Doktorens log
jsc
A1: Farmers walks
68+70 kg x 2 medium ture
A2: Push-ups
BW x 10
BW+25 kg x 10
Dips
Bw x 10
Bw+10 kg x 5 sæt x 10
Bw x 10
N. Grip. Pull-ups
Bw x 7 sæt x 8
D. Laterals
15 x 10
14 x 15
13 x 15
Machine Rear laterals
40 x 15, 15
35 x 20
D. 30/3
A1: Farmers walks
68+70 kg x 2 medium ture.
A2: Push-ups
BW x 10
BW+25 kg x 10
Ring Dips
Bw x 6 x 12 reps
Inverse rows (3021)
Bw x 6 x 8 reps
M. Laterals
80 x 15, 15, 15
Overhead C. ext
Stakken x 5
Stakken+10 kg x 10
Stakken x 12
Stakken x 10 + push-downs x 6
40 x 15, 15, 5
Var lidt slidt
D. 2/5
A1: Farmers walks
A2: Push-ups
BW x 10
BW+25 kg x 10
Dips
Bw x 15, 15, 15, 15, 13, 12, 15, 15
Narrow parallel pull-ups (3210)
Kv x 8, 8, 8, 8, 8, 8, 8, 8, 8
40 x 15, 15, 15, 15
D. 30/3
A1: Farmers walks
68+70 kg x 1 medium ture.
A2: Push-ups
BW x 10
BW+25 kg x 10
Dips
Bw+10 kg x 10, 10, 10, 10, 10, 10
Inverse Reverse grip rows
Kv x 8, 8, 8, 7, 6, 6, 5
40 x 15, 15, 15, 12, 13
Machine laterals
80 x 10, 10, 10, 10, 10
Edited by jsc
Farmers
68+70 kg x 1 runde
Push-ups
Kv x 10
Kv+25 kg x 10
Chin-ups, medium parallel
Kv x 9, 9, 9, 9, 9, 8, 8, 8
Ring Dips
Kv x 12, 12, 12, 10, 10, 11 - 67 reps
Maskin laterals
100 x 15 ->85 x 5->70 x 5
Overhead ext
Stakken+10 kg x 10->stakken-5 kg x 4->stakken-20 kg x 4
Rear delt machine flyers
40 x 15->35x5->30x5->25x5->20x5
Edited by jsc
Push-ups
Kv x 10
Kv+25 kg x 10
Farmers
68+70 kg x 1 tur
Dips
Kv x 10
Kv+10 kg x 10, 10, 10, 10, 10
Kv x 20, 15, 13
N. Para. Pull-ups
Medium grip rows (2210)
15 plader x 8, 7
14 plader x 7
Overhead ext
Stakken x 10, 9, 8, 7
Pec-deck
Stakken x 10, 10
Maskin laterals
Stakken x 10, 10, 10, 10, 10
Maskin Rear flyers
45 x 15
40 x 15
Edited by jsc
D. Suitcase holds
60 kg x 20/20 sek
80 kg x 30/30, 30/30 sek
Der var for crowded til farmers. Er spændt på, om lænd og obliques er døde i morgen?
Push-ups
Kv x 10
Kv+25 kg x 10
Ring Dips
Kv x 15, 15, 12, 10, 10
Pull-ups, brede parallelle
Kv x 8, 8, 8, 8, 7, 6
Maskin laterals
Stakken x 15, 13, 12
K. Rows (2210)
15 x 8, 8, 6
Overhead ext
Stakken x 10, 10, 10, 8
Rear delt maskin flyers
45 x 15
40 x 15
34 x 15
Suitcase holds
60 kg x 20/20 sek
80 kg x 40/40, 40/40 sek
Push-ups
Kv x 10
Kv+25 kg x 10
Inverse rows
Kv x 8, 8, 8, 8, 6, 6
Dips
Kv x 10
Kv+10 kg x 10
Kv+15 kg x 10, 10, 10
Kv x 15, 12
Maskin laterals
100 x 10, 10
100 x 8 -> 85 x 4 -> 70 x 5 -> 55 x 3
Suitcase holds
40 kg x 10/10 sek
60 kg x 10/10 sek
80 kg x 10/10 sek
100 kg x 10/10 sek
80 kg x 20/20 sek
Push-ups
Kv x 10
Kv+20 kg x 10
Dips
Kv x 10
Ring pull-ups
Ring Dips
Kv x 15, 15, 14, 14, 13
Maskin Rear flyers
45 x 15 + 4 drop
Maskin laterals
100 x 15 + 4 drop
Edited by jsc
Farmers walks
Push-ups
Kv x 10
Kv+20 kg x 10
Kv+40 kg x 10
Inverse rows
Kv x 8, 8, 8, 7, 6, 5
Weighted Dips
Kv x 10
Kv+15 kg x 10, 10, 10, 10
D. Laterals
2 x 10 kg x 8
2 x 15 kg x 10
2 x 14 kg x 10
2 x 12.5 kg x 11
Overhead ext
Stakken x 10, 10, 10 + 9 straight arm pull-downs
D. 5/5
Bencurls
70 x 8
90 x 8
110 x 8
130 x 8
150 x 8, 8
130 x 8
Rygstrækkere
Kv+10 kg x 8, 8, 6
Squat-stanse deadlift
40 kg x 5
60 kg x 5
80 kg x 5
100 kg x 5
110 kg x 5, 5, 5
D. 7/5
A1: Suitcase holds
40 kg x 10 sek
60 kg x 10 sek
80 kg x 10 sek
100 kg x 12 sek
80 kg x 40 sek
De var tunge i dag. Ryggen driller for tiden, og den her øvelse synes at hjælpe?
A2: Push-ups
Kv x 10
Kv+20 kg x 10
Kv+40 kg x 10
Dips
Kv x 10
B1: Pull-ups, bredt parallel
Kv x 10, 10, 10, 10, 10
B2: Ring Dips
Kv x 15, 15, 14, 13, 12
C1: Maskin laterals
100 x 13, 12, 10
C2: Rear delt flyers
45 x 13, 12
40 x 13
Edited by jsc
Farmers walks
Push-ups
Kv x 10
Kv+25 kg x 10
Kv+50 kg x 10
Dips
Kv x 10
Kv+15 kg x 10
Ring Dips
Kv x 15, 15, 15
Inverse rows
Kv x 8, 6, 6, 6, 5, 5
Elastik leg for skuldre
Bencurls
90 x 8
110 x 8
130 x 8
150 x 8
170 x 5+3
Rygstrækkere (2210)
Kv x 8, 8
Dødløft fra blokke, pegefinger ved ringe
40 kg x 5, 5, 5
60 kg x 5
80 kg x 5
90 kg x 5
Push-ups (3020)
Kv x 10
Kv+20 kg x 10
Kv+40 kg x 10
Dips
Kv x 10, 10, 10
K. Rows
20 plader x 15 sek hold i bund -> 15 plader x 5
(25 plader x 15-20 sek hold i bund -> 15 plader x 5 (3210)) x 5
Maskin laterals
60 x 10
80 x 10, 16, 10
Overhead ext
Stakken+10 kg x 9 -> stakken-5 x 5 -> stakken-15 x 4
Edited by jsc
Suit case isohold m 1/2 dødløft
40 kg x 10 sek
60 kg x 10 sek
80 kg x 10 sek
90 kg x 17 sek
80 kg x 50 sek
Push-ups (3020)
Kv x 10
Kv+20 kg x 5
Kv+40 kg x 8, 8, 8
Parallel pull-ups (3020)
Kv x 8, 8, 7, 6, 5, 6
Jeg syntes jeg var sindssygt slap i disse, indtiljeg erkendte, at jeg kørte m tre sekunders negativ fase, mod vanligt et sekund ;)
Dips (3020)
Kv x 10, 10, 10, 8, 8
Maskin laterals
80 x 18, 15, 12
Maskin Rear flyers
40 x 15, 12,
Farmers walks
70+68 kg x 2 x medium tur
Push-ups
Kv x 10
Kv+20 kg x 5
Kv+40 kg x 8, 8, 8, 7, 6
Inverse rows (3320)
Kv x 6, 6, 6, 6, 6
Bencurls
90 x 8
110 x 8
130 x 8
150 x 8
K. Rows
Hold i bund + (3012)
(Stakken x sek 15 plader x reps) x
20 sek+7, 30+5, 30+5, 30+5, 30+5
M. Laterals
60 x 10
80 x 10, 10, 10, 10
Overhead ext
Stakken x 8
Stakken-10 x 10
Stakken-15 x 10
Stakken-20 x 10
Edited by jsc
Suit case isohold
20 kg x 10 sek
50 kg x 10 sek
70 kg x 10 sek
90 kg x 17, 10 sek
80 kg x 20
Push-ups (3020)
Kv x 10
Kv+20 kg x 5
Kv+40 kg x 5
Dips (3010)
Kv x 10
Kv+15 kg x 10, 10, 10, 9, 8
Kv x 12
Parallel pull-ups (3010)
Kv x 8, 8, 7, 6, 6, 8
Maskin laterals
60 x 8
80 x 3
100 x 10, 10
90 x 12
80 x 12
Maskin Rear flyers
40 x 10, 10
35 x 10
Straight arm pull-downs (3010)
Stakken x 7
Stakken-10 x 7
K. Rows
Hold + dynamisk
16 plader x 10 sek + 5 reps
25+16 x 30+5
Bencurls
90 x 8
110 x 8
130 x 8, 8, 8, 8, 8
High handles trapbar DL
46 x 5
56 x 5
66 x 5
76 x 5
86 x 5
Low handle er for lav og high handle er lidt for høj. Prøvede m sko på i dag og så kan jeg evt køre low handle fra et par skiver næste gang
1-bens RDL
16 kg x 8
Walking lunges
Kv x 1/2 center
Kv+20 kg x 1/1 centerlængde
Nu prøver jeg dem her mhp, om knæene kan være med.
Tog op for at træne, men var for slidt. Gik op på trappemaskinen i stedet. Det er en morderisk maskine, så det blev ren intervaltræning :P
Stairmaster
Niveau 10 x 5, 4, 3, 3, 3 min m 2 min pause
nåede op på en puls omkring 172 til sidst
Edited by jsc
