føj de sad lige i skabet---Triceps rope pushdown:4x8-12: 35 kg----SYRE---Wristcurls:4x10: 40 kgReverse wristcurls:4x10: 6 kg dbEndnu en god omgang skulder og arme Edited September 29, 2007 by Zune Quote Link to comment Share on other sites More sharing options...
Zune Posted October 2, 2007 Author Report Share Posted October 2, 2007 Uge 40, mandag den 1/10-07, bryst og ryg, 70 min.Var sent oppe i WFC.DB Benchpress:--opvarmning---1x10: 22kg db1x10: 24kg db1x10: 28 kg db1x10: 30 kg db--opvarmning slut--1x10: 42 kg db2x10: 45 kg db2x7: 45 kg dbIncline db benchpress:2x8: 34 kg db2x7: 34 kg dbHigh incline benchpress:4x7: 30 kg dbIncline db flyers:3x8: 20 kg dbChins(bøjet greb):3x7: BWCG Chins:3x7: BWT-bar:1x10: 60 kg3x8: 75 kgPulley rows:4x10: 70 kgLat pulldown(parallelt greb/bredt):3x10: 90 kgLat pulldown(bredt/lige):3x10: 80kgEn god omgang, som har givet DOMS her dagen efter. Quote Link to comment Share on other sites More sharing options...
Zune Posted October 4, 2007 Author Report Share Posted October 4, 2007 Uge 40, onsdag den 3/10-07, ben, lægge, cardio og mave, 55 min.Var sent oppe i WFC.Opvarmning på cykel:5 min.Legpress:1x10: 80 kg5x10: 120 kgLeg extension:5x10: 30 kgLeg curls:4x10: 15 kgSeated calve raises:5x10-12: 30 kgCardio/cykel:25 min, 10,15 km.Total abs machine/technogym:40 kg: 100 reps. Quote Link to comment Share on other sites More sharing options...
Zune Posted October 6, 2007 Author Report Share Posted October 6, 2007 Uge 40, fredag den 5/10-07, skulder, biceps og triceps, 75 min.Var oppe i WFC.Military press:1x10: 40 kg1x10: 50 kg1x10: 60 kg2x8: 60 kg3x6: 60 kg1x8: 50 kgSeated db shoulder press:3x10: 30 kg dbSeated lateral raises:3x10: 10 kg dbSeated front raises:(tre varianter)3x10: 10 kg dbBB curls:1x10: 40 kg1x10: 45 kg1x6: 50 kg1x5: 50 kg1x8: 45 kg2x10: 40 kgIncline db curls:4x10: 18 kg dbConcentration curls:3x10:14 kg dbDips:1x12: BW2x10: BWTriceps pushdown:4x10: 65 kgOne arm triceps pushdown:4x10: 25 kgEn lang men god omgang Quote Link to comment Share on other sites More sharing options...
Zune Posted October 9, 2007 Author Report Share Posted October 9, 2007 Uge 41, mandag den 8/10-07,Bryst og triceps, 65 minVar sent oppe i WFC- Startede op med en programændring, hvor jeg hopper tilbage til flg.:Mandag: Bryst+triceps.Onsdag: Skulder+ben+cardioFredag: Ryg+biceps.Benchpress:2x10: 50 kg1x10: 80 kg1x10: 110 kg1x10: 120 kg1x5: 130 kg1x3: 130 kg1x5: 120 kg1x3: 120 kgIncline benchpress:1x10: 90 kg1x8: 90 kg1x7: 90 kgLying hammer press:4x10: 80 kgPec deck:4x10: 40 kgDips:3x10: BW-----Føj den sad, kunne godt mærke programændringen---Frenchpress:1x10: 37,5 kg1x6: 37,5 kg1x4: 37,5 kg---total syre--Triceps pushdown(reverse):3x10: 30 kgTriceps pushdown(rope):3x10: 40 kgFøj hvor jeg var smadret i pecs og tris efter denne omgang.. Kroppen fik et chock ovenpå denne programændring. Quote Link to comment Share on other sites More sharing options...
Zune Posted October 13, 2007 Author Report Share Posted October 13, 2007 Uge 41, lørdag den 13/10-07, skulder, ryg og biceps, 60 minVar oppe i WFC.Militarypress:1x10: 50 kg1x10: 60 kg1x10: 65 kg1x6: 65 kg1x7: 60 kgSeated lateral raises:3x10: 10 kg dbBent over raises:3x10: 10 kg dbChins:1x10: BW2x9: BWCG chins:1x8: BW2x7: BWT-bar:1x10: 60 kg3x8: 70 kgPulley rows:3x8: 70 kgLat pulldown(lige og bredt):3x10: 80 kgLat pulldown(bredt og parallelt):3x10: 80 kgBB curls:1x10: 40 kg1x10 45 kg1x6: 45 kg1x6: 40 kg.....mega syre pump i underarmeneIncline biceps curls:2x10: 18 kg db2x8: 18 kg dbConcentration curls:2x10: 14 kg db1x10: 10 kg dbTrods syre i underarmene og det påvirkede min bicepstræning kom der en solidt pump i bi´s. Quote Link to comment Share on other sites More sharing options...
Zune Posted October 15, 2007 Author Report Share Posted October 15, 2007 Uge 42, mandag den 15/10-07, bryst, triceps og mave, 50 minVar sent oppe i WFC.Benchpress:2x10: 50 kg1x10: 80 kgWorkset3x10: 110 kgLying hammerpress:1x10: 90 kg NY PR2x10: 80 kgIncline benchpress:1x8: 90 kg2x10: 70 kgPec deck:3x10-12: 40 kg........Total syre+krampeagtig smerte Det kunne mærkes i fibrene, at jeg trænede skulder i forgårs derfor blev det lette vægte og høj intensitet.Frenchpress:3x10: 40 kgTriceps pushdown:3x10: 70 kgTriceps rope pushdown:3x10-12: 30 kg.....Godt pump Mavelir:100 reps.kørte med lette vægte og høj intensitet samt mindre sæt end normalt.. Quote Link to comment Share on other sites More sharing options...
Zune Posted October 18, 2007 Author Report Share Posted October 18, 2007 Uge 42, torsdag den 18/10-07, Skulder, ben, lægge, mave og cardio, 75 minVar tidligt oppe i WFC.Opvarmning:5 min. cykelMilitarypress:1x10: 40 kg1x10: 50 kg1x10: 60 kgWorksæt1x8: 65 kg1x5: 70 kg1x5: 65 kg1x5: 60 kgSeated latersl raises:4x10-12: 10 kg dbBent over cabel raises(rear delt´s):4x10-12: 5 kg... pussyvægt men den syrede som en Jeg fik virklig isoleret rear delt´s :4thumbup: Leg press:1x10: 40 kg1x10: 80 kgworksæt5x10: 120 kgLeg extension:5x10: 30 kgLeg curl:4x10-12. 15-20 kgSeated calve raises:5x10-13: 30 kgCardio/Sofa cykel:25 min. 10. 25 kmMave:40 rep. leg raises40 rep. chrunch machineGod skulder omgang, ben var lidt fesne men skulle bare overståes. Quote Link to comment Share on other sites More sharing options...
Zune Posted October 19, 2007 Author Report Share Posted October 19, 2007 Uge 42, fredag den 19/10-2007, ryg og biceps, 45 min.Var tidligt oppe i WFC.Chins:3x10: BWT-bar:1x10: 70 kg2x10: 80 kgCG Chins:3x8: BWSeated pulley rows:3x10: 70 kgLat pulldown(bredt/lige):3x10: 80 kgLat pulldown(bredt/parallelt):3x8: 80 kgEZ-curls:3x10. 40 kg...Syrede godt i underarmen efter alt den rygPreacher curls:1x5: 37,5 kg1x8: 32,5 kg1x8: 27,5 kg...mine arme syrede totalt til...Første gang i lang tid, hvor jeg er nede på 6 sæt biceps Pumpet kom dog rent i bi´s Quote Link to comment Share on other sites More sharing options...
Zune Posted October 22, 2007 Author Report Share Posted October 22, 2007 Uge 43, mandag den 22/10-07, bryst, triceps og mave, 45 minVar sent oppe i WFC.DB benchpress:Opvarmning1x10: 24 kg db1x10: 30 kg db1x10: 38 kg dbWorksæt:1x10: 45 kg db1x10: 50 kg db NY PR!!!!1x7: 45 kg dbIncline db benchpress:1x10: 42 kg db1x10: 38 kg db..fik hjælp på de sidste to1x10: 38 kg db..fik hjælp på de sidste toHigh incline db benchpress:2x7: 28 kg db1x5: 28 kg dbFrenchpress:1x10: 40 kg1x9: 40 kg1x7: 40 kgTriceps rope pushdown:3x12: 35 kg...syre tri´sAbs:100 reps.Holdt mig til mindre sæt end normalt, men ramte pec´s og tri´s rent :4thumbup: Quote Link to comment Share on other sites More sharing options...
jan3868 Posted October 24, 2007 Report Share Posted October 24, 2007 Ja det ser jo godt ud min ven... Men hvem bliver årets bænk puzzy mon ...... ! Quote Link to comment Share on other sites More sharing options...
Zune Posted October 24, 2007 Author Report Share Posted October 24, 2007 Ja det ser jo godt ud min ven... Men hvem bliver årets bænk puzzy mon ...... !Du siger bare til når du er klar!!!!!! Du har til den 31/12-07. Quote Link to comment Share on other sites More sharing options...
Zune Posted October 24, 2007 Author Report Share Posted October 24, 2007 Uge 43, onsdag den 24/10-07, skulder, ben, lægge, cardio og mave, 50 minVar sent oppe i WFC.Standing lateral raises:3x10: 12 kg dbSeated frontraises:3x10: 12 kg dbBent over raises:1x10: 12 kg db2x10: 10 kg dbHavde DOMS i pecs og delta, så det blev ikke til pres øvelser i dag..Leg extension:5x10: 30 kgLeg curls:5x10: 30 kgLegpress:5x10: 120 kgSeated calve raises:5x12: 30 kgCardio:25 min sofacykel, 10,2 kmAbs:80 reps i chrunch-machine Quote Link to comment Share on other sites More sharing options...
Zune Posted October 26, 2007 Author Report Share Posted October 26, 2007 Uge 43, fredag den 26/10-2007, ryg og biceps, 50 min.Var tidligt oppe i WFC.Chins:3x10: BW..Meget lette i dag T-bar:3x10: 75 kgLat pulldown(bredt/lige):3x10: 85 kgLat pulldown(bredt/parallelt):3x10: 80 kgLat pulldown(smalt/parallelt):3x8: 80 kgPulley rows:1x10: 65 kg1x6: 70 kg1x8: 65 kgBB-curls:1x10: 40 kg2x6: 45 kg1x8: 40 kgPreacher curls(EZ-bar):1x6: 37,5 kg1x8: 32,5 kg2x10: 27,5 kg Quote Link to comment Share on other sites More sharing options...
