ANGEL
angel
Dagens træning Torsdag d. 23. Juni
MORGENCARDIO kl. 6:00
POWERWALK
¤ 50 minutter
EFTERMIDDAGSTRÆNING kl. 13:30
BEN
POWERWALK
¤ 15 minutter
SQUAT
1set x 20reps @ 20kg
1set x 15reps @ 20kg
1set x 15reps @ 40kg
1set x 12reps @ 50kg
1set x 12reps @ 60kg
1set x 10reps @ 70kg
1set x 11reps @ 70kg
1set x 12reps @ 70kg
1set x 13reps @ 70kg
1set x 14reps @ 70kg
LUNGES
1set x 10reps @ 60kg
1set x 11reps @ 60kg
1set x 15reps @ 60kg
... gik lidt ned i kg da mit ene knæ "driller" lidt for tiden :dry:
SEATED LEG PRESS
1set x 20reps @ 110lb
1set x 15reps @ 170lb
1set x 15reps @ 210lb
1set x 15reps @ 250lb
1set x 12reps @ 290lb
ET BENS LEG EXTENSION
1set x 20reps @ 10lb
1set x 15reps @ 10lb
1set x 15reps @ 25lb
1set x 15reps @ 30lb
1set x 10reps @ 50lb
1set x 12reps @ 50lb
... egenligt OK - men mest for at skåne mine knæ som er lidt udsatte for tiden!!
ADDUCTOR
1set x 20reps @ 130lb
1set x 17reps @ 150lb
1set x 10reps @ 170lb
ROTATOR CUFF - EXTERN
1set x 15reps @ 8lb
1set x 15reps @ 12lb
  • Replies 10.3k
Posted Images
Dagens træning Fredag d. 24. juni
FORMIDDAGSCARDIO kl. 10:00
POWERWALK
¤ 50 minutter
EFTERMIDDAGSTRÆNING kl. 16:00
BRYST - BICEPS - LÆG - MAVE
CYKLE
¤ 15 minutter
SKRÅ DB PRESS
1set x 15reps @ 15kg
1set x 12reps @ 17.5kg
1set x 10reps @ 20kg
1set x 10reps @ 22.5kg
1set x 10reps @ 25kg
1set x 8reps @ 27.5kg
1set x 6reps @ 27.5kg
1set x 12reps @ 25kg
... alle bænkene var optaget (og min tålmodighed strakte ikke til at vente ... skulle jo BRÆÆÆÆNDE) så det blev DB pres i stedet for alm. BB pres :smile:
FLYES - maskine
1set x 12reps @ 37.5kg
1set x 9reps @ 47.5kg
1set x 7reps @ 52.5kg
1set x 5reps @ 57.5kg
1set x 10reps @ 37.5kg
SIDDENDE LÆGPRES
1set x 20reps @ 50kg
1set x 16reps @ 70kg
1set x 14reps @ 80kg
1set x 12reps @ 90kg
1set x 10reps @ 100kg
... lidt dum i knæet --> så det blev ikke til så mange i dag :raisebrow:
MAVE - LIGE
hyperextensionbænk - fuld peakkontraktion i toppen
1set x 15reps @ BW
1set x 20reps @ BW
1set x 20reps @ BW
1set x 20reps @ BW
Front raise superset'et med laterals
FRONT RAISE DB
skråt ind foran, underhånd
1set x 10reps @ 4kg
1set x 10reps @ 6kg
1set x 10reps @ 9kg
1set x 10reps @ 11kg
... WEEEEE :w00t: streger på toppen af brystet ... KLASSE :cooldance:
LATERALS DB
1set x 10reps @ 4kg
1set x 10reps @ 6kg
1set x 10reps @ 9kg
MAVE - SKRÅ, maskine
1set x 15reps @ 90lb
1set x 12reps @ 110lb
1set x 10reps @ 130lb
BICEPS DB CURL
1set x 10reps @ 12.5kg
1set x 15reps @ 12.5kg
... som opvarmning for den lidt mere koncentrede maskine curl :smile:
BICEPS CURL - HAMMER STRENGTH
1set x 14reps @ 22.5kg
1set x 14reps @ 25kg
1set x 10reps @ 27.5kg
POWERWALK
¤ 25 minutter
Mange svedige drenge :slut: i OBBC i daw... not bad - not bad at all :tongue
Dagens træning Lørdag d. 25. Juni
MORGENCARDIO kl. 5:30
POWERWALK
¤ 45 minutter
EFTERMIDDAGSCARDIO kl. 18:15
POWERWALK + 6 kg rygsæk
¤ 60 minutter
Det var så den første dag med rygsæk på i denne diæt --> der var intet at bemærke ud over lidt ekstra sve på ryggen :tongue:
... og så lige et lille men til alle de billister der dytter når man PW'er den aw!!
Det er kanon dejligt at I giver den lille opmuntring men HOLD KÆFT jeg er ved at hoppe ud i rabatten hver gang der er nogen der gør det fordi jeg går i min egen verden :blink::blink: så hold venligst lidt igen :wink::innocent:
Hjemmets nye guldklump :wub:
(øgenavn allerede fundet ... Bibi :blink: )
Bemærk hvordan hun allerede inden for de første 10 minutter har fundets hjemmets bedste gemmested... Krawens gunz ... det er sgu et sikkert sted :4thumbup:
Edited by angel
Hvad siger monsteret aka. Baxter til den lille ny?
<{POST_SNAPBACK}>
Baxter siger at hun for det første må lære det på den hårde måde eller hun får med poten :devil: samt at hun skal tage sig i agt.. specielt i HANS kattekradsetræet!! :4boxing:
NAAAAH... Baxter er faktisk fantastisk sød, sidder så pænt og kigger på hende. Han kommer kun en pote tættere af gangen! De har endnu ikke rigtigt hilst på hinanen men danser lidt om "den varme grød" og ser hinanden an med sigende blikke :blink:
... er spændt på i morgen hvordan de så har det :wub:
Edited by angel
det er nu nogle søde katte
selv om jeg normalt ikke er katte menneske
fik du min pm
<{POST_SNAPBACK}>
jep har fået den :smile:
Har bare en stak jeg skal have besvaret først... så er ikke nået til din endnu :wink:
(sker i morgen :4smartass: )
POWERWALK
¤ 45 minutter
¤ 60 minutter
Det er kanon dejligt at I giver den lille opmuntring men HOLD KÆFT jeg er ved at hoppe ud i rabatten hver gang der er nogen der gør det fordi jeg går i min egen verden :blink:  :blink: så hold venligst lidt igen  :wink:  :innocent:
<{POST_SNAPBACK}>
Kan KUN sige AMEN til det!! Jeg har det på RRÆCIS samme måde som dig -er ved at få hjerteslag hver gang, især hvis det er de helt store lastbiler :firebounce::omg::firebounce:
POWERWALK
¤ 45 minutter
¤ 60 minutter
<{POST_SNAPBACK}>
<{POST_SNAPBACK}>
JA... de store lastbiler giver sgu et godt et shock :freaked:
Specielt når de kommer bagfra og honker hornet!!!
¤ 60 minutter
<{POST_SNAPBACK}>
Går du med eller mod trafikken?
Jeg ville i hvert fald ikke være særlig tryg ved at gå samme vej som bilisterne (dvs i højre side :smile: ), så man ikke aner hvornår de kommer.
PS: jeg savner katte :crybaby: - de er bare så nuser
Edited by MaxPower
Nora..
mht biluheldet!
et stort "flot gået" fra denne gamle 1. hjælps instruktør..
det lyder som om du kørte den flot 100% efter bogen
Det er så godt at se når folk kan og vil lave god 1. hjælp
RESPEKT herfra :4thumbup: :4thumbup: :4thumbup:
¤ 60 minutter
<{POST_SNAPBACK}>
<{POST_SNAPBACK}>
Hver anden dag med... hver anden dag mod --> vender retningen af turen hver anden dag :smile:
Går dog altid på fortovet ... aldrig på vejen!!
Nora..
mht biluheldet!
<{POST_SNAPBACK}>
Takker Blackmoore :4thumbup:
Var også bare så glad for at opleve at jeg kunne bruge lidt af mine kundskaber fornuftigt :4smartass:
p.s. Har du tjekket billederne af hjemmet nye kugle :wub:
Dagens træning Søndag d. 26. Juni
MORGENCARDIO kl. 8:00
POWERWALK + 6kg rygsæk
¤ 60 minutter
MIDDAGSTRÆNING kl. 11:30
RYG - SKULDER
TRÆK NED FORAN
1set x 15reps @ 70kg
... bare lidt opvarmning :smile:
LEVER ROW
1set x 13reps @ 50kg
1set x 8reps @ 70kg
1set x 9reps @ 70kg
ONE ARM DB ROW
1set x 10reps @ 35kg
1set x 10reps @ 40kg
1set x 8reps @ 44kg
1set x 9reps @ 44kg
1set x 8reps @ 35kg
SUPPORTED BB ROWS
1set x 8reps @ 40kg
PRONEREDE DB SHRUGS
1set x 13reps @ 20kg
1set x 12reps @ 30kg
1set x 10reps @ 30kg
... absolut ny favorit øvelse :wub:
LATERALS - maskine
1set x 15reps @ 50lb
1set x 12reps @ 60lb
1set x 10reps @ 70lb
LATERALS DB
1set x 15reps @ 2 x 6kg
1set x 12reps @ 2 x 8kg
1set x 10reps @ 2 x 10kg
Dvs de dytter af dig på fortovet?  :blink:
Selvom du vender ruten, så kan du vel stadig gå imod trafikken - med mindre vejen er ensrettet?
<{POST_SNAPBACK}>
Ja... de dytter af mig på fortovet, endda nogle gange bag hækken :blink::raisebrow: men det er også kun lastbilerne der kan se mig der!!
Kan ikke gå modsattte side meget af vejen, da der kun er et fortov!!
... synes nu altså at chocket er tæt på at være lige så stort om det er front dyt eller bag dyt :tongue::tongue::laugh:
Jeg laver lige en total sviner af min egen log med min æææælskede uldtotter :heartpump:
Den lækre lille ny kærlighed :wub:
Den gamle skønne kat :w00t: som FAKTISK har fødselsdag i dag :cheer:
Lidt coaching af den bette ny ... det er jo vigtigt at hun bliver optrænet ordenligt :4smartass:
... og så bare lige en masse bonus billeder af Bibi, fordi jeg slet ikke kan stå for hendes charme :wub:
Edited by angel
