BOOOOOM!1!
Johnny Bravo
  • Replies 504
Dagens træning.
Incline BB. Press:
10x60kg
8x90kg
5x110kg
5x110kg
8x100kg
Bench Rows:
5x100kg
5x100kg
5x100kg
5x100kg
5x100kg
Seated DB. Lateral Raise:
10x17.5kg
10x17.5kg
10x17.5kg
10x17.5kg
Face Pulls:
10x35kg
10x40kg
10x40kg
10x40kg
BB. French Press/CGBP superset with Alternate DB. Curl:
10x40kg/10x40kg - Failure x25kg
10x40kg/10x40kg - Failure x27.5kg
Dagens MEGA spændende træning.
Pulldown:
20x45
20x50kg
20x50kg
Plate Loaded Machine Rows:
20x40kg
20x40kg
20x40kg
Plate Loaded Incline Chest Press:
20x40kg
20x50kg
20x50kg
Rear Delt Machine:
20x30kg
20x35kg
20x35kg
DB. Lateral Raise:
20x12kg
20x12kg
20x12kg
EZ BB. Preacher Curl:
20x20kg
20x22.5kg
20x22.5kg
Rope Pushdown:
20x30kg
20x35kg
20x35kg
Dagens træning.
High reps = striations!!
Plate Loaded Pull Down:
20x50kg
20x50kg
20x50kg
Wide Grip Cable Rows:
20x50kg
20x50kg
20x50kg
Hyper Extensions:
20xbw
20xbw
20xbw
Wide Grip Bench Press:
20x60kg
20x60kg
20x60kg
DB. Lateral Raise:
20x14kg
20x14kg
20x14kg
Incline Smith Press:
20x30kg
20x30kg
20x30kg
Alternate DB. Curl:
20x16kg
20x16kg
20x16kg
OH Cable Extension:
20x40kg
20x40kg
20x40kg
Rear Delt Machine:
20x40kg
20x40kg
20x40kg
Dagens træning.
Pull Down:
20x50kg
20x50kg
20x50kg
Chest Supported Incline DB. Rows:
20x15kg
20x17.5kg
20x17.5kg
Upright Rows:
20x40kg
20x40kg
20x40kg
20x70kg
20x70kg
20x70kg
DB. Lateral Raise:
20x15kg
20x15kg
Incline DB. Flyes:
20x17.5kg
20x17.5kg
20x17.5kg
EZ BB. Curl:
20x30kg
20x30kg
20x30kg
OH Cable Extension:
20x20kg
20x20kg
20x15kg
Chest Dips:
50xbw
20xbw
Dagens træning i en tom hule.- bortset fra Chris selvfølgelig.
Stiff Arm Pull Down:
20x20kg
20x20kg
20x20kg
Pull Down:
20x40kg
20x40kg
20x40kg
DB. Press:
20x22kg
20x22kg
20x22kg
Military Press:
20x30kg
20x30kg
DB. Flyes:
20x17.5kg
20x17.5kg
20x17.5kg
Bent Over Lateral Raise:
20x5kg
20x5kg
BB. Curl:
20x20kg
20x30kg
20x30kg
CG BP:
20x60kg
20x60kg
20x60kg
Dagens træning.
Pull Down:
20x40kg
20x40kg
20x40kg
DB. Pull Overs:
20x27.5kg
20x27.5kg
20x27.5kg
Incline BB. Press:
20x50kg
20x50kg
20x50kg
Bench Rows:
20x60kg
20x60kg
20x60kg
20x60kg
DB. Flyes:
20x17.5kg
20x17.5kg
20x17.5kg
DB. Lateral Raise:
20x9.5kg
20x9.5kg
20x9.5kg
Preacher EZ BB. Curl:
20x25kg
20x25kg
20x25kg
OH Cable Extension:
20x20kg
20x15kg
20x15kg
Dagens træning.
Pull Down -V-bar:
20x40kg
20x45kg
20x45kg
20x40kg
20x40kg
20x40kg
20x40kg
20x45kg
20x45kg
Bench Press:
20x60kg
20x50kg
20x50kg
One Arm Cable Lateral Raise:
20x5kg
20x5kg
20x5kg
Rear Delt Machine:
20x35kg
20x35kg
20x35kg
Cable Curl:
20x20kg
20x25kg
20x25kg
Rope Push Down:
20x15kg
20x17.5kg
20x17.5kg
Guest Slettet bruger
Æv. Surt det skulle ende sådan. Men når man ikke lige rammer dagen og derudover er så uheldig, som du var, så er der ikke meget at gøre, desværre.
Ellers fin indsats og indstilling op til konkurrencen.
Bedre held næste gang, friend :smile: .
