essensen Posted September 21, 2008 Author Report Share Posted September 21, 2008 (edited) Godt at høre Ved du egentlig hvad det fysiologiske argument er for at kabel crossovers ikke er gode til at bygge masse? Jeg mener, hvis man rammer failure på 12 rep og øvelsen rammer pecs kan jeg ikke gennemskue hvorfor den sucker..I'll state why flys are crappy.They are a low loading exercise that places all the insertions and joints involved in the movement under unnecessary load which leads to injury. This is primarily because the recruitment patterns of the chest fly have a slight delay before the pec is in it's position of strength. So all of the bicep, deltoid, and pectorial insertions (that deep burn you get in the centre of your chest at the sternum is actually tendon trying to pull off the bone) are being compromised, the shoulder capsule itself is therefore under a lot of stress, all leading to structural problems.Now that isn't to say that flys will kill you and rape your children, but given they are doing damage at such a low loading (thus little growth potential) you would question why you would do them at all. The only real place for them in a workout is as an activation exercise done at low loading. Most people do them post exercise where they probably have the least value other than as a pump exercise. Either way neither option should be anything other than a very occassional use.Another point is that DB flys for chest are the worst offender. All the load is happening when it is doing the most damage, and none when you need the most loading. Do cable flys if at all.Det er så godt nok flys der bliver talt om - men cable kommer jo lidt ind over der. Men - det handler jo om ens eget 'feel' - og jeg er personligt glad for at smide nogle flys ind i mit program efter presseøvelserne. Edited September 21, 2008 by essensen Quote Link to comment Share on other sites More sharing options...
Christian B Posted September 21, 2008 Report Share Posted September 21, 2008 Tak Må presse videre! Quote Link to comment Share on other sites More sharing options...
essensen Posted September 23, 2008 Author Report Share Posted September 23, 2008 (edited) Træning den 22/9-2008Så er det hverdag igen igen....I lørdags tog jeg hen til en pige fra mit arbejde og hendes veninder med 3 venner og drak mig ned. Vi tog videre og drak på apparatet hvor jeg naturligvis endte med at nappe hende jeg arbejder med . Og nu lader det så til en anden pige fra arbejdet er lettere misundelig over dette - Oh the drama I søndags tog jeg en velfortjent hviledag oven på en uge med 5 træningspas og 2 omgang cardio. I den her uge kører jeg noget semi-deload i form af 3 x FB high-rep sessions. Jeg har dårlig erfaring med rigtig deload så derfor kun en semi-udgave. Nu har jeg givet kroppen tæsk med mellem 5-8 træningssessions om ugen i et stykke tid - så 3 små træningspas med lette vægte og højre reps må alt andet lige aflaste lidt. Fik trænet mandag før skole - sov vanen tro elendigt, men fik da mig klaret igennem med et fornuftigt tempo. Jeg tror jeg skubber træningen således at jeg træner igen torsdag og sidste gang lørdag da jeg skal på druk fredag. Vi ved jo alle der er uanede mængder hypertrofi at hente på træning oven på druk Squat:10 @ 60kg12 @ 80kg12 @ 80kg3 @ 90kg1 @ 100kg12 @ 80kgT-bar rows:12 @ 40kg14 @ 60kg12 @ 60kg12 @ 60kgBænkpres:12 @ 50kg10 @ 70kg15 @ 70kg2 @ 90kg12 @ 70kgChin ups: (OHG)12 x bw12 x bw12 x bw10 x bwSS:DB skulderpres:12 @ 20kg12 @ 24kg12 @ 24kg10 @ 22kgIso wide grip hammerstrength bench press: 15 @ 70kg15 @ 70kg16 @ 70kg20 @ 70kgSS:Standing calf raise:15 @ 40kg15 @ 70kg15 @ 70kg15 @ 70kgLaterals:15 @ 10kg15 @ 11kg15 @ 11kgRope crunches:4 setsRobe Pushdowns:14 @ 17,5kg15 @ 24,5kg14 @ 28kg14 @ 28kgSS:Incline db curls:12 @ 15kg13 @ 15kg12 @ 15kgHammercurls:13 @ 16kg------------------------------------------------------------------------------------------Ok - fik lige kigget på træningen på skrift - jeg fik måske allligevel liiiige smækket lidt for mange øvelser og volumen på. Edited September 23, 2008 by essensen Quote Link to comment Share on other sites More sharing options...
simondj Posted September 23, 2008 Report Share Posted September 23, 2008 Blev spurgt i omklædningsrummet hvordan jeg var blevet så ripped Det er ret omsont at forklare alt så gav ham bare lidt keyworks i henhold til kost osv.Vi tog videre og drak på apparatet hvor jeg naturligvis endte med at nappe hende jeg arbejder med . Og nu lader det så til en anden pige fra arbejdet er lettere misundelig over dette - Oh the dramaGodt at se at du stadig reaper "the ENDLESS benefits of being ripped" ! Quote Link to comment Share on other sites More sharing options...
essensen Posted September 25, 2008 Author Report Share Posted September 25, 2008 (edited) DJ>> Man skal altid reape efter bedste evne Træning den 24/9 - 2008En omgang cardio før skoleCardio:15 min cykel15 min crosstrainer5 min cykel5 min crosstrainer= 40 min.-----------------------------------------------------------------------------------------------Træning den 25/9 - 2008Uinspirerende deload-træning med højre reps. Der er måske en del volumen, men jeg skøjter igennem træningspasset og føler mig slet ikke brugt efterfølgende så mon ikke det aflaster en del.Deadlift:10 @ 60kg8 @ 90kg6 @ 100kg6 @ 100kg6 @ 100kg1 @ 120kgIncline DB press:12 @ 24kg10 @ 32kg12 @ 30kg15 @ 28kg- et eller andet fuckfjæs havde taget 30'erne og båret dem tværs gennem lokalet for at bruge dem og så efterfølgende ladet dem ligge der - så jeg måtte hen og hente dem og farmerwalke dem på plads. Utroligt folk er så hamrende dovne og ubetænksomme.SS:DB rows:15 @ 36kg15 @ 36kg15 @ 36kg12 @ 36kgSeated cable rows: (narrow grip)15 @ 27kg15 @ 30,5kg15 @ 30,5kgSS:B.O lateral raise:15 @ 10kg12 @ 10kg15 @ 8kgcable laterals:15 @ 3,7515 @ 3,7512 @ 3,75SS:Cable crunches:4 setsDips:25 x bw12 @ +20kg25 x bw25 x bwSS:seated hammerstrength preachercurls:15 @ 20kg15 @ 22,5kg15 @ 22,5kg15 @ 22,5kgSeated calf raise:5 sets @ 15 repsSS:Machine flys:3 sets @ 15 reps---------------------------------------------------------------------------------------------------------------------Jeg laver muligvis en eller anden form for cardio før skole i morgen - jeg skal være drunk om aftenen (tema-fest på uni) så det er nok ikke en dum ide med lidt forebyggende cardio. Jeg tager den sidste omgang deload-træning på lørdag efter druk! Edited September 25, 2008 by essensen Quote Link to comment Share on other sites More sharing options...
Paven Posted September 25, 2008 Report Share Posted September 25, 2008 Jeg kan se, at druk er det grundlaegende aksiom, du opbygger din tilvaerelse ud fra. Det er nok en god ting!Hvordan gaar det med dansk-studiet? Quote Link to comment Share on other sites More sharing options...
JernHenrik Posted September 25, 2008 Report Share Posted September 25, 2008 Jeg kan se, at druk er det grundlaegende aksiom, du opbygger din tilvaerelse ud fra. Det er nok en god ting!Hvordan gaar det med dansk-studiet?Der er aldrig nogen, som har taget skade af 2-3 gennemgribende drukture om ugen - de er med til at holde motivationen oppe. Quote Link to comment Share on other sites More sharing options...
essensen Posted September 28, 2008 Author Report Share Posted September 28, 2008 Jeg kan se, at druk er det grundlaegende aksiom, du opbygger din tilvaerelse ud fra. Det er nok en god ting!Hvordan gaar det med dansk-studiet?For tiden er det i hvert fald et grundlæggende aksiom - det skal nok også til at ændre sig lidt nu, der er gået lidt for meget druk i den på det seneste. Dansk går nogenlunde - sådan lidt op og ned. Jeg har et par gode fag det her semester (kollektivromanen rekontekstualiseret og medieanalyse) og 2 jeg godt kunne have været foruden (svensk/norsk og Sprog). Den kan godt blive lidt anstrengende når man hader halvdelen af sine fag, men jeg hænger i endnu.lolz - de lå også ved foden af trapperne da Quads! og jeg trænede onsdag.Folk er epic dumme i FDK! Quote Link to comment Share on other sites More sharing options...
Krumborg Posted September 28, 2008 Report Share Posted September 28, 2008 Din protkage er munch-like med lidt banan, nødder og citronskræl :4mewantfood: Hvad tid rammer du fitdk i morgen? I crave teh pump.. Quote Link to comment Share on other sites More sharing options...
essensen Posted September 28, 2008 Author Report Share Posted September 28, 2008 Træning den 26/9-200840 mins cardio før skole. Om aftenen tog jeg til tema-fest på universitetet og fik scoret den pige jeg før har omtalt her i loggen (hende med kæresten - som hun så ikke længere har). Jeg er inde i en god stime Hende jeg så havde gang i sidste weekend skrev løbende til mig i løbet af aftenen og ville have jeg skulle komme forbi det sted hun var ... og dermed har jeg placeret mig solidt i et velkendt dilemma.Træning den 28/9-2008En omgang high rep deload oven på meget lidt søvn og druk. Var dehydreret og vaskulær og fik et fint pump grundet alle de høje reps, men nu er jeg godt nok klar til at rive noget jern igen. Jeg annoncerer et nyt program i morgen. Quote Link to comment Share on other sites More sharing options...
essensen Posted September 28, 2008 Author Report Share Posted September 28, 2008 Din protkage er munch-like med lidt banan, nødder og citronskræl :4mewantfood: Hvad tid rammer du fitdk i morgen? I crave teh pump.. Ja, den kan optimeres meget rent smagsmæssigt (selvom jeg synes den smager godt som jeg laver den) - men jeg sparer kalorierne. Jeg rammer FDK omkring kl. 9 i morgen hvis alt går efter planen (dvs. min nye ulidelige overbo ikke larmer helt ekstremt som han har gjort de sidste 4 dage) Quote Link to comment Share on other sites More sharing options...
Guest DBM Posted September 28, 2008 Report Share Posted September 28, 2008 Træning den 26/9-200840 mins cardio før skole. Om aftenen tog jeg til tema-fest på universitetet og fik scoret den pige jeg før har omtalt her i loggen (hende med kæresten - som hun så ikke længere har). Jeg er inde i en god stime Hende jeg så havde gang i sidste weekend skrev løbende til mig i løbet af aftenen og ville have jeg skulle komme forbi det sted hun var ... og dermed har jeg placeret mig solidt i et velkendt dilemma.Ohhhh teh drama!!! Quote Link to comment Share on other sites More sharing options...
essensen Posted September 28, 2008 Author Report Share Posted September 28, 2008 Ohhhh teh drama!!! I know Quote Link to comment Share on other sites More sharing options...
essensen Posted September 29, 2008 Author Report Share Posted September 29, 2008 Træning den 29/9-2008Jeg hader mig selv ind i mellem; jeg sov omkring 9 timer samlet set fra fredag til søndag i denne weekend og regnede derfor med en solid nattesøvn i går, men jeg vågnede kl. 4 og lå derefter og vendte og drejede mig i næsten 3 timer før jeg endelig igen faldt i søvn og fik en lille time og måtte derefter opgive at sove mere Needless to say har jeg været lidt bombet i dag! Jeg kom også til at tænke over jeg har drukket meget lidt væske siden fredag og muligvis er lettere dehydreret - det vil måske forklare (kombineret med alt for lidt søvn) hvorfor jeg har været ret svimmel det meste af dagen. Jeg håber at få rettet lidt op på det horrible søvnmønster i løbet af denne uge.Jeg droppede mine timer i dag da jeg ikke kunne overskue dem - havde alligevel heller ikke lavet den opgave vi skulle gennemgå og det var derfor lettere meningsløst at møde op. Jeg valgte i stedet at få lavet et par praktiske ting og så tage hen og smede den. Jeg er som bekendt begyndt på et nyt program - valget er faldet på et WS4SB - dog med lidt modificeringer hist og her, men overordnet følger jeg de retningslinier DeFranco har givet. Jeg kører efter hans Washed Up meathead template med 4 træninger pr. uge. Det kan godt blive ldit problematisk med arbejde - specielt da jeg har en træningsdag lørdag hvor jeg ofte skal arbejde og derfor kun kan afsætte ca. 40-45 min til træning at most. Det betyder jeg nogle gange må skære lidt i sæt og øvelser og træne lidt hurtigt igennem den dag ("vanity day"). Jeg må bare forsøge at gøre mit bedste.Det var ME upper body-dag. Jeg var fint motiveret, men energien var ganske simpelt ikke særlig god af grunde der er åbenlyse. Jeg var også lidt for længe op træningen da jeg lallede lidt for meget rundt til sidst - jeg skal gerne havde denne session ned på 1 t og 30 min så jeg kan træne før skole fremover.the numbers:Mandag: (Max-effort upper body)A. Me Bench press:10 @ 50kg8 @ 70kg6 @ 80kg3 @ 85kg3 @ 90kg2½ @ 95kg - fail på 3 rep - bah!9 @ 75kg- Dårlig styrke, men det var forventet. JEg er altid slap efter deload og min vægt var meget lav i morges - denne weekend har bare generelt ikke været god for mig.B Db incline bench press: (supplemental lift)10 @ 24kg16 @ 30kg15 @ 30kg10 @ 30kg - nice and slow.C1 Barbell Rows: 10 @ 60kg8 @ 80kg12 @ 90kg12 @ 90kg12 @ 90kgSSC2 Cable Scarecrows:12 @ 3,75kg12 @ 5kg12 @ 5kg12 @ 5kgD Barbell Shrugs 10 @ 60kg12 @ 90kg12 @ 90kg12 @ 90kgE Rack chins: (extra)10 x bw10 @ +10kg10 @ +10kg10 x bwSå stødte Krumborg til og så skulle der vanen tro pumpes guns F1 Db incline curls:10 @ 15kg12 @ 17kg10 @ 17kg10 @ 17kgAgainst the wall curls:14kg @ failureSS:F2: Overhead rope extensions:12 @ 28kg12 @ 28kg12 @ 28kg---------------------------------------------------------------------------------------------------------------------------------------- Quote Link to comment Share on other sites More sharing options...
essensen Posted September 29, 2008 Author Report Share Posted September 29, 2008 Programmet:Mandag: (Max-effort upper body)A. MAX-EFFORT LIFT – Work up to a max set of 3-5 reps.-Bench pressB. SUPPLEMENTAL LIFT – Perform 3 sets of max reps. 15-20 reps on the first set. Same weight for both sets.-Db incline bench pressC. HORIZONTAL ROW – Perform 3-4 sets of 8-12 reps. -Barbell Rows SUPERSET D. REAR DELT/UPPER BACK – Perform 3-4 sets of 8-12 reps. - scarecrowsE. TRAPEZIUS – Perform 3-4 sets 8-15 reps. -Barbell Shrugs F. ELBOW FLEXOR EXERCISE – 3-4 sets of 8-15 reps. -Db incline curlsOnsdag: (Max-effort lower body)A. MAX-EFFORT LIFT – Work up to a max set of 3-5 reps. squats B. UNILATERAL MOVEMENT – Perform 3 sets of 6-12 reps. Walking lunges C. HAMSTRING / POSTERIOR CHAIN MOVEMENT – Perform 3 sets of 8-12 reps. Romanian Deadlift ADDITIONAL: leg extensionsD. GROUND-BASED, HIGH-REP ABDOMINAL CIRCUIT – Perform 3 circles, 10-20 reps, 1-2 mins rest between circuits. Sprinter sit-ups, V-ups, toe touches, hip thrusts. ADDITIONAL: standing calf raise ADDITIONAL: Dips – Perform 3 sets of 8-12 reps torsdag: (repitition upper body)A. REPETITION LIFT – 3 sets of max reps or 4 sets of 12-15 reps. Incline BB Bench Press B. VERTICAL PULLING – Perform 3-4 sets of 8-12 reps. Chin ups SUPERSET C. REAR DELT – Perform 3-4 sets of 8-12 reps. Rear delt flyes MEDIAL DELTS– Perform 4 sets of 8-12 reps. DB Shoulder Press TRAPZ - Perfom 3 sets of 8-10 reps.Db shrugsSS:Triceps pushdown - 15-25 reps each setLørdag: (vanity day) – extra biceps, shoulder, calves, absDødløftA1 Cg pulldownsA2 LateralsB1 Cg cable rowsB2 Db shoulderpressC Barbell curlsD1 seated calf raiseD2 Machine crunches-------------------------------------------------------------------------Sat lidt mere overskueligt op:Mandag: (Max-effort upper body)Bench pressDb incline bench pressBarbell Rows SSscarecrowsBarbell Shrugs Db incline curlsOnsdag: (Max-effort lower body)Squats Walking lunges Romanian Deadlift leg extensionsSprinter sit-ups, V-ups, toe touches, hip thrusts. Dips Extra: Standing calf raisetorsdag: (repitition upper body)(Deadlift)Incline BB Bench Press Chin ups SSRear delt flyes DB military press Db shrugsSSTriceps pushdown - 15-25 reps each setLørdag: (vanity day) – extra biceps, shoulder, calves, absA1 Cg pulldownsA2 LateralsB1 Cg cable rowsB2 Db shoulderpressC Barbell curlsD1 seated calf raiseD2 Machine crunches Quote Link to comment Share on other sites More sharing options...
N Gadegaard Posted September 30, 2008 Report Share Posted September 30, 2008 Ved du, hvor lang tid æggehvider kan holde sig i køleskabet? Quote Link to comment Share on other sites More sharing options...
essensen Posted September 30, 2008 Author Report Share Posted September 30, 2008 Ved du, hvor lang tid æggehvider kan holde sig i køleskabet?Dem jeg har på dunk kan holde sig i 28 dage efter åbning. Hvis du blot har dem fra et æg skal jeg ikke kunne sige det. Quote Link to comment Share on other sites More sharing options...
N Gadegaard Posted September 30, 2008 Report Share Posted September 30, 2008 Dem jeg har på dunk kan holde sig i 28 dage efter åbning. Hvis du blot har dem fra et æg skal jeg ikke kunne sige det.Jeg har en dunk fra Hedegaard, så mon ikk det er det samme. Quote Link to comment Share on other sites More sharing options...
Nick_BB Posted September 30, 2008 Report Share Posted September 30, 2008 Jeg har en dunk fra Hedegaard, så mon ikk det er det samme.Hvor køber I jeres ægggehvide på dunk?Og du må meget undskylde for logspam :) Quote Link to comment Share on other sites More sharing options...
essensen Posted September 30, 2008 Author Report Share Posted September 30, 2008 Jeg har en dunk fra Hedegaard, så mon ikk det er det samme.Med al sandsynlighedHvor køber I jeres ægggehvide på dunk?Og du må meget undskylde for logspam :)Køber mine hos den lokale bager. Quote Link to comment Share on other sites More sharing options...
Krumborg Posted September 30, 2008 Report Share Posted September 30, 2008 Money over muscle!Bailer i morgen - fået en spand ekstra arbejde. Træner efter 20 istedet. Quote Link to comment Share on other sites More sharing options...
Maxmonzter Posted September 30, 2008 Report Share Posted September 30, 2008 I do 5 rep sets of squats at 250kgs lol Quote Link to comment Share on other sites More sharing options...
Christian B Posted September 30, 2008 Report Share Posted September 30, 2008 I do 5 rep sets of squats at 250kgs lolYou Rock dude!!! Quote Link to comment Share on other sites More sharing options...
Johnny Bravo Posted September 30, 2008 Report Share Posted September 30, 2008 I do 5 rep sets of squats at 250kgs lolI envy your epic posing skills! Quote Link to comment Share on other sites More sharing options...
essensen Posted October 1, 2008 Author Report Share Posted October 1, 2008 Træning den 1/10-2008Vågnede kl. 6.15 og så gad jeg åbenbart ikke at sove mere – jeg lå i hvert fald bare og vendte og drejede mig til uret ringede. Jeg kan godt mærke jeg ikke har fået noget kvalitetssøvn siden torsdag, men jeg var egentlig ret opsat på at få trænet ben i dag. Jeg har helt glemt hvor fedt det er at give træne benene igennem og være helt bombet bagefter!Jeg har i øvrigt gjort en interessant observation i forhold til mit evigt tilbagevendende problem med mit knæ – eller rettere scene ved knæet. For det er sjovt nok begyndt at komme igen og det har ellers stort set ikke været noget problem hele sommeren. Jeg er derfor kommet til den konklusion at problemet med al sandsynlighed er klimabetinget. Det lader til at mine scener ved knæet bliver ”stramme” af kulden og derfor begynder at skabe sig. Det er i hvert fald påfaldende problemet begynder igen nu der er et omskift i vejret til noget koldere temperaturer – for jeg har vitterligt intet mærket til det hele sommeren. Jeg vil derfor fremover forsøge at smutte i dampbad efter bentræning så jeg får masser af varme til led og scener.Opvarmning: Airsquats, bensving, sidesving, leg extensions.ME-Squat:10 @ 60kg9 @ 80kg5 @ 90kg4 @ 95kg3 @ 100kg3 @ 105kg10 @ 85kg- Svag omgang. Min hofte brokkede sig ikke, men til gengæld er der et eller andet i lysken der generer ved de tungeste løft hvilket lidt gør jeg holder igen. Walking db lunges:10 @ 12kg12 @ 16kg12 @ 16kg12 @ 16kg- Var bange for mit knæ ville broke sig, men det gik egentlig Ganske fint.Romanian Deadlifts:10 @ 60kg8 @ 80kg12 @ 90kg10 @ 90kg10 @ 90kgSS:Unilateral leg extensions:12 @ 20kg15 @ 35kg12 @ 37,5kgDropset:12 @ 37,5kg + 10 @ 30kg + 12 @ 22,5kg+ walking lunges @ bw-The sweet pump.Standing Calf raises:15 @ 40kg14 @ 70kg14 @ 70kg14 @ 70kg + 14 @ 60kg + 12 @ 40kgSS:Dips:20 x bw8 @ +20kg8 @ +35kg8 @ +35kg22 x bw- Denne øvelse er sat ind her på prøve da jeg træner triceps igen i morgen..skal lige se om det kan fungere.Abdominal Circuit: – Perform 3 circles, 10-20 reps, 1-2 mins rest between circuits. (Sprinter sit-ups, v-ups, toe-touches, hip thrusts)3 rounds @ 10-12 reps- Dette circuit er overraskende hårdt – var helt færdig til sidst! Her er et link hvor det kan ses: Jeg har stor respekt for fyren i den, han udfører det virkelig nydeligt med god stil og oveskud. Jeg lå sgu og spjættede helt vildt allerede i 1 runde Specielt v-ups af afsindigt svære at lave ordentligt - men jeg kan kun anbefale dette circuit, det fungerer glimrende.Tid: 1 time og 30 minMusik: slipknot – Iowa (på Karl Æg's opfordring - den holder), Lamb of God – ashes of the wake. Quote Link to comment Share on other sites More sharing options...
